Like Tree46Likes
Old 04-14-2013, 01:42 AM   #11446
SourDieselX's Avatar
Normally I'm a really loyal customer of SP, have loved their products, I just picked up the Reventon Pro and the wifi module and have had the worst luck. The slot where the sensor cable goes in, one of the prongs is half missing, secondly, I can't get the wifi to work worth a darn. I can't get it to stay connected or anything, I'm really baffled ;\
---Sponsor: Remote Control Hobbies---
http://www.facebook.com/pages/Remote-Control-Hobbies/156985487744758
Go big or go home!!
SourDieselX is offline   Reply With Quote
Old 04-14-2013, 07:21 AM   #11447
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Originally Posted by Dog Runner View Post
I'm confused as to where to get the most recent software for the reventon pro. Is it via the computer or the wifi module/app or somewhere else?
What version number is the most recent software?
If its a computer program, does it work on a Mac ?
Thanks for any help.
You can find the latest version of the software below, entitled Reventon PC Program with USB Driver V1.1.0.22:
http://www.speedpassion.net/en/download.asp
As I stated a few replies above yours, I am running the program on a Mac, but not natively.
I am running the current version of OSX and installed an old version of XP SP3 that I've had lying around.
If you aren't really computer savvy, I would skip the XP install and install Windows 7 via Bootcamp as it will be much easier.
Installing the Speed Passion program itself is pretty simple, unzip the program, install the USB driver, locate the driver in com ports and double click or right click? to assign it properly and complete the driver installation.
After that, install the PC program, connect your ESC, and the rest is simple.
IIGQ4U is offline   Reply With Quote
Old 04-14-2013, 10:48 AM   #11448
durtbag's Avatar
You are not alone, I was able to get the WiFi module I purchased to work 3 times and it failed. I have sent it back hoping for a replacement.
I just don't think the technology is perfected yet, and we the end purchasers are being used as testers at our own expense.
I have not seen any of the the known SP Reps on this board respond to questions about failed Bluetooth and Wifi Modules, makes me wonder about the integrity of the company.
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 04-14-2013, 11:09 AM   #11449
Mine consistently disconnects, I can't get it to connect to the ESC, I've followed the steps to the T that they have in their manual and website and the same thing keeps happening. I'm really disappointed in their products this time around. I had high hopes for the Reventon Pro and the wifi and am completely let down. Hopefully their customer service lives up to their products and takes care of it as I've never had to deal with their CS before.
Go big or go home!!
Old 04-14-2013, 01:01 PM   #11450
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
Where is the "turbo" feature in the Reventon Pro settings?
I understand that there's timing and punch already, but I'm looking for a Tekin-type "turbo" setting to kick up the top speed for straights.
Am I missing it or does the Reventon Pro not have it?
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 04-14-2013, 01:06 PM   #11451
IIGQ4U's Avatar
Which profile do you have loaded on your ESC?
Old 04-14-2013, 01:31 PM   #11452
Dog Runner's Avatar
However it came out of the box is what I have on my esc right now. I downloaded the newest PC software but did not see any type of "turbo" in the user manual and so I have not installed the newest software on the LCD box or on my reventon pro yet.
Is there a specific profile that has a turbo feature that maybe is not listed in the instruction manual?
JR
Old 04-14-2013, 01:41 PM   #11453
IIGQ4U's Avatar
You won't see a turbo function in the manual unfortunately. This functionality will be available once you install the current software onto your computer and connect the ESC.
You will need to load a profile that allows dynamic timing (Not blinky).
Were you able to properly install the USB driver?
Old 04-14-2013, 02:29 PM   #11454
Dog Runner's Avatar
I'm running windows XP on a mac using Parallels.
've been able to successfully load the PC program and my Parallels XP system sees the reventon LCD box as the "CP2102 USB to UART BRIDGE CONTROLLER" but the PC program does not seem to recognize it.
