Like Tree8Likes
Old 02-11-2013, 12:33 PM   #11206
Fuzzi0n's Avatar
Originally Posted by performula View Post
Wow, I only read the last two pages of this forum and now I'm wondering if I should not have ordered my 8.5T v3 Combo Set lol.
Does the ESC/Motor come with all the necessary bullets for all connections? I know I'll have to solder some stuff up but didn't know if I needed to order bullet connectors.
You'll need connectors for the battery, I personally direct solder the motor, if you don't want to you'll need connectors for that too.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 02-11-2013, 12:49 PM   #11207
slakr's Avatar
Trader Rating: 28 (100%+)
The motors come with the SP connectors that fit the "bullets" on the SP motor endbell.
The motor also includes the sensor cable.
The ESC includes the cable to go to your receiver.
YOU WILL NEED THE CONNECTOR(S) TO GO FROM THE ESC TO THE BATTERY!
JQ THECar & THEeCar Black~Mugen MBX7TR Eco~TLR 22 3.0SR,22-4 2.0~XRAY XB2C
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 02-11-2013, 12:57 PM   #11208
Originally Posted by DOTMAN View Post
Are they all mod motors?
No stock1 13.5 and 17.5 there is one on there for a 4.5 but no idea what it is set too hope it helps
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 02-11-2013, 02:06 PM   #11209
performula's Avatar
Fuzzion and slakr,
So I only need to purchase one set of 4.0 banana plug/bullets in order to complete all of the wiring?
Battery->ESC->Motor
performula is offline   Reply With Quote
Old 02-11-2013, 02:45 PM   #11210
slakr's Avatar
Fuzzion and slakr,
Battery->ESC->Motor
Correct
AE TC7.1
Old 02-11-2013, 02:59 PM   #11211
Fuzzi0n's Avatar
Fuzzion and slakr,
Battery->ESC->Motor
That should be all you need, not sure if your motor will come with anything other than a sensor cable though, that's what my 8.5 combo came with. slakr mentioned that they motors come with connectors, but my ones didn't. Not an issue for me as I don't use connectors on the motor.
Old 02-11-2013, 03:18 PM   #11212
slakr's Avatar
HMMMM... mine came with these http://www.speedpassion.net/us/produ...p=162820&c=OPT
But I purchased two Reventon Pro ESC's and two 8.5R Competition V3.0 motors and they had the connectors, but they were not the "combo" packages.
AE TC7.1
Old 02-11-2013, 03:56 PM   #11213
performula's Avatar
OK, well it's all purchased. Just have to wait for everything.
Old 02-11-2013, 04:02 PM   #11214
performula's Avatar
So were the complaints of a bad batch of manufacturing defects, software, etc.? Just curious to what went on.
Old 02-11-2013, 05:58 PM   #11215
trytowin's Avatar
Whats the part number for a 12.5mm high torque/power rotor for a 17.5 MMM motor ? Thanks
I'm just here to discharge my battery.
trytowin is offline   Reply With Quote
Old 02-11-2013, 06:00 PM   #11216
Does anyone have a setup for the Reventon Pro that will give a brushed motor feel? I'm racing dirt oval and just looking for a little help setting my speedo. I've always ran LRP's and would like the same feel. Any help would be appreciated.
Rob2 is offline   Reply With Quote
Old 02-13-2013, 09:36 AM   #11217
Today i received my cirtix stock ESC, but i saw that you can only adjust 3 settings in the ESC (ABS, drag brake and overheat protection).
Is this correct for blinky?
Or is it possible to upgrade the setting card/ESC for more settings such as lipo cut-off, start punch etc.
addicted2blue is offline   Reply With Quote
Old 02-13-2013, 11:34 AM   #11218
izzyracer's Avatar
Trader Rating: 27 (100%+)
You must have an LED program card to make changes and if you have the club spec you can only make changes to those three. Please someone correct me if I'm wrong.
http://www.speedpassion.net/uploadfi...ay27th2010.pdf
Izzy
izzyracer is offline   Reply With Quote
Old 02-15-2013, 09:46 AM   #11219
gndprx's Avatar
Trader Rating: 18 (100%+)
I have a Reventon R that will be paired with a Tekin Redline 17.5 motor in my TC4. We run open timing so no limitations.
What would be a good starting profile to work with for a generally small track with one top speed back stretch. Concrete surface that is typically medium grip.
Carl Fisher
Team Xtreme RC
The Grove Racing Center
gndprx is offline   Reply With Quote
Old 02-15-2013, 09:47 AM   #11220
gndprx's Avatar
Double post. Sorry.
Carl Fisher
Team Xtreme RC
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
