The Speed Passion Thread
On the previous page I posted how there is no help here,and now the next page is full of help and advice...
Is that what it takes?...really?
OK,you can help me.
I bought three reventon pros and was led to believe the software/firmware was FULLY developed.
Now I'm not being nasty,or threatening in any way,or calling you names etc,but answer me this honestly.
Did Speedpassion release this ESC with software/firmware in its production stage to consumers too early,just to beat Muchmores Fleta 4 team of software engineers?
And why not wait until you got all the bugs out of YOUR firmware first,so that upgrades would take effect and not blow up processors?
And yes,I work with this stuff....a lot.
Answer me that.
Tim
OK,you can help me.
Answer me that.
Tim
What issues are you having?
what are your issues? I have been running the reveton pros since the day they arrived in the us. I own 6 of them and run them in off road and on road without any issues. At the track I run at I help people who do not really read instructions and set them up with no problems. So what are your issues maybe someone will help you if you let them know. By the way the muchmore fleta is the exact same esc as the reveton they get it from speed passion and runs the same soft ware.
I will post this here..... not like I will get a resolution or anything
So I updated my iOS app, now I have "SAFE MODE". Tried to update firmware in "SAFE MODE", get to the point where I have a progress bar telling me it is updating, and then "UPDATE FAIL, RESET ESC" warning.
HOW DO I RESET THE ESC???????????
THIS PRODUCT JUST SUCKS !!!!!!!!!!!!
Now SP wants me to send the ESC to HK to have it fixed. The expense of sending it back to them with a trackable shipping service will exceed the value of the ESC.
I can't think of any ESC's on the market that would require an ESC with a Firmware issue to be sent back to the manufacturer for repair.
How can SP honestly expect their customers to keep paying for repair costs on ESC's, when the failures are obviously caused by their easily corruptible Firmware?
Ridiculous!
Hey everyone, I'm in need of a little help. I'm running a sp gt2.0, firmware version 117, software v3 508 no timing but the esc is not blinking? Am I missing somthing here, or does the sp gt2.0 not blink?
Any one have any clues why this is happening and what i can do about it ?
I run a couple of GT 2.1 prostock's in blinky mode but they don't blink. Long as you see 508 no timing when you plug in the program box I believe you are good to go.
I have 2 GT 2.1 EX. One blinks, the other doesn't. When they blink, it is a very dim LED on the bottom of the ESC, very hard to see.
So is the Reventon Pro v1.1 worth it or not so much? Might have to go with the Xerun 3.1....
Can a esc be broken by connecting the motor wires wrong
I would reconnect the wires in the correct order, and test it again. If it still does not work, send it in for repair.
What are you exact issues? The Reventons were released long before the Much More ESC.
Where did you purchase the ESC? Was this a Asian, UK, or other market outside of the USA?
The GT 2.0s have the light on the bottom of the ESC. Depending on how you have it mounted you may or may not see the "blinking". This was changed with the Reventons and the light was placed on top for "tech" at races.
Yes and no. Normally this wouldn't damage the ESC, but it is hard to say without knowing specifics.
So the latest on this is that somehow the Reventon R ESC has magically acquired the wrong Identity Code in the Firmware, this is why the WiFi Module can't read the data from the ESC. There is no way to fix this with any programming device they make?
Ridiculous!
Ridiculous!