Within the PC folder I do see the "SPusbdriver 6.6" folder. I think I have installed that correctly because now if I click on the setup icon in that folder, it says that the driver is already installed. However, if I unplug and then plug in the LCD box, it get a "new hardware"wizard that pops up.
I'm not sure about this "com ports assignment" you mentioned. Maybe that's what I'm missing.
edit: found the device manager and located the reventon box and the device properties says that the device is not configured correctly. So, maybe the USB driver was not installed correctly. So, now I don't know where to go.
JR
Old 04-14-2013, 02:39 PM   #11455
IIGQ4U's Avatar
Yeah, that's the part you are missing.
Do you know how to get to the com ports?
Just go to Start/My Computer/View System Information/Hardware/Device Manager/Ports and then double click the port that says Speed Passion. After this, click driver and update driver... I'll update the rest in a sec. I need to check again for myself.
Old 04-14-2013, 02:53 PM   #11456
Dog Runner's Avatar
Sorry to other forum members for this back-and-forth, but maybe someone else can learn from this, too.
I can get to the Device Manager. I don't see "Speed Passion", but do see a 'bridge controller' which is the LCD box. If I click on that and then click on 'install driver' the system looks for software but can't find it anywhere.
Notice that the port dialog box for the controller says that it's not configured correctly. Not sure why that's happening.
JR
Old 04-14-2013, 02:54 PM   #11457
IIGQ4U's Avatar
Yeah, I am trying to help you and others with this issue.
You need to click "No, not this time," and then "Install from a list or specific location (Advanced)"
Next, browse your C drive under Program Files and find the Speed Passion USB Installer program and click next.
You will then see a Hardware Installation Caution where you will click "Continue Anyway"
After this, click "Finish" and you are done.
I will update screen shots momentarily.
Old 04-14-2013, 03:27 PM   #11458
IIGQ4U's Avatar
After you plug in your new USB device (Speed Passion program card), you may see the following:
After you click no and proceed, you will see:
Click install from specified location and proceed
Here, you will find the location of your SP USB driver. If you have not already attempted to install it, you may see it on your desktop. If you have attempted to install it already, you can find it in Program Files
After you have found the location of the SP USB installer, you will see the following:
Click "Continue Anyway"
Now click "Finished"
To verify the installation, go to your Device Manager and expand the ports column. When properly installed, you will see the following:
After this, fire up your Reventon ESC program, plug your ESC 3 port lead into the 3 port slot on the programming card and insert the USB into the computer:
Once this is all done, you will see something similar to this:
From here, you are on your own.
Old 04-14-2013, 04:19 PM   #11459
Dog Runner's Avatar
Thank you very much for all your help.
I keep getting an error though. I think maybe part of the problem is that my computer does not recognize the LCD box as Speed Passsion. It just sees it as "CP2102 USB to UART BRIDGE CONTROLLER" and it shows up under "other devices" in the hardware manager, not the "ports".
I can get through all the steps you provide but when I locate the USB folder and try to install, it just ends up saying that I cannot install the hardware because the wizard cannot find the necessary software.
I told it exactly where to look though, so I'm not sure the problem here.
I am using the box that came with the Reventon Pro. It says it's the "Smart LCD Program Card". Do I need a different box?
JR
Old 04-14-2013, 04:22 PM   #11460
woozer71's Avatar
Trader Rating: 23 (96%+)
Originally Posted by woozer71 View Post
I am running the reventon pro with LRP x12 10.5 in blinky mode. I am running the v20 software. The problem I have is that when the car runs the power seems way down. The voltage in the battery is fine. I ran the motor with my HW justsock and the motor runs fine, so that not the problem. I have tried the esc with a17.5 Tekin and it does the same thing. Any suggestions would be appreciated.
Fraser Coast RC Car Club/FCRCCC
VBC D06 / Xray T4 2013
Yokomo BMax2 ver 2 - Tamiya F104 x1
Sanwa MT-4
woozer71 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
