Like Tree3Likes
Old 05-15-2013, 10:38 AM   #11581
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Originally Posted by Yogi- View Post
Ive got a reventon club stock that ive been trying to set more brakes on. Now it wont drive. Im setting it via the reset button as per intructions, ive had a few goes at it and reset the throddle at least 4 times,Ive got power runing to the servo and fans etc. Any help would be great.
Hey
If you go back to page 770 and direct this question to "Solara"(Howard),he may,or should be able to help you.
There is SUPPOSED to be SP techs answering questions etc,as well as Howard.
You will usually get help from someone who also uses your esc though.
Try your local hobby shop.
Cheers.
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 05-20-2013, 12:22 PM   #11582
Ok put gear ratio back to 8:1 and advanced the timing to 10 deg on motor bellend now it is just as fast as when it was running around a 6:1 ratio with 5 deg bellend timing!!!! Does anyone know how much timing the esc applies to the motor in stock 1 as it is not adjustable? How much bellend timing should i be running? I see the new sp mmm motors come stock set at 15 deg, should I put a 11 - 20 deg sensor board in?
181racer is offline   Reply With Quote
Old 05-23-2013, 07:41 PM   #11583
clubbeno's Avatar
Default top end
G'day,
I have a V3 13.5T & reventon pro running Stock1. I was having trouble keeping up with guys down the straight.
Endbell timing is stock, FDR is 5.7, motor usually came off 70*c
Boost:80
HB max: 135~140
punch:5
start RPM: 8000
Any pointers would be helpful. Newbie to brushless tuning scene. I was thinking of 5.5 FDR, more HB max and lower start RPM...Would this be heading in the right direction?
FYI - Mate had same car, same settings but with a MMM motor. He smoked it & it wasnt any quicker than mine. (because he had more timing in total?!being an mmm 11-20*)
clubbeno is offline   Reply With Quote
Old 05-24-2013, 10:51 AM   #11584
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by clubbeno View Post
G'day,
Boost:80
HB max: 135~140
punch:5
start RPM: 8000
Turn up the timing on your 13.5 endbell to all the way 10* (full right) then gear to 6 final then do the following...
Boost:80%
HB max: 150k (max)
punch:7
start RPM: 3000 rpm
Engage time: 0.1s
Slope: 12*/0.1s
If your motor temp can take up a notch, go down the slope to 6*/0.1s
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-24-2013, 06:26 PM   #11585
clubbeno's Avatar
Default thanking you
Thank you very much! Will give it ago
Old 05-25-2013, 12:03 AM   #11586
G-rem's Avatar
Hello everyone,
I have some problems with the Stock V20 soft in my Reventon Pro, used with a 4.5T motor and on an Awesomatix: when I accelerate, there are some power cut-off, like if I had sensor problems (I tried with another one, same problem). So it's not progressive at all.
What can be the mistake? Thanks for help,
Regards,
G-rem
G-rem is offline   Reply With Quote
Old 05-25-2013, 05:51 AM   #11587
Holmenkollen's Avatar
I have a Reventon Pro with SP 4.5. With V20 stock software the motor ticks ever so slightly forward in neutral after calibration. Had to add some negative value on the throttle trim. With the software that came with the ESC I hade zero problems.
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 05-25-2013, 07:26 AM   #11588
Timbo99's Avatar
Default Software change
G'day,
Boost:80
HB max: 135~140
punch:5
start RPM: 8000
Hey,
Try running the Muchmore Fleta 4 stock software.
Your LCD programmer will accept it as I've done this with mine,and everything is a lot smoother and more adjustable.
Checkout www.muchmoreracing.net for instructions.
Best of luck!
Let me know how it goes.
To be bluntly honest the Speedpassion firmware/software was released to early,as there is more development needed.
You will be much better off running the muchmore versions.
Cheers
Tim
Old 05-25-2013, 05:02 PM   #11589
cwoods34's Avatar
Originally Posted by G-rem View Post
Hello everyone,
Regards,
G-rem
I'd highly recommend the Modify1 software, which is the one that came pre-loaded on the Reventon Pro I think. The stock softwares are pretty aggressive, and I noticed both the ESC and motor ran hotter as compared to Mod1.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 05-25-2013, 05:04 PM   #11590
Originally Posted by Timbo99 View Post
Hey,
Best of luck!
Cheers
Tim
There is no more options to change they are just name different names
And it's just rebranded software
Plus also if speedpassion find out that its much more software while in warranty they have all rights to void it and you will be paying the repair bill
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 05-25-2013, 05:33 PM   #11591
Trader Rating: 20 (100%+)
Guys,I need a starting setup for Reventon Pro with SP 10.5t MMM boosted on carpet track.The track its 85' x 42'. Help are welcome.
Schumasher CAT K1 AERO/HobbyWing V3.1 ESC/HobbyWing V10 6.5T Motor/IP Batteries
WWW.SPEEDLINEHOBBY.COM "A HOBBY STORE FOR RC RACERS"
IVAN RM is offline   Reply With Quote
Old 05-26-2013, 01:30 AM   #11592
G-rem's Avatar
You're right, but no one uses this software even in mod classes. Have a look at Wilck last set-up in Gran Canaria, he ran with the Stock V20 software plus Thunder Power 4.5t...
A little clarification: I put the stock V19 (the previous one before Stock V20) and I had no problem; accelerations are linear and I have no power cut-off during this phase; so I think the problem come from V20 software...
Best regards,
G-rem
Old 05-26-2013, 04:24 AM   #11593
Timbo99's Avatar
The Speedpassion software IS NOT RIGHT.
I was hoping my " muchmore" related post would prompt a response from Solara or a SP Tech.
This is a joke.
That's why I've uploaded the MM software to my SP LCD box and wow.
Chalk and cheese.....
I then bought a Fleta 4 esc.
And that's why I shared what I did because it worked,I have spent excess of $$$$$ with Speedpassion,I trusted and waited,waited,waited,now there is nobody who helps you guys with your issues.
Pretty lame.
I still believe this software is in a somewhat of a beta stage.
The GT2 & 2.1 are fine.
I may be selling a reventon pro to a friend,but I will recommend running the MM software.
The product is awesome,just get the software/ firmware right!
Regards guys,
Tim
Old 05-26-2013, 11:48 AM   #11594
kwiksi's Avatar
Trader Rating: 103 (100%+)
Send a message via AIM to kwiksi
Anybody have a FDR starting point for 21.5 MMM on tight carpet track for TC rubber tire blinky?
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - PT Racing Oils - 92Zero Designs
kwiksi is offline   Reply With Quote
Old 05-26-2013, 05:52 PM   #11595
This is a joke.
Pretty lame.
Regards guys,
Tim
Does this work for reventon r? I have one that the lipo cutoff does not function on stock 1 v19 and they have not yet released v20.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
