Old 11-17-2009, 07:49 AM   #1111
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by nnick View Post
Maybe it's silly question, but where can we get newer software?
is it from here?
Yes...that is the one, download that blue little arrow box and install the software, then choose your software within the program that you are planning to use on your vehicle.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-17-2009, 09:29 AM   #1112
Trader Rating: 15 (100%+)
Send a message via AIM to DJGonzo69
Thanks Guys!
So Ultralinehobbies even though it's showing on their site probably don't have it then.
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 11-17-2009, 11:45 AM   #1113
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
Originally Posted by abailey21 View Post
Good answer.... lolI <3 U DC
I love you to sweet britches
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 11-17-2009, 11:46 AM   #1114
abailey21's Avatar
Trader Rating: 35 (100%+)
Originally Posted by DJGonzo69 View Post
Thanks Guys!
Not yet, his will ship early next week like everyone else
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 11-17-2009, 12:30 PM   #1115
Tech Legend
Cain's Avatar
Trader Rating: 211 (100%+)
can someone tell me the primary differences between the GT 1.1 EsCs and the newer 2.0 escs?
< Team Associated RC10B6D x 2>
< Tekno SCT410.3 x 2>
< Durango DEX410V5>
Old 11-17-2009, 01:27 PM   #1116
Solara's Avatar
Performance is a hugh jump from 1.1 to 2.0
Then the 2.0 has mutliple software to choose from, especailly running stock class...version 1.1 is not update/upgradable.
Old 11-17-2009, 02:40 PM   #1117
Tech Legend
Cain's Avatar
thanks for the info. I guess I will stick with 2.0's then.
Just need to see what is going on here with the new silver arrow 2.0 esc's for 1/8.
< Durango DEX410V5>
Old 11-17-2009, 05:40 PM   #1118
irgo's Avatar
Default Speedpassion GTv1 vs Speedpassion GTv2
correction Speedpassion version 1.0 is the one that is not update/upgradable,
but Speedpassion version 1.1 is update/upgradable.
Speedpassion GT2.0 Got Lot's more Power abilities Inside compare to GT1.xx.
The Huge Problem is Speedpassion version 1.xx can use Brushed Motor
but Speedpassion 2.0 cannot use Brushed Motor.
Quark Force
irgo is offline   Reply With Quote
Old 11-17-2009, 08:07 PM   #1119
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
guys how would I know when lipo-cutoff is kicking in ?
I have a trakpower 5400 gold lipo battery and a trakpower 5000 dark series lipo which is brand new
I feel a power loss after 20 minutes or more of running then I STOP but then what if I kept going after that power loss. by power loss I mean im drifting and then the motor just slows down and I know its lipo cut off
kriiiss is offline   Reply With Quote
Old 11-17-2009, 11:38 PM   #1120
Ryan Maker's Avatar
Send a message via MSN to Ryan Maker
If you are running for that long and experiencing power drop off towards the end of your run, that is just the battery dyeing. Li-Po cut off stops the car completely and doesn't allow any power to your ESC/Motor. Hence, your car will stop, dead.
If your ESC is not cutting off like this before the battery is dyeing, you should probably think about increasing the Value of the Li-Po Cutoff on your ESC. The battery should only have a slightly noticeable drop in performance until the Li-Po cutoff kicks in. I run 2.8v Per Cell on the GT 2.0 Pro.
Hope this helps,
Ryan.
Awesomatix - Muchmore - Silverback - Roche - Radtec - LeeSpeed - Protoform - Futaba - Hiro Seiko - SG PitDesign
RC MAKER - www.rcmaker.com.au
Ryan Maker is offline   Reply With Quote
Old 11-17-2009, 11:46 PM   #1121
Someone who has speed passion logo in pdf type, illustration tens, jpg?
Please if there is a little more flavor?
Zooberg is offline   Reply With Quote
Old 11-17-2009, 11:52 PM   #1122
Ryan Maker's Avatar
Is this what you're after?
Ryan.
Old 11-18-2009, 02:20 AM   #1123
Ryan.
Yes.. have any bigger
Old 11-18-2009, 02:42 AM   #1124
Redwood's Avatar
I might be wrong, but I think I read before that the SP2.0 has a 'soft' Lipo cutoff, meaning that the car does not shut down completely, but slows to a crawl so that you can bring your car in, safer than a shut down on the straight.
Perhaps this is what you experience, however I may be wrong.
Regards
Neal
Redwood is offline   Reply With Quote
Old 11-18-2009, 05:34 AM   #1125
razzor's Avatar
Thats correct the lipo cutoff doesnt cut off completely like the older versions but now makes the car slows down a lot but still mobile.
If you hitting the cutoff drifting after 20 mins then id suggest you look at the settings and the setup on the car for any hassles.
I can drift for 50 - 60 mins with a Thunderpower 40c 5000mah and a 11.5 brushless motor with a 13mm rotor.
I run with the cutoff at 3.2v.
You also notice a drop off in performance when the battery is in the 3.4 - 3.6v region.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
