Old 11-29-2012, 03:39 AM   #10786
Hello,
How many internal timing degrees have each motors?
1C105V3 Competition V3.0 1 Cell Motor - 10.5R
138105V3 Competition V3.0 Brushless Motor - 10.5R
SP000037 1/10 Competition MMM series 10.5R Brushless Motor
Regards,
JoseLu
ysyracing is offline   Reply With Quote
Old 11-29-2012, 08:20 AM   #10787
Trader Rating: 38 (100%+)
Originally Posted by ysyracing View Post
Hello,
Regards,
JoseLu
Out of the box the V3.0 and V3.0 1 cell have 0 to 10 degrees of timing available and the MMM has 10 to 20 degrees. Any will support from 0 to 50 by replacing the timing board with the appropriate one (which covers 0 to 10, 10 to 20, 20 to 30, 30 to 40 and 40 to 50 in the 5 different boards available.)
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 11-29-2012, 08:28 AM   #10788
Tech Legend
Cain's Avatar
Trader Rating: 211 (100%+)
timing boards on sale right now like everything else, not a bad time to get some.
< Team Associated RC10B6D x 2>
< Tekno SCT410.3 x 2>
< Durango DEX410V5>
Old 11-29-2012, 10:24 AM   #10789
Hello,
Regards,
JoseLu
Hello, thanks for your reply.
Are you sure?
I think that the 0 external timing corresponds to 12 of internal timing, but I am not sure.
Regards,
JoseLu
Old 11-29-2012, 11:28 AM   #10790
rimracker's Avatar
Trader Rating: 14 (100%+)
Originally Posted by joech View Post
Does the GT2 has DDRS in blinky mode?
Thanks.
I know the GT 2.1 prostock does.
rimracker is offline   Reply With Quote
Old 11-29-2012, 11:39 AM   #10791
Tech Legend
Cain's Avatar
Gt2.0 Pro does too
< Durango DEX410V5>
Old 11-29-2012, 08:35 PM   #10792
skypilot's Avatar
Are you sure?
Regards,
JoseLu
I believe you are correct, or at least that is what I was told also.
I know that the old SP motors that didn't have adjustable timing had 12 or 13* degrees built in timing,
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 11-30-2012, 01:57 AM   #10793
yes, with the stock board the V3's are adjustable between 0 to 10 degree, use option board to adjust it up to 50 degree.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 11-30-2012, 11:15 AM   #10794
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Akita View Post
Which is the fastest FW for the PRO with 5.5R SP ?
Everyone play with 4.5 boost , its a big track .
I have istall the latest stock with all max .
The mod is better ? Can i use hybrid boost at mod ?
Stock1 (boost/turbo) with 4.5....we have setup on our website for you to try. Use it...that is the fastest setup so far.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-30-2012, 11:17 AM   #10795
Solara's Avatar
Originally Posted by skypilot View Post
Thanks thats the info I was looking for. I thought there was a software for boost in mod. Or was that for the GT 2.0? Thanks again.
GT2 had a boost for mod software but it was a watered down version of boost...because we were worry about running boost with mod motor, if not handling correct, it will have a lot of burning motor....but after all these time of testing and running with the boost/stock version with MOD motor...everyone get a grib on it and no one run the boost mod version no more...
For Reventon, we just don't bother to make the boost mod version...everything for boost will be using STOCK1.
Old 11-30-2012, 11:17 AM   #10796
Solara's Avatar
Thanks.
Yes....on GT2.
Old 11-30-2012, 11:19 AM   #10797
Solara's Avatar
Hello,
Regards,
JoseLu
I think your question should be asking about the BUILT IN TIMING from these motor...all of the SP motor are running abotu 12-15* built in timing...plus the sensor board timing goes from 0-50. Plus your ESC software if you are running timing software.
Old 11-30-2012, 06:54 PM   #10798
Trader Rating: 1068 (100%+)
GT 2.0 pro question: Could a GT 2.0 Pro handle a 4 pole 4000kv motor of would I see a nice fire???
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 11-30-2012, 07:06 PM   #10799
Tech Legend
Cain's Avatar
Yes. That is the motor I use right now in an SC10 4x4 with that ESC.
< Durango DEX410V5>
Old 11-30-2012, 07:23 PM   #10800
What about in a heavier 4x4? SC10 is pretty light comparably to the SCTE I guess I should have mentioned chassis and weight? I thought it would be ok though.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
