Like Tree32Likes
Old 06-12-2013, 05:59 PM   #11701
Send a message via Yahoo to FireRacer88
.....................................e
FireRacer88 is offline   Reply With Quote
Old 06-12-2013, 08:30 PM   #11702
Originally Posted by kavajas View Post
Some times wen i turn Reventon box gives me this error:
CHECK SUM P:4AEE
F:CC4D ID:1A0000
Any teck help????
Thxs
Because you are pressing and holding the "ITEM button" when you switch on the ESC and Revetnon program card. This is not the error message. If you are pressing and holding the "ITEM button" to turn on the program card without ESC, it will display the program card version.
WMGary is offline   Reply With Quote
Old 06-13-2013, 06:01 AM   #11703
You have to go to MuchMore Fleta /assets folder and copy all the files to Reventon 1.1.0/assets folder. Then open Reventon Program, connected the box clicking the bottom them chose 1.4 from MuchMore.
Thanx a lot, working great after following your instructions.
2Quick is offline   Reply With Quote
Old 06-13-2013, 12:26 PM   #11704
I have a question about an old granturismo v1.1,can i put the firmware with turbo.into this esc? Ive never had a speedpassion before so dont know the ins and outs of it
scytherat is offline   Reply With Quote
Old 06-14-2013, 02:44 AM   #11705
Ordered a Reventon Pro combo, see that Reventon Pro 1.1 is released now
will speed passion continue to develop the software for the old reventon pro or have i done a really bad deal now?
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 06-14-2013, 03:39 AM   #11706
GT V1.1 does not have turbo software.
Old 06-14-2013, 03:44 AM   #11707
Reventon PRO 1.1's software is compatible with Reventon PRO.
Old 06-14-2013, 04:04 AM   #11708
Originally Posted by BadSign View Post
I have the Reventon Stock Club Race and would like to adjust the Percentage Braking - ABS and the Percent Drag Brake. Which Program Cards Allow me to do this?
You wont need a card , you can do it with the button on the switch . there are directions in your user manual. You can also use the LED program card.
Yogi- is offline   Reply With Quote
Old 06-14-2013, 12:49 PM   #11709
scoyle's Avatar
Is the 1.1 a new speedo or new software? And where are you reading about it?
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 06-14-2013, 01:26 PM   #11710
AdrianM's Avatar
Its an updated Rev Pro. It has some internal changes and a 30mm fan.
Adrian Martinez
Old 06-17-2013, 08:29 AM   #11711
durtbag's Avatar
Default iOS app update
I will post this here..... not like I will get a resolution or anything
So I updated my iOS app, now I have "SAFE MODE". Tried to update firmware in "SAFE MODE", get to the point where I have a progress bar telling me it is updating, and then "UPDATE FAIL, RESET ESC" warning.
HOW DO I RESET THE ESC???????????
THIS PRODUCT JUST SUCKS !!!!!!!!!!!!
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 06-17-2013, 10:19 PM   #11712
Turn off the ESC and then turn on the ESC. Also restart the app.
Old 06-18-2013, 12:41 PM   #11713
durtbag's Avatar
Yeah, that doesn't do anything. thanks for the effort!
Old 06-18-2013, 12:51 PM   #11714
Travis S's Avatar
Trader Rating: 46 (100%+)
Did you see if the app is still running in the background after you closed it and remove it from that list as well? Something could be hung up with the app and just because the app is not showing up on your phones screen it doesn't really mean it's closed all the way. I don't even know if this app runs in the background or not but it is worth checking.
(Close the app and then double tap on the square button at the bottom of the phone brings up apps open in the background.)
Travis S is offline   Reply With Quote
Old 06-18-2013, 02:32 PM   #11715
durtbag's Avatar
Nope, does not run in the background. Even deleted the app and reinstalled, and restarted the phone.
I'm sure the problem is with the WiFi Module, sent it back for repair and was told that it was a Firmware problem in the ESC.
The ESC works fine without the Module inline, so the ESC receives signal from the RX no problem.
Just keeps telling me that the ESC is not connected when I have the Module inline.
When I use Safe Mode the app shows the ESC as being connected on the app.(highlighted in green) But when I press ESC Connection (OFF) it comes up with a warning ESC not connected. WTF?????
This SP stuff has just been a nightmare....... I have given up on it.
Thanks, anyway
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
