Like Tree8Likes
Old 01-13-2013, 03:17 AM   #10981
quickershifter's Avatar
I just bought a new SP Ver.3 motor 17.5T, hooked it up to my SP Rev Pro but no throttle (motor not turning). Try to calibrate the ESC after firmware v22 updated, no beep sound in the ESC, but the orange led blinks. I can feel the motor staggering but no turns. Any advice on this?
quickershifter is offline   Reply With Quote
Old 01-13-2013, 05:45 AM   #10982
Airflow's Avatar
I've been running a novak high rev 10.5 ballistic motor the whole day like 5 packs on my Reventon R with boost. No shut down whatsoever.
Airflow is offline   Reply With Quote
Old 01-13-2013, 06:06 AM   #10983
Airflow's Avatar
Hi solara, do I need to upgrade my Reventon R firmware to the one you posted? I'm using stoc01
What's the benefit of upgrading to this new firmware anyway?
Old 01-13-2013, 12:56 PM   #10984
Airflow the v 20 stock1 firmware is only for the pro at the moment not sure if its being release for the r but the new firmware is meant to help mid power
If any of the sp boys could tell us about if the r gets the shock1 v20 ?
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 01-13-2013, 01:06 PM   #10985
ChrisNRG's Avatar
Will the Reventon Sock Club work with a Trinity Revtech 17.5t or D3.5 17.5t motor?
ChrisNRG is offline   Reply With Quote
Old 01-13-2013, 02:17 PM   #10986
Well, the new program for the pro has definatley sorted out the mid range problems. However, the brakes have now become too soft so, well done but please keep at it.
RSCosworth is offline   Reply With Quote
Old 01-13-2013, 06:16 PM   #10987
BigC123's Avatar
Well got my replacement Reveton Pro in and noticed that it looks like they tightened the case to hard because , it is cracked around the screws, is there a way I can order a new bottom for the ESC, I sure don't want to send it back, I just waited two weeks for this one. Any suggestions anyone?
Clayton "BigC" Neal
Caster Racing USA
SpecR R1
XRAY T3R
Speed Passion USA
BigC123 is offline   Reply With Quote
Old 01-13-2013, 06:31 PM   #10988
Try to change the sensor cable.
WMGary is offline   Reply With Quote
Old 01-13-2013, 06:48 PM   #10989
Originally Posted by Solara View Post
Did I answered your PM...? If not...I did not receive your PM, please send again...
I just resend my pm...thanks!
X men is offline   Reply With Quote
Old 01-13-2013, 06:56 PM   #10990
Airflow's Avatar
Thanks for the info man. I wont be upgrading after all.
Old 01-13-2013, 07:24 PM   #10991
If you are using Stock1 V20, set initial brake force to 30-50%.
Old 01-13-2013, 09:04 PM   #10992
Trader Rating: 24 (100%+)
Originally Posted by PitNamedGordie View Post
I had the same issue on my first run with the Pro. The default brake setting is set at 30%. You are going to have up this to feel the brakes...
Thank you~!
JoeyE is offline   Reply With Quote
Old 01-14-2013, 04:40 AM   #10993
WMGary, I have try using another sensor cable, but still no turn on my motor. Do I have to change the capacitor? Or should I send it back and claim for warranty? But how?
Old 01-14-2013, 08:34 AM   #10994
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
Selling my 2 raceday old reventon pro. Pm me if interested.
jeff jenkins is online now   Reply With Quote
Old 01-14-2013, 07:29 PM   #10995
Send it back. You can contact USA support firstly.
Email: usa@kinggoldenltd.com
RMA
http://www.speedpassion.net/us/rma_form.asp
"Login requested"
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
