The Speed Passion Thread
I'm having some trouble programming timing in my Ver 2.0 ESC. I'm using the HW program box, and HW software. When I try to set the boost start RPM, that option is greyed out, and can't be selected. Does anyone know what I'm doing wrong?
are you using the GT2.0 pro? You may just have the wrong software installed. If it has 508 installed, that's "blinky"
and the timing will be greyed out. You probably should use 428 or 528 stock. This will give you all the settings. I can show you next week if you don't get it sorted out by then.
Hey Ryan,
Thanks for the reply. Looks like I'd better be careful on what I buy. Wouldn't wanna get a DQ
Hi , I'm wondering if anyone can tell me what hb sloperate means?
Hope this help also good way of getting a lower motor/esc temp is running a smaller slope as the more deg you try to add every sec will add load which increases heat
I am having trouble with a reventon s:
I rewired the motor/ speed control and now my forward/ reverse is backwards. I recalibrated and checked the throttle reverse on the remote, but I can't seem to change it. Also, when I dont have the sensor cable connected the motor functions fine (except for previous issue) but when I hook up sensor cable the motor seems to be cogged. I tried another sensor cable but it did not help. Should I reflash the firmware and see if it solves the problem? Thanks for any help
Sorry I didn't mention that I have a Reventon Pro & a SP MMM 10.5T motor running the 11-20 set mid way.
I read on the speed passion site that Stock0 has "ZERO TIMING "Stock - Blinky" so is this the 508 software?
So all the scrutineer cares about is if the ESC is flashing at Neutral as per the ROAR rules.
But the original question still stands, the Blinky ESC runs no timing So how does Mod 2 with no timing behave differently. Or is it the same?
But I did have a rock lodge itself into my Fan on the ESC which is now not working to well.
So on a Reventon Pro what are safe ESC temps ? I am guessing no higher than 60Deg.
How many people run No fan on there ESC.?
Hi Guys
I have updated my firmware for my Reventon Pro and put it in the drift mode. Should have forward and reverse. But I am facing a problem whereby sometimes the motor wont reverse. Anyone faced such a problem?
Can someone explain the difference and adjustable parameters of the Speedpassion modify1 software compared to the stock1 software? Is the modify1 software suitable for running a 17.5t motor in stock boosted or am I better to just stick with stock1?
I'm waiting for my new thunder power Z3R 17.5 motor to arrive to, since I spent the last week testing trying to set up my speedpassion to run an LRP X12 17.5 for stock, only to be bashing my head against the motor temps before discovering that the motor is completely knackered...hence the high temps!
I was only running very mild boosting and still reaching 105degrees celcius in 6 minutes at our track
FDR 5.38:1
DRRS 1
HB power 40%
HB max rpm 120k
HB start rpm 5000rpm
HB sloperate 6.0 deg/0.1s
so im thinking if I cant get the motor to behave using the stock1 software, maybe the modify1 software is better suited to my track and driving style if its a milder software
any help appreciated guys,
Chris
FDR 5.38:1
DRRS 1
HB power 40%
HB max rpm 120k
Chris
The mod1 softwear think only has static timing not boost/turbo timing
I bought the 17.5 MMM motor and it arrived at the end of February but I've been having some problems with it. When I accelerate it kind of bogs and hesitates a bit before it gets going. I also noticed it's not any faster than my old Speed Passion motor that had no timing adjustment on it. I thought it was the sensor cable so I ordered a new one and tried that but I still got the same problem. I'm using a Reventon Pro with this motor too to replace the old Citrix ESC I was using before. So I took out the sensor board and did a bit of troubleshooting with a multimeter to test the connections and I noticed that there are two empty solder pads. It looks like a capacitor or resistor should go there but I"m not sure. Can anyone confirm if my sensor board is missing a component in the area I have circled in red?
