Like Tree3Likes
Old 02-15-2013, 05:03 PM   #11221
which one is better GT2.0 Pro Brushless ESC or the reventon pro? still confuse what esc should i get
canon is offline   Reply With Quote
Old 02-15-2013, 06:01 PM   #11222
Get a GT2.1 or a Hobbywing V3. The Reventon Pro is crap!
RSCosworth is offline   Reply With Quote
Old 02-16-2013, 12:50 AM   #11223
Hi RSCosworth,
Can you please tell us why you think the Pro is crap ?
I`ve read alot of negative comments about the HW V3 also.
Running HW V2.1`s and HW V3.0`s and think my V2.1`s are the best esc`s I`ve used. Almost the same as the SP GT 2.0
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Old 02-16-2013, 05:34 AM   #11224
really there are kids that read this idiot
lol i have run all three and many others, these are the 3 i would run and are all good but i am running a reventon pro at the mo and loving it and i am one of the quickest down the straight in my class but i wouldnt get a gt pro2.0 or hw2.1 as they are last gen esc and now have no nw software coming out for them.
you will hear the 2-3 ppl the say they r c*&p or have no brakes but i know lots of ppl that never had problems and love how fast and smooth they r and poor brakes is ppl using rubbish low torque motors ~(non brca)or even setup
but not saying ppl that have had esc blow on them for no reason aren't just is wording their worries
its a great esc and has less problems then other esc brands i know of and used, i have seen novak tekin nosram/lrp sp hobbywing gm orion orca all fail at my clubs, non user faults so as i said you will always get 2-3 on forums rubbishin a brand
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 02-16-2013, 06:28 AM   #11225
Just changed my reventon to a lrp flow. Yes the reventon was fast down the straight. But I never found the punch others guy had. Not were the brakes much good... Also after 2 minutes it would start to fade despite not being hot at the end of the run. Flow is 100% better for me so far.
Mi4cxl is offline   Reply With Quote
Old 02-16-2013, 07:08 AM   #11226
Trader Rating: 36 (100%+)
The Reventon Pro is the newest highend Speed Passion ESC> The GT 2.0 Pro is great, but will not be receiving any future software updates.
Nexus is offline   Reply With Quote
Old 02-16-2013, 10:15 AM   #11227
I just buy speed passion reventon pro.....with 10.5 competion motor.. I use it on trf 416 x any can help me with setup and gear setup for this esc...
ipanmina is offline   Reply With Quote
Old 02-16-2013, 12:09 PM   #11228
Speed passion reventon pro and muchmore fleta 4 same esc?
How is that esc in 17.5 boost stock?
Zooberg is offline   Reply With Quote
Old 02-16-2013, 01:53 PM   #11229
yes both are the same, can't answer for how it's in boosted since i haven't run mine yet and will be running in blinky class..sorry
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 02-17-2013, 10:14 AM   #11230
Today i've changed my motortiming and suddenly my cirtix stock club ESC/motor doesn't function normal anymore.
I need to rotate the rotor by hand first en when i hit the throttle on my transmitter the motor makes a strange noise and isn't able to turn at full speed and also my fan stops working.
When i go back to neutral position on my transmitter the fan starts to work again.
I've checked the motor with another ESC and the motor still works as it should be.
Even the ESC smells like it's burned up, normally when you need to setup the esc you will hear some beeps everytime you set the neutral, max brake and full throttle.
When i'm doing the setup i hear 1 click for neutral,2 clicks for full throttle and 3 clicks for max brake in my motor and not a beep of the ESC itself.
What could be wrong with the esc.
I'm 200% sure i haven't done anything wrong but the ESC doesn't function as it should be.
addicted2blue is offline   Reply With Quote
Old 02-17-2013, 03:18 PM   #11231
Well. had my maiden trip with my Reventon Pro today. I must say i was very nervous how it it would would turn out. Because of all of this talk about how crap it was and no brakes and etc..bla bla.
Well that is just total bullshit in my eyes It had all the brakes i needed(Locked wheel's if i wanted) super smooth power delivery, and all the punch i need out of corners
All i needed to do setup wise was to add more drag brake and reduce the break since it was locking all wheels. all in all very very happy with the first outing
Equipment used:Serpent S411,SP Reventon Pro,Express Motorsport (Trinity D3.5) 13.5"Zapper" and Intellect 7200 70 bat Blinky class. Awesome Combination and Fastest down the straight. Everyone thought i used Boost
*Sanwa M12*Hitec*
Old 02-17-2013, 06:21 PM   #11232
Bad contact of sensor cable or overload motor timing could make this happen. In this case, your esc is no function on motor channel "A, B or C". Therefore, it will be no beep sound when you do the calibration. If your ESC is within warranty, contact SP Customer Service for further support (RMA).
WMGary is offline   Reply With Quote
Old 02-17-2013, 06:26 PM   #11233
I posted last week that i had no brakes using the reventon pro with my trinity 13.5 motor and suspected that it would work better if i used a speed passion motor. Looks like that was the case. I paired the reventon with a MMM 13.5 and had pretty good stopping power. the two appear to be a good combination. If anyone cares
DOTMAN is offline   Reply With Quote
Old 02-17-2013, 06:58 PM   #11234
Andy w's Avatar
I have a Reventon R with stock0 firmware installed. Everything works fine as far as the esc but I can't make adjustments with the program box. It recognizes it and can go through the menu but when I want to change the value and press ok hash marks show on the box and it freezes. The change does not get saved.
I have tried a different box and it does the same thing. Any ideas?
Andy w is offline   Reply With Quote
Old 02-17-2013, 08:04 PM   #11235
mtbboy's Avatar
Can I run a reventon r in 1s mode?
If so how.
D.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
