Old 03-05-2013, 05:16 PM   #11296
Originally Posted by Solara View Post
Yes, it is there for you to use...use it.
Ah okay, cool
dvaid852456 is offline   Reply With Quote
Old 03-05-2013, 07:29 PM   #11297
Andy w's Avatar
Originally Posted by Andy w View Post
So I am a little dumbfounded on a Reventon R in a 1s application.
I have used my Reventon R in my oval car with a 13.5 1s. I used it with a LiFe rx pack and a Novak Smartboost. I had it in this setup for over a month. If this isn't possible how did it work. Now I have a LRP SSX in the oval and the the Reventon is in my TC.
It worked fine in both 1s and 2s for me.
Anyone???
Andy w is offline   Reply With Quote
Old 03-06-2013, 03:23 PM   #11298
kwiksi's Avatar
Trader Rating: 101 (100%+)
Send a message via AIM to kwiksi
If anybody needs a SP 6.5V3 check the ....
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - Vision Racing Products - Reilley Motorsports - 92Zero Designs
kwiksi is offline   Reply With Quote
Old 03-09-2013, 02:33 AM   #11299
My almost new Reventon Pro started to turn itself off the other day.. Thought it was some loose wires, but it was not. Can drive for about 5 mins, then it cuts, no lights ,no power, no nothing. Can turn it stright on again. It does not get hot. Drove it on the straight with full throttle,then it turned off, no brakes. If there had not been a net after the jump in the end, somebody may have died (it was not there 2 months ago) . Tried to read most of the threads, but could not find a solution. Running 5,5 T combo mmm SP motor. All the latest firmware/software, mod 1
AlekB is offline   Reply With Quote
Old 03-09-2013, 01:34 PM   #11300
Hello, its my first post.I run a gt2.0 speed control with an Lrp motor x20 5.5T 4dot timing(27.5) and i have a problem.When i use the program V3.0 120428 or 110323 stock the speed works on the 1/4 of the full speed and sometimes works and then again to 1/4 speed.Whe i go back to V2.0 100528 stock the speed works great.Do you have a solution?
I read alot but im lost here.Thanks
akisole is offline   Reply With Quote
Old 03-09-2013, 08:53 PM   #11301
Solara's Avatar
Trader Rating: 16 (100%+)
Anyone???
Even with receiver pack and booster, Reventon S and R will not work with 1S.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 03-09-2013, 08:55 PM   #11302
Solara's Avatar
Please turn off lipo cut off, and thermal protection, then recalibrate with radio and try again....and, try to use MOD2 software. Just give that a try first.
Old 03-09-2013, 08:58 PM   #11303
Solara's Avatar
You are running BOOST (428) program, with a 5.5T motor and using the highest timing (4 dot 27.5*) on it...? You are lucky you didn't blow up that motor....when i run mod with boost, I set the motor with the LOWEST timing as possible.
I would change the insert on your LRP to 0 dot and try again....if the GT2 work with the 2010 version 528, it will work on the 2012 version 428....
Let us know your setup on the 428....
Also, you mentioned it work on 1/4 speed....do you mean it only give you 1/4 of the throttle..? After you load the software, did you recalibrate with your radio again..? Every time you changed software, you have to recalibrate with your radio (with your ESC).
Old 03-09-2013, 09:41 PM   #11304
Andy w's Avatar
As I said in my post, mine DOES work with a 1s. It works with either a rx pack or booster. I am trying to figure out why when it supposedly shouldn't.
Old 03-09-2013, 11:23 PM   #11305
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Unless the X20 differs substantially from the X12
4 dot is the minimum timing adjustment
LRP-X 12 series timing info
4-dot = 27.5
3-dot = 32.5
2-dot = 37.5
1-dot = 42.5
0-dot = 47.5
You read the timing with the dots facing you.
Info supplied by
Reto Koenig
LRP electronic GmbH / Germany
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-10-2013, 01:07 AM   #11306
Every time i load a new software i recalibrate the speed.The timing in x20 is the lowest 4dot 27.5 the other is 30, 32.5, 35 and 37.5.
I will tell you exacly what it made me.
For the first 30 seconds the speed work in full throttle.after that when i keep the trhottle in 1/4 for 1 sec(entering a corner) and give all the thortle exiting the corner the car goes with 1/4 of thorthe.I dont have full thortle.When i leave and give again full thortle gives me 3/4.I work it like a nitro with playing all the time with trhottle to work.
I play
Drag Brake Force 15%
Low Voltage Cut-Off 3,4v/cell
"DDRS" Start Mode level 3
Maximum Reverse Force 50%
Initial Brake Force 0%
Neutral Range 6%(Narrow)
Turbo Open Time 12 deg/0.1sec
Boost Start RPM 9000rpm
Turbo Open Delay 0.2 sec
acc 750
Old 03-10-2013, 10:45 AM   #11307
MOmo's Avatar
Just picked up a Rev. S model off a fellow racer last night.
Plan on using it in my drift car. Appears that 9.5 is the lowest motor application, correct?
Has anyone else tried the drift profile and is there a major difference from stock? Mod?
Momo
RACE CARS: B44.1, RC8.2E FT, SC10.2 4X4, B5M, YZ-2
RADIO: Futaba 4PKS/3PKS. BATTERY: Venom
ESC: SpeedPassion. MOTORS: SpeedPassion / Venom
"Im not a racer, but I play one on the Internet"
MOmo is offline   Reply With Quote
Old 03-10-2013, 11:07 AM   #11308
Trader Rating: 17 (100%+)
I'm looking to get a Reventon Stock Club ESC to run blinky 17.5 in my 2wd SC10. I have a Savox 1258 in the truck. Anyone experience brown out issues with this combo? I know the Savox are power hungry. Just want to make sure the ESC BEC is up to the task of a Savox servo before I buy one.
Snafujg is offline   Reply With Quote
Old 03-10-2013, 09:09 PM   #11309
EDWARD2003's Avatar
Okay.... were in Japan can I purchase the greening timing board for MMM motors?
EDWARD2003 is offline   Reply With Quote
Old 03-10-2013, 11:27 PM   #11310
quickershifter's Avatar
I can't get my Rev R to on the turbo/boost. How to set it up? I'm running Yeah Racing Hackmoto 13.5T BL motor.
quickershifter is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
