Like Tree46Likes
Old 02-24-2013, 11:47 PM   #11266
Trader Rating: 27 (100%+)
Originally Posted by thunderbt3 View Post
Pick up a programming box or find someone at your track that has a programming box. You can increase the amount of brakes via the programming box.
I got one. Updated the box. Just not sure on the numbers. Some say the lower the numbers, you'll have more brakes and some say the higher the numbers, you'll have more brakes.
JoeyE is offline   Reply With Quote
Old 02-25-2013, 05:42 AM   #11267
Originally Posted by JoeyE View Post
I got one. Updated. Just not sure on the numbers. Some say the lower the numbers, you'll have more brakes and some say the higher the numbers, you'll have more brakes.
What is your current break setup om the prog.box? The higher number the more breaks you get. To much and it will feel like you have zero breaks (tire lock) hope this Helps:-)
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 02-25-2013, 08:20 AM   #11268
Great, thank you~!
Old 02-25-2013, 12:01 PM   #11269
durtbag's Avatar
Default WFi Module
Just looking for some feedback from those using the WiFi Module with their Reventon ESC's. I have read most of the thread but there is not much mentioned about the WiFi or Bluetooth Modules.
Any comments good or bad would be appreciated.
Thanks, Terry
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 02-25-2013, 12:18 PM   #11270
tazfam2's Avatar
Trader Rating: 40 (100%+)
Originally Posted by mtbboy View Post
Can I run a reventon r in 1s mode?
If so how.
D.
No you cant only the pro with a booster or reciever pack
Xray x1 17 Xray t4 2017
T4 2017 tekno 48.3. Associated B6 B64
Leisure Hours Hobbies and Raceway
Fiercesolutions.com
Windy City RC raceway and hobby's
tazfam2 is offline   Reply With Quote
Old 02-25-2013, 07:08 PM   #11271
Trader Rating: 37 (100%+)
Originally Posted by duckman996 View Post
I need some help...
I have a Speed Passion GT Pro Stock ESC and a SP Multi ESC program card, however, the program card has the Hobbywing V3 software on the card and I do not know how to change it back to Speed Passion?
What would the latest blinky software that I can use on this speed controller be?
Thanks. I did a search on this thread and I could not find an answer.
You cannot revert to an older version of SP software if it has a newer version of HW software. The card won't accept that change.
Originally Posted by coretex View Post
I tried some friends SpeedPassion Program card but it did not work. Probably the wrong version or something.. I guess I have to buy a Reventon Series Smart LED Program Card.
I have trouble finding this product on the web: Speed Passion Product code SP000007. Do anybody know of a store that has this in stock?
You need the blue Reventon cards for Reventon ESCs.
Thanks, Terry
The Bluetooth module rocks. I don't keep it mounted, but it's easier to use than lugging a laptop to the track if firmware changes are needed.
Nexus is offline   Reply With Quote
Old 02-25-2013, 08:13 PM   #11272
I need some help...
Since it appears I'm screwed and can't go back to SP software. Anyone know what HW V3 software works on the GT Prostock in Blinky?
duckman996 is offline   Reply With Quote
Old 02-26-2013, 07:49 AM   #11273
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Could you downgrade the HW V3 software to an earlier version of the HW software then swap to SP software?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 02-26-2013, 01:33 PM   #11274
Trader Rating: 16 (100%+)
Does your card READ your ESC...? If your card can read the ESC setting and you can do all the adjustment with it....don't bother to convert it, just use it...
Old 02-26-2013, 04:16 PM   #11275
Originally Posted by darnold View Post
You might try 20% Drag Brake and 10% Initial Brake; from there I would adjust the brakes on your Tx to your taste. You will probably wind up turning down your Tx brake setting from 100 to something like 60-80 if you have a good blue groove. Please let us know if this helps.
Thank you. I ran my new Reventon Pro in Mod EDM at the February Freeze last weekend with a Trinity duo2 7.5. Had no issues other than some fine tuning and finished 3rd. Love my SP stuff so far.
Rob2 is offline   Reply With Quote
Old 02-26-2013, 07:03 PM   #11276
Andy w's Avatar
So I am a little dumbfounded on a Reventon R in a 1s application.
I have used my Reventon R in my oval car with a 13.5 1s. I used it with a LiFe rx pack and a Novak Smartboost. I had it in this setup for over a month. If this isn't possible how did it work. Now I have a LRP SSX in the oval and the the Reventon is in my TC.
It worked fine in both 1s and 2s for me.
Andy w is offline   Reply With Quote
Old 02-26-2013, 07:13 PM   #11277
NutDriver's Avatar
Trader Rating: 19 (100%+)
Sorry for a partial thread hijack. Any word on the Speed Passion Audi R18 body? REALLY looking forward to getting this body.
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 02-28-2013, 01:24 PM   #11278
Anyone know what the actual KV rating of the 10.5t MMM motor is? Can't seem to find the info anywhere.
Chamelion is offline   Reply With Quote
Old 02-28-2013, 01:31 PM   #11279
Trader Rating: 14 (100%+)
4000kv
http://www.amainhobbies.com/product_...ess-Motor-105R
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 02-28-2013, 02:57 PM   #11280
coretex's Avatar
So I finally got hold of a SP000007 LED program card.
I now am trying to find out why I cannot change to a program where i can do reverse. I can't find any Mod0 firmware etc. Have I bought the wrong card?
coretex is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
