Like Tree46Likes
Old 01-05-2013, 01:02 PM   #10951
Trader Rating: 27 (100%+)
Loaded Stock 0 software into my Reventon Pro. Everything is cool except i have no brakes. I tried setting it on my radio but nothing. Is there something i can set on the Reventon program through my computer?
JoeyE is offline   Reply With Quote
Old 01-05-2013, 01:51 PM   #10952
Originally Posted by Nexus View Post
Reventon programming cards cannot be used with GT 2.0 Pros or other non-Reventon ESCs.
Can anyone point me to the right programming box that connects to the pc? Didn't see it on the sp website.
slater333 is offline   Reply With Quote
Old 01-06-2013, 03:40 AM   #10953
roger999's Avatar
Default Reventon R + Thunder Power 10.5
Anyone using TP motor with Reventon R speedo? Im thinking now to get a new motor and not so sure if get just SP MMM 10.5 or ThunderPower 10.5? Dont want to have any issue due to using two different brands thats why asking? Thanks.
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 01-06-2013, 05:32 AM   #10954
Bishop's Avatar
My Thunder Power motor seemed to work just fine with my Reventon Pro.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 01-06-2013, 03:26 PM   #10955
mtbboy's Avatar
Setup for reventon R
17.5 Boosted
Fdr
Speedo settings
Motor timing
90x36 tight
D.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 01-06-2013, 05:21 PM   #10956
Default Help!!!!
I have the Reventon Pro and Reedy Sonic 17.5. I have everything hookup but am getting no power to the motor. Wires are connected fine. I calibrated according to instructions but nothing when I pull the throttle. I thought it might be the motor so I connected the Reventon to my speedPassion motor and still nothing. The LEDs are not blinking or anything. They both just stay lit - red and orange.
I put my Orion speedo back on and everything works perfectly fine.
Can someone give me some direction - maybe something I should check???
Thanks.
bdortch is offline   Reply With Quote
Old 01-06-2013, 05:24 PM   #10957
Trader Rating: 37 (100%+)
Thanks.
What radio are you using? Might need to.reverse the throttle.
Nexus is offline   Reply With Quote
Old 01-06-2013, 07:55 PM   #10958
You need a LCD Professional Program Card for GT2.0 series. Part number is "SPLCD01".
PC software: "Speed Passion USB Interface software V1.38 and software"
this software does not work with Reventon.
WMGary is offline   Reply With Quote
Old 01-07-2013, 12:36 PM   #10959
rimracker's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Solara View Post
Several 17.5 boost setup are on the SPEED PASSION website...
http://www.speedpassion.net/us/escsetup.asp
Solara PM
rimracker is offline   Reply With Quote
Old 01-08-2013, 07:19 AM   #10960
Solara, please check pm...Thanks!!
X men is offline   Reply With Quote
Old 01-08-2013, 11:25 AM   #10961
I'm using the KO Euros.
Are you suggesting to reverse the throttle and then calibrate?.
Old 01-08-2013, 11:32 AM   #10962
Correct. With some radios you need to reverse the throttle then re-calibrate with the ESC.
Old 01-08-2013, 12:03 PM   #10963
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-10-2013, 09:18 AM   #10964
shamar's Avatar
HI guy
I did some testing on sunday on a large flow 1/10 nitro track, kinda high traction and had great fun.. Have a race at the end of the month and it going to be 10 mins long with one stop and go. Its going to be an electric vs nitro should be fun trying to out run most of the nitro car with a 13.5 motor... Soon goin to 10.5 MMM motor
Hey are my setting
Neutral range - 4
Over heat protection - on
DRRS -5..... car is eazier to drive
Start RPM -5000
Hybrid Boost Active - 50%- 60%.... I found my car is faster and smoother on power
Hybrid Boost Max RPM -150k
Turbo Delay - 0.2 sec
Brakes - 60% using the 3300uf High Power Capacitor brakes is much stronger
Drag brakes- 10%
FDR - 5.0 with better with a lower boost setting
lipos- EAmotorsports 5000 70c lipos
Car - xray t3 2011
Esc - Reventon Pro
Motor - 13.5 MMM motors with timing at the lowest
Esc temp - 130-150f with out fan after 10mins
here is the track i will be running
http://youtu.be/SslO5Qmo8RY
shamar is offline   Reply With Quote
Old 01-11-2013, 08:34 AM   #10965
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I had the same issue on my first run with the Pro. The default brake setting is set at 30%. You are going to have up this to feel the brakes...
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
