Like Tree32Likes
Old 12-04-2012, 01:29 PM   #10831
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Cain View Post
Solara: any estimate on when the 12.5 Super 7 rotors will be in stock? Will you make a version of the MMM with the 12.5 motor out of the box?
Rotor should be around X'mas time.....there will not be a motor came with a 12.5 super 7 rotor...the market is not there, we will leave that as the option parts.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-04-2012, 06:56 PM   #10832
TAMAK's Avatar
Trader Rating: 28 (100%+)
Reventon R installed! Waiting on a few more peices: Life pack and hobbyking booster for testing. I will post back with the results.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 12-05-2012, 05:21 AM   #10833
Originally Posted by ysyracing View Post
Hello,
How many internal timing degrees have each motors?
1C105V3 Competition V3.0 1 Cell Motor - 10.5R
138105V3 Competition V3.0 Brushless Motor - 10.5R
SP000037 1/10 Competition MMM series 10.5R Brushless Motor
Regards,
JoseLu
Originally Posted by Solara View Post
I think your question should be asking about the BUILT IN TIMING from these motor...all of the SP motor are running abotu 12-15* built in timing...plus the sensor board timing goes from 0-50. Plus your ESC software if you are running timing software.
Hello,
Thanks for your reply.
I would like that you confirm the information.
If I add the internal and external timing I will have the following timing, per motors with their original unit sensor.
1C105V3 Competition V3.0 1 Cell Motor - 10.5R. 12-15║ minimum and 22-25║ maximun.
138105V3 Competition V3.0 Brushless Motor - 10.5R. 12-15║ minimum and 22-25║ maximun.
SP000037 1/10 Competition MMM series 10.5R Brushless Motor. 23-26║ minimum and 32-35║ maximun.
Is that correct? Thanks.
Regards,
JoseLu
You are going to hurt your brain....can you simply tell us what you are running and I think we can all help you to pick the right board and setting for your motor...
Don't forget, you have to work with the gearing...and rollout.
Hello,
I explain you. I'm writing the rules of a championship 1/10 Electric Touring Stock in Spain.
The first rule is. Any person could use any motor brand.
The second rule is. The addition the internal and external timing is 35║ or 36║.
The second rule, I think isn┤t the best rule for this category, but I haven't the commisary neither the technical necessary tools.
Please, Could you answer me previous question? Thanks.
Regards,
JoseLu
ysyracing is offline   Reply With Quote
Old 12-05-2012, 07:22 AM   #10834
Solara's Avatar
Hello,
Regards,
JoseLu
yes...your calculation is correct.
Old 12-05-2012, 08:09 AM   #10835
Solara's Avatar
New update for REVENTON ESC....there are no new firmware within but all the frimware were added the "upload protection" feature that it will provide a perfect upload without demaging the ESC internal software. That means it should not have anymore 99% upload and crashed....for those ESC that has software problem, this software should take care of it....give it a shot.
http://www.speedpassion.net/files/SP..._v1_1_0_21.zip
(1) Uninstall the REVENTON software via window's uninstall program
(2) Go to 'C:\Program Files\Speed Passion" and make sure to delete the folder SPEED PASSION.....(if the folder still exist there)
(3) Install the new program...
(4) Update the LCD card...without connecting the ESC. I see alot of people having trouble connecting the LCD firmware because they are connecting the ESC with the LCD while doing the card update, that will not work and will screw up the software.
(5) When updating the card (The new V2.6 version) then restart the computer and program and connect your REVENTON PRO with the LCD card (no fan connection and no LIPO please) and you should be able to do the firmware update...
Old 12-05-2012, 08:10 AM   #10836
Solara's Avatar
Attachment 1000460
Looking good...please do let me know the result, I have no luck to getting the REVENTON S, R and Stock Club Race to work with any booster and receiver pack that I know.....only REVENTON ESC that works with booster or receiver pack is the PRO. Pro circuting is different then the S, R and SCR.
