Old 03-18-2013, 02:14 PM   #11341
Originally Posted by ruebiracer View Post
Hey guys,
thinking about getting a new ESC for my 417,
and Iīm tending to try the new LRP Flow, as itīs already quite popular here in Europe. My second favorite is the Reventon Pro, as I only had the best experience with Speed Passion so far.
Iīm running 17,5t blinky most of the time, but have to use LRP X12 motor by law.
I would appreciate any pro and contras you may have for me!
And can the Reventon be run Forward / Brake+ Reverse in blinky mode?
I know my old sP can, but the manual of the Reventon seems to say no.
BR,
Matthias
Hello Matthias,
If it is Binky mode(Roar Legal), then there is no reverse. No matter old or new SP ESC.
Thank you
Speed Passion Customer Service 1-888-928-1328 usa@kinggoldenltd.com
SP CS is offline   Reply With Quote
Old 03-18-2013, 02:30 PM   #11342
clint's Avatar
Trader Rating: 22 (100%+)
Send a message via MSN to clint
thank you for the reply, I ended up receiving an email today confirming they have my esc..
Originally Posted by SP CS View Post
Hello Clint,
Normally within 24-48 hours. if it fall on a Friday, it will be on the following Monday.
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 03-18-2013, 04:39 PM   #11343
mental_raycer's Avatar
Hi guys im running the reventon pro in 17.5boosted on alarge track, ivr been runnning the SP V3 motor for a little while but I cant get any speed out of it and so ive gone for thw LRP X12 again, can someone give me a good starting point for boosting numbers using this motor?
Running a 5.38:1 FDR for our large track with an 80m front straight and its a very flowy track so high speeds are the norm here. I couldnt push the sp motor past a certain point to chase the faster guys at the state titles.on the weekend, losing 10+ car lengths on the straights and making just 2 back throigh the technical section
Any help appreciated, thanks
Chris Mitchell
West Coast Model RC Club President
Ryper Hobbies | AKA Racing | Hobbywing | Wild Turbo Fan
mental_raycer is offline   Reply With Quote
Old 03-19-2013, 01:18 PM   #11344
ruebiracer's Avatar
Hello Matthias,
If it is Binky mode (Roar Legal), then there is no reverse. No matter old or new SP ESC.
Thank you
Oh, didnīt know that. So I have to check my ESC settings. It was definetely blinking and had a reverse after full stop. Software was this 508 file.
I have to look what went wrong...
Thanks so far,
Matthias
www.TTSC-Racing.de
www.skodacup.de
ruebiracer is offline   Reply With Quote
Old 03-19-2013, 05:05 PM   #11345
Pittster's Avatar
Just a quick question, I run in a Pro2 SCT class which is 10.5T motor no timing So I have been running the latest Mod2 firmware with 0 timing and its been working great.
But we have a event coming up that requires the Binky software to be loaded so going off some complaints here of cogging what is the difference between Stock0 & Mod2 when they are both at 0 timing?
I did read that Mod 2 is meant to be more aggressive? But in what way.
Pittster is offline   Reply With Quote
Old 03-19-2013, 10:47 PM   #11346
YoDog's Avatar
Trader Rating: 25 (100%+)
If they are requiring "blinky" at the race, you will need to use software version 508 only. If you use either stock or mod, you will not pass tech. These are not "blinky" regardless of what the timing is set at. What speedo are you running? Revention?
YoDog is offline   Reply With Quote
Old 03-19-2013, 11:27 PM   #11347
Pittster's Avatar
Sorry I didn't mention that I have a Reventon Pro & a SP MMM 10.5T motor running the 11-20 set mid way.
I read on the speed passion site that Stock0 has "ZERO TIMING "Stock - Blinky" so is this the 508 software?
So all the scrutineer cares about is if the ESC is flashing at Neutral as per the ROAR rules.
But the original question still stands, the Blinky ESC runs no timing So how does Mod 2 with no timing behave differently. Or is it the same?
Old 03-20-2013, 10:14 AM   #11348
Morbo's Avatar
What color is the high torque 12.5mm rotor that fits in the 17.5 MMM?
All humans are vermin in the eyes of Morbo.
Morbo is offline   Reply With Quote
Old 03-20-2013, 10:29 AM   #11349
Be careful on the rotor you get. there is a 12.5 rotor with a red band that SP is selling that is NOT Roar legal. it's basically a mod rotor. They have another rotor with a gray band, that is a legal rotor. The tricky part is, the part number is the same
DOTMAN is offline   Reply With Quote
Old 03-20-2013, 12:21 PM   #11350
hi that guy has confused you, he is talking about 508 blinky that goes onto the gt pro2
there is a cogging problem moving away but only on v20 stock0 off the V1.1.0.22 programmer softwear, if you get hold of V1.1.0.21 like i have there is no problem
i have both as i run blinky and stock1 softwear
mod 2 also has very strong brakes (meant for off road)but can't be in blinky as you can add static timing in the esc plus the blinky light
hopes this helps you
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 03-20-2013, 03:00 PM   #11351
Pittster's Avatar
Thanks makes sense the 508 is for hobbywing/gt pro2's I can see where YoDog was coming from.
That's interesting that the Stock0 brakes are weaker than Mod2.
Maybe a Speed Passion rep can explain the core differences between Stock0 (Blinky) & Mod2. (Apart from the obvious Stock0 has no timing or boost adjustments)
Old 03-20-2013, 05:40 PM   #11352
b20btec's Avatar
I'm running a 17.5r 3.0 which way do I turn to advance. Look at my picture did I go the wrong way?
b20btec is offline   Reply With Quote
Old 03-20-2013, 06:18 PM   #11353
nolo148's Avatar
Advance motor timing? To do so loosen the 3 screws on the motor, tap the rotor on a table or flat surface which will losses the sensor board and turn it to the right (20*) afterwards just screw in the 3 screws. Check for the motor temp to. There's also a video on YouTube showing how to do it.
nolo148 is offline   Reply With Quote
Old 03-20-2013, 06:42 PM   #11354
b20btec's Avatar
Thanks man.
Old 03-20-2013, 09:01 PM   #11355
If you need more timing on your motor to get more speed, you can purchase different circuit boards from S/P. The boards go from 20-30 degrees, 30-40 degrees timing, nd 40-50 degrees timing. They work great, but you really have to keep an eye on your motor temps.
gdcopbdcop is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
