Like Tree32Likes
Old 11-23-2012, 08:49 AM   #10741
I have to say mine is proving hard work to find that sweet spot between acceleration and top end... Can't keep up with another lad at the club with a team powers Speedo.
Mi4cxl is offline   Reply With Quote
Old 11-23-2012, 10:43 AM   #10742
roger999's Avatar
Was trying to update my Reventon R to stock1 v19 software but it stopped on 99%... I had to shut down SP software and now when i want to load it again on SP software says: no related file... is impossible to load stock again and any other... also impossible to send anything to speedo...
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 11-23-2012, 03:24 PM   #10743
Osiris 75's Avatar
Trader Rating: 17 (100%+)
So, I hooked up my reventon pro for the first time and everything works fine except when I pull on the throttle, nothing happens. It's a 4.5t motor. My friend who has the same set up used his esc with my motor and everything worked fine. We replaced all of the wires and tried it again with my esc and no response from the motor. Bought it 1 month ago and just opened it today and no go on the motor. Suggestions?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
CAPRICORN USA / REFLEX RACING
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 11-23-2012, 03:28 PM   #10744
Fuzzi0n's Avatar
Did you try reversing your throttle channel, then setting the ESC up again?
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 11-23-2012, 04:13 PM   #10745
Osiris 75's Avatar
Yes, I did that.
Chris Kemper
Old 11-23-2012, 04:26 PM   #10746
Default Reventon S?
How low of turn can this speedo handle? Was planning to use one in stock and open 17.5 and 13.5 on dirt ovals but was wondering if it would handle some mod racing. Tks
Rob2 is offline   Reply With Quote
Old 11-23-2012, 05:57 PM   #10747
Fuzzi0n's Avatar
Reventon S is 9.5T or slower. Might be worth getting the R instead if you plan to run mod.
Yes, I did that.
:/ Does he have a motor you can try? If so, give that a shot and see if it works, although I'd expect it wouldn't if your motor was fine on his ESC. Your motor isn't a Viper is it? They had issues with those, and you have to disconnect the temp sensor wire apparently. Otherwise, not sure what's wrong with it - might be worth contacting C/S directly.
Old 11-24-2012, 12:36 AM   #10748
roger999's Avatar
One more thing, until i dont touch trhe update firmware button all works fine i can change all settings on speedo etc. But when i push the update software button and no related file is instead of software update files all reventon interface is frozen and i cannot change settings anymore... what is going on? is that problem with speedo? or just need to erase all software on speedo and upload it again? But how?
Old 11-24-2012, 02:30 AM   #10749
knighthawk's Avatar
I had this issue with one of my two RevPro's, it was a Radio Calibration issue, took me three time to get it to set correctly before the esc rotated the motor !
Question, are the two lights on the ESC changing when you move the throttle, if so this may be your issue as was mine, once I got it to connect properly all now works fine !!
Many thanks to my back pocket for main sponsor !
TLR Losi 8ight 2.0 EU - Novarossi 4BTT
Schumacher SX3 - Speed Passion Reventon Pro - Speed Passion V3 6.5
Schumacher SV2 - Speed Passion Reventon Pro - Speed Passion V3 8.5
Radio - Futaba 3VCS 2.4Ghz - R603FS - FrSky TFR4
knighthawk is offline   Reply With Quote
Old 11-24-2012, 04:55 AM   #10750
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
Originally Posted by rosey1990 View Post
Using a Reedy Sonic 13.5, FDR 6.5, 24deg endbell timing, on a medium/large indoor carpet track. ESC settings:
DRRS: Level 8
Hybrid Boost Power: 90%
Hybrid Boost Max: 135K
Hybrid Boost Start RPM: 5000RPM
Hybrid Boost Delay: 0.1s
I'm running :
Drrs: level 9
Hybrid boost:100%
Boost max:150k (always max no matter what motor)
Hybrid start:4,000
Boost delay: 0.02s
I'm using a Speedpassion v3 13.5 with red sensor board in the middle
Fdr around a 5.75-6.25 depending on track size.
Don't know how these settings will work with reedy motor I only run sp motors
Old 11-24-2012, 04:57 AM   #10751
Super Moderator
Marcos.J's Avatar
If running mod I would get the pro
Old 11-24-2012, 03:48 PM   #10752
Post
Originally Posted by Solara View Post
For REVENTON R
(new)the latest Blinky ROAR legal software is STOCK0_V20
the latest BOOST/TURBO software is STOCK1_V19-58b7
the latest static timing only software (MOD1) is MOD1_V20-dfa7
There are no MOD2 for the REVENTON R yet.
Will there be MOD2 for the R?
Welshmerlin is offline   Reply With Quote
Old 11-24-2012, 04:45 PM   #10753
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Default Reventon LCD Card
I just picked up Speed Passion EX 1S speedo and was wondering if I could use the Reventon Pro LCD card as a dongle with the GT software or do I need to buy the older style LCD card?
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 11-25-2012, 02:00 AM   #10754
knighthawk's Avatar
on the SP website it states that the older LCD Card is not Compatible with the Reventon Series
http://www.speedpassion.net/eu/produ...=SPLCD01&c=OPT
With that said I Would assume the GT ESC's are not Compatible with the Reventon Cards
Old 11-25-2012, 07:20 AM   #10755
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
where did you find the ESC at?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