Old 12-05-2012, 09:54 AM   #10837
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Had a buddy with the Reventon R crap out on him on his first track run.
It worked fine initial testing and setting everything up, then after he hooked it up, nothing throttle wise.
We could reconfigure the radio, etc. and get steering. Tried the throttle channel on the receiver with a servo, worked fine. Tried another motor, nothing. Motor worked fine on my GT 2.0 Pro. could reset the ESC to the Radio and it did its beeps ,etc. Just no throttle output.
He has the wireless module as well, pretty cool stuff.
Anyway, what else do you guys suggest he try before sending it in when you have no throttle response?
So the Reventon Pro can work with a TQ Booster or a receiver pack? what settings do you need to do to get it to work?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-05-2012, 10:35 AM   #10838
TAMAK's Avatar
I heard hobbyking booster and receiver pack works for sure, I also heard TQ booster does NOT work with Reventon Pro. I am just testing the Reventon R in my 1/12th scale and see what combination will work. I dont see why it wouldn't work with a Life pack unless the FET's and or drivers cannot run on a 1 cell lipo.
Old 12-05-2012, 05:47 PM   #10839
darnold's Avatar
Yep, TAMAK heard correctly. I was able to run the Reventon 2s Pro in 12th mod several weeks ago using both a Lipo rx pack AND a HobbyKing booster. The important thing is that mine would NOT power up when I removed the red power wire from the esc harness. I instead HAD to leave the esc harness in tack. When I used the rx pack I had to turn the esc off via the rx pack switch. When I used the HobbyKing booster I could turn the esc on AND off via the Reventon Pro's integrated power button. I decided to configure that speedo with the HobbyKing booster. Howard is still testing it on his 2s Reventon Pro.
Team Top Racing USA,Team MaClan ESC, Pro One Tires, Hot Race Tires
darnold is offline   Reply With Quote
Old 12-05-2012, 06:02 PM   #10840
TAMAK's Avatar
Thanks Dave! I confirmed tonight that a receiver pack will NOT work on the Reventon "R" with 1 cell lipo. I tried it with and w/o the red wire in the esc harness and no go. The only time it will worked in that configuration is with a 2 cell lipo. I also made sure the lipo cut off setting was disabled. But I feel if the esc will not operate with a lipo reciever pack, there is no way a booster is gonna make it better..
Old 12-05-2012, 10:21 PM   #10841
askbob's Avatar
Originally Posted by askbob View Post
What is the lowest turn motor the Revention S will be OK with in a 2wd buggy?
Any input?
askbob is offline   Reply With Quote
Old 12-06-2012, 07:23 AM   #10842
Solara's Avatar
Any input?
9.5T.
Old 12-06-2012, 09:06 PM   #10843
darnold's Avatar
Default Reventon on 1s operation
No problem. I'm not sure about the Reventon "R" since I've never run it but the Reventon Pro works. Of course this is with the MOD 1 software!!! Even the Reventon Pro will NOT work if you try to use the Hybrid Boost Software. My guess is that you either have to run Blinky or Mod but you can't run Boosted anything else on 1s at this time. Since I only run Mod then I'm not affected by the Hybrid Boost software not working on 1s yet. We'll get it sorted out soon for that software. For now, if you run 1s Mod (and I'm thinking Blinky should work also) using either a 2s Lipo Rx or HobbyKing booster with the Reventon Pro you should be fine.
Old 12-08-2012, 10:43 PM   #10844
quickershifter's Avatar
I having problem changing my setting using the LCD program card. I've updated the card to v2.6. Setting using PC is okay. But when I use the LCD it just displaying the 'Speed Passion Reventon' screen. Any thought on this matter?
quickershifter is offline   Reply With Quote
Old 12-10-2012, 09:02 AM   #10845
Solara's Avatar
See version 2.5 (downgrade) on your LCD would work or not...I will give that a try myself tonight.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
