Like Tree46Likes
Old 06-07-2013, 08:36 PM   #11671
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Originally Posted by SP CS View Post
What we can help you with?
On the previous page I posted how there is no help here,and now the next page is full of help and advice...
Is that what it takes?...really?
OK,you can help me.
I bought three reventon pros and was led to believe the software/firmware was FULLY developed.
Now I'm not being nasty,or threatening in any way,or calling you names etc,but answer me this honestly.
Did Speedpassion release this ESC with software/firmware in its production stage to consumers too early,just to beat Muchmores Fleta 4 team of software engineers?
And why not wait until you got all the bugs out of YOUR firmware first,so that upgrades would take effect and not blow up processors?
And yes,I work with this stuff....a lot.
Answer me that.
Tim
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 06-07-2013, 09:57 PM   #11672
Nanoframe's Avatar
if you are trying to connect the ESC to the computer, no battery and Fan disconnect.
If you are connecting to a program card to change setting, Battery on and fan can stay connect or disconnect.
Which was what I mentioned earlier. But thanks for adding the part about disconnecting the battery when connecting the esc to the computer.
Nanoframe is offline   Reply With Quote
Old 06-09-2013, 04:52 PM   #11673
Send a message via AIM to ^jynx^
I bought a 3racing F113 combo(with the speed passion reventon R esc and 17.5R motor)and got around to running today. I'm using a spektrum Dx2 radio and set it up per manual. Took it out for a test drive and zero braking. Then tried a few other radio set ups I have and still NO brakes. Did I get a defective unit? Or am I possibly missing something? Any help would be greatly appreciated. Thanks!
^jynx^ is offline   Reply With Quote
Old 06-09-2013, 08:26 PM   #11674
Originally Posted by busman View Post
Just installed an Revention Pro/Novak Ballistic 21.5, all said and done link the Radio etc... pull the throttle and just get a squink sound, actually tries to run backward first then tries to go forward, was able to run the car for a miniute or two, but when I came to a stop same Squink and no go.
Tried timing low and high, same thing... anyone have an Idea? Used the box to setup speedo, all checks out, latest firmware etc.. Whaats going on?
Are you sure the motor is working fine? Do you have another ESC to test this Motor? I guess the 21.5 motor have some problem.
WMGary is offline   Reply With Quote
Old 06-09-2013, 08:27 PM   #11675
Which ESC firmware are you using?
Old 06-09-2013, 08:40 PM   #11676
To be honest I'm not sure. It's right out of the box.
Old 06-09-2013, 08:59 PM   #11677
Are you sure the ESC is Revetnon R? Because 3Racing F113 combo set is using Reventon S.
Old 06-09-2013, 09:42 PM   #11678
Originally Posted by Cale79 View Post
I just have bought a Reventon Pro. Now i setted it up with the stock1 firmware without any problems. I also wanted to update the programbox to 2.7. Each time i try to do this the pc stops the program at 2%.
Any options i can go try out?
Waiting around 6 mins although the progress bar is freezed.
Old 06-09-2013, 09:56 PM   #11679
My reventon stock and my reventon s both had very little if no brakes, had to ajust via the lead program card.i think you can do it via the reset button, i think the club stock was standard at 30% brakes.
Yogi- is offline   Reply With Quote
Old 06-09-2013, 10:28 PM   #11680
Xpress's Avatar
I'm pretty sure that my Reventon came out of the box with the brake setting at 30%. I turned it up to 70% and my tc has all the brakes I could want...
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 06-10-2013, 05:51 AM   #11681
Your right it is the S. but either way the brakes suck out of the box. I'm assuming I need the card to adjust it?
Old 06-10-2013, 03:29 PM   #11682
As i wrote i had the same problem. As i now tryed to start the program as administrator it worked flawless. So try that
I updated the esc with stock1. The programbox with 2.7. At the track i had the problem my esc didnt do anything anymore. So make sure u test it. The esc didnt want to start up anymore. After putting the 2.4firmware into the programbox it worked fine again. All setting also the hybribboost work great.
This esc is a monster !
Cale79 is offline   Reply With Quote
Old 06-10-2013, 03:39 PM   #11683
Wish I'd have stayed with my Reventon pro all along. Moved to a flow works but that went pete tong at the weekend....
Reventon shall be staying in the car from now on. Any changes in software since around december?... Running 13.5
Mi4cxl is offline   Reply With Quote
Old 06-10-2013, 03:57 PM   #11684
Ok, I'm about to install a reventon pro in my 17.5 tc. And have a few questions;
1) how to I install the 'stock 0' blinks mode software onto the esc?
2) will I have compatibility issues with the Novak 17.5 motor?
Chrisg23 is offline   Reply With Quote
Old 06-10-2013, 04:55 PM   #11685
Also does the fleta 4 software work on this? If so is there any advantage to it
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
