Like Tree12Likes
Old 04-29-2013, 11:36 PM   #11521
skyball's Avatar
Originally Posted by Eazy View Post
I did swap to a new sensor wire but it did not help. The thing is this problem is intermittent, it starts fine then in the middle of a run i don't get the boost anymore as though it went to blinky I have to go to a full stop or even on n off again then it works again.
I had a similar problem with a LRP X12 motor. It ran fine at my workbench, but on the track after some laps it would send the esc into "error blinky mode" as i call it (both leds blinking). In the end it turned out to be a faulty sensor board in the motor causing this.
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 04-30-2013, 10:25 AM   #11522
mxgregg's Avatar
Trader Rating: 32 (100%+)
Whats the hot setup with a reventon R and a modified 5.5 Orion motor in a touring car?
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 04-30-2013, 10:42 AM   #11523
hi sorry v20 only for the pro i got confused but u may have a high power servo that the esc bec cant handle you get it alot with spectrum and savox servos try a power cap on the receiver as the voltage might be dropping there? just another idea alot of brands stuffer with this as these types of servos draw up to 3.2amps and most esc bec supply 3.0amps
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 04-30-2013, 02:47 PM   #11524
tc3 racer sc's Avatar
Default Esc for repair
Where can I send my Esc back for repair thanks for your help
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 05-01-2013, 09:05 AM   #11525
Did few more testing with the Reventon R today. Reloaded the firmware again. Soldered the esc fan directly to battery supply, change between few motor, but result same as before. Still getting the red and orange blinking lights when i loose my boost during a run.
Any SP tech care to help shed some light to the matter. I've been reading thru the internet and it seems that it is not the 1st time someone has encounter the matter but I've yet to see a proper solution.
Hope someone from SP can help me soon as i have a race over the weekend and i would really love to run the esc
Thanks!
Eazy is offline   Reply With Quote
Old 05-01-2013, 12:50 PM   #11526
Thanks!
Some motors have incompatible temperature sensors. You could try cutting the temp sensor wire on the sensor cable. This thread has the details if you try a search.
dvaid852456 is offline   Reply With Quote
Old 05-01-2013, 05:25 PM   #11527
Speed Passion's Avatar
Angry Still Horrible Support
Good luck if you get any decent support. I can't even get them to handle a simple body sticker issue, STILL. It's been 3 weeks now and still nothing. I'm even told they only have one to spare but online they have more than one body available, jeeze.
Speed Passion is offline   Reply With Quote
Old 05-01-2013, 05:30 PM   #11528
Well I was using the bundled sp 13.5t v3 motor. N the problem still persist.
Old 05-01-2013, 07:59 PM   #11529
What motor timing are your using? Could you try lower motor timing such as 0, 5 and 10 timing.
WMGary is offline   Reply With Quote
Old 05-01-2013, 08:05 PM   #11530
Check PM.
Old 05-02-2013, 05:22 AM   #11531
The motor timing we set @ zero. I've given up testing n reported the case to the local distributor here. Hope to get a replacement soon.
Old 05-02-2013, 09:28 AM   #11532
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Smile Lovin my S/Passion!
That's a shame.
I've had nothing but positives from Speedpassion,from using their products to customer support via phone,email etc.
I can't fault the product,service or price.
Thanks guys!!!!
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 05-02-2013, 04:20 PM   #11533
Originally Posted by Timbo99 View Post
That's a shame.
Thanks guys!!!!
Yeah I don't understand. I got two bodies that had the stickers stuck together and ruined. I asked that they send another set, as online they have plenty of the same bodies still for sale. This is their reply:
"There is only one set of sticker match to one body. We don't have extra for replacement, not that we don't have it in stock. We can only provide you with a refund on that body."
Thank you
Speed Passion
It's like I don't need a refund as I need a body that I can use, and if you have other one's you are selling why are you not taking it from one of them?? Buy another body is the impression I'm getting or take a refund?
This is really ridiculous!
Old 05-03-2013, 03:01 AM   #11534
peter.'s Avatar
I have a sp Competition MMM Series 13.5R and if I drive with blinky 20grade timing can I also just to keep 4.0 or higher
peter. is offline   Reply With Quote
Old 05-03-2013, 11:02 AM   #11535
trx450racer174's Avatar
I searched and could not find a good answer.
17.5 Blinky TC running Rev Pro with and a MMM with a 12.5mm red ring rotor anyone have a good starting FDR and reccomended timing.
I have the stock, green and yellow timing boards.
Track has a 125ft straight.
Any help is appreciated.
E.K.D. RC Paint Work
Team Serpent USA, Desoto Racing , Team DE Racing, Team Hitec, Team Trakpower, Futaba, Team AKA, TrackstarRC.
trx450racer174 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
