Old 02-10-2013, 08:35 AM   #11191
shamar's Avatar
I have been running reventon from the start also and was running the tekin rs pro and i haven't had any problems with it. Since I switch bands i'm faster than the other guys that use tekins. The reventon pro is the smoothest esc I have own and use to dis date, I run 13.5 motor on a large on road track with nitro car and i'm just as fast or faster..........
shamar is offline   Reply With Quote
Old 02-11-2013, 10:09 AM   #11192
I'm having trouble with brakes on the reventon pro. i use the speedo with a revtech 13.5 and i have almost no brakes even though they are set to 100%. i have to crank drag brake up to 40% to get the car to stop.
Any suggestions?
DOTMAN is offline   Reply With Quote
Old 02-11-2013, 11:09 AM   #11193
Any suggestions?
hi have u tried 90-80% as you might be locking up the wheels ? i had to do this at my track and though it was poor brakes, also some motors if they r rev-y dont have alot of brakes never tried a rev tech? but i know gm and x12 have great brakes
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 02-11-2013, 11:23 AM   #11194
LOL...locked brakes. That's funny. Actually I've had this problem with the SP v2 pro and also the hobbywing. Really weak brakes. they seem to work a lot better in mod. I'm going to try a SP motor with the reventon to see if it's any better using it's own motor
Old 02-11-2013, 11:45 AM   #11195
roger999's Avatar
Yes he's right, locked brakes. Try to start with 50% brakes on reventon, this speedo seriously has great breaking system. I tried to use first 100%, after 80% and the good way on my track is 55% at the moment.
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 02-11-2013, 11:52 AM   #11196
I have also owned the gt pro 2 then hobby wing v3 gm120 orca nosram and now reventons (back to speedpassion as they r the smoothest and just as fast and any other esc) And i learnt this when i got gt pro when it first came out
all or nothing
Old 02-11-2013, 11:59 AM   #11197
Thank for the help but they brakes aren't close to locking. they aren't grabbing at all. I should mention, this is when i try to brake hard at the end of a high speed section. i badly overshoot the turn because i get practically "NO" brakes. Brakes work ok at short shoots and low speed sections
Old 02-11-2013, 12:04 PM   #11198
Also just checked the sp website the last four post are all set to 60-70% brakes apart from one 30% lol locked brakes
all or nothing
Old 02-11-2013, 12:24 PM   #11199
Are they all mod motors?
Old 02-11-2013, 12:29 PM   #11200
mxgregg's Avatar
Trader Rating: 32 (100%+)
I just bought a renventon R for my new TCXX. Sounds like mixed feelings on how these work?
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 02-11-2013, 12:32 PM   #11201
my reventon is very smooth and the software updates are easy and the interface is nice. I just have trouble with brakes using stock motors
Old 02-11-2013, 12:43 PM   #11202
mxgregg's Avatar
I'll be running a 8.5.
Old 02-11-2013, 12:49 PM   #11203
if the "R" can handle an 8.5...you'll probably be ok.
I wonder if the problem with stock is because we normally run stock motors with the timing advanced quite a bit. When I run mod, i don't advance the timing at all
Old 02-11-2013, 01:10 PM   #11204
mxgregg's Avatar
Suppose to handle a 5.5.
Old 02-11-2013, 01:27 PM   #11205
performula's Avatar
Wow, I only read the last two pages of this forum and now I'm wondering if I should not have ordered my 8.5T v3 Combo Set lol.
Does the ESC/Motor come with all the necessary bullets for all connections? I know I'll have to solder some stuff up but didn't know if I needed to order bullet connectors.
performula is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
