Like Tree46Likes
Old 11-15-2012, 08:05 AM   #10681
Trader Rating: 38 (100%+)
I had a Pro that never worked correctly and an S with a manufacturing defect. The 3 R's are all good as well as the other S. So according to internet logic, 100% of pro's fail, 50% of S's and 0% of R's. Only kidding of course, I'll be sticking with them for quite a while as they provide a value that none of the OVERPRICED esc's do at this time.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 11-15-2012, 08:15 AM   #10682
Trader Rating: 8 (90%+)
Thumbs up
Originally Posted by Solara View Post
Word is...ROAR is about to approve the entire line of REVENTON series ESC for running the soon be release STOCK0 V20 software. It is still the same as the current Stock0 software except we have to have a VERSION # listed as this is the ROAR new rule....new update software should be out along with the new EOS winning off road software MOD2.
manuelargentina is offline   Reply With Quote
Old 11-15-2012, 12:02 PM   #10683
http://www.roarracing.com/?page_id=737
Awesomatix USA, AVID, Serpent USA / Desoto Racing, Team Scream, LRP, Psycho Cells Racing, Sweep Racing, T.Q. Wire, Hurricane Motorsports, Core Creations, Hobbytown USA of K.C., 2mm Design and ProLevel
BSYDOR is offline   Reply With Quote
Old 11-15-2012, 12:04 PM   #10684
Trader Rating: 37 (100%+)
Originally Posted by BSYDOR View Post
BAM Sydor was holding it up :P
Thanks for posting...Reventons ROAR approved now.
Nexus is offline   Reply With Quote
Old 11-16-2012, 02:59 AM   #10685
the catman's Avatar
Originally Posted by Penz316 View Post
Didn't see that in my manuel ...
So now my LCD Card is toast ?
I just try without the fan now and nothing happened ... the card light up and then ... nothing
What I do ?
Unfortunately Penz316 In your manual under Programming the ESC page 9
section 11.1 Connect the Speed Passion Smart Program Card to the reventon ESC.
Do not connect ESC with ESC fan and battery
taken straight from manual maybe it should have said with esc fan and battery connected
the catman is offline   Reply With Quote
Old 11-16-2012, 03:00 AM   #10686
the catman's Avatar
V20 out today Friday in Australia
Old 11-16-2012, 10:43 AM   #10687
i just checked, it is out here on the US web site also...
gdcopbdcop is offline   Reply With Quote
Old 11-16-2012, 01:19 PM   #10688
What now for me ? My LCD doesn't show nothing ...
Work when I plug it on my computer but doesn't work with the ESC/Battery
I cannot update the LCD with plugging on CPU too
Have you tried holding the reset button as you connect the USB cable to the LCD Unit? It should show "Firmware Update" you can then start the software on your PC and update the firmware again. I noticed you cannot navigate away from the update page or it freezes up. Just set it going and wait about 5 minutes without clicking on anything else or opening any other programs.
dvaid852456 is online now   Reply With Quote
Old 11-16-2012, 02:32 PM   #10689
YoDog's Avatar
Trader Rating: 26 (100%+)
Hi Guys,
Is the new software being released only compatible with the Revention products?
just wondering...
YoDog is offline   Reply With Quote
Old 11-16-2012, 02:47 PM   #10690
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
I'm using Windows 7 64-bit and had issues with updating the LCD firmware due to the software crashing. I went and switched the program properties to Windows XP SP3 compatibility and run as Administrator. After this, no issue with the software locking up during the LCD firmware update.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 11-16-2012, 03:22 PM   #10691
vr6cj's Avatar
Trader Rating: 124 (100%+)
Also remember that you have to install the drivers for the LCD programmer so your pc knows what it is to use it for the first time. The LCD drivers are in the folders you extracted in the zip v20 download. Just update the lcd drivers from the device manager and point it to the extracted folder to search for the update.
hope this helps
vr6cj is offline   Reply With Quote
Old 11-16-2012, 04:34 PM   #10692
Trader Rating: 3 (80%+)
Hello ? Is this thing on
Are you looking for a solution for the problem ?
Or just ignoring the problem hoping it will go away.
I have heard at least 3 other Reventon PRO's have the same problem as mine.
They shut themselves off. I have NEVER had this problem with any other ESC.
It is nice that some people are having good luck with theirs.
But it would be nice to have some support for those of us having problems.
I judge a company by how they treat their customers after the sale.
Not just how they treat you while taking your money.
76Trans Am is offline   Reply With Quote
Old 11-17-2012, 02:21 AM   #10693
I've just receive my Revetron PRO with SP 5.5T (combo) .
I have no idea about settings on this esc .
The track is asphalt and large and my car is the Tamiya trf417
I need a setup to start with and then i will see if i need more power or it' too much .
Akita is offline   Reply With Quote
Old 11-17-2012, 02:22 AM   #10694
Originally Posted by 76Trans Am View Post
Hi,
I received the Reventon pro and have it in the car. I raced the last 2 weekends and love the punch and braking power. However after a 5 min heat race when I stop the car. The ESC is turning itself off. I also had it shut itself off when I had crashed near the end of a heat and was waiting to be marshaled. I am running 21.5 Blinky. The lipo cut off is turned off as well as the temp cut off. I also added the fan to see if it would help but it does not.
Any ideas ? LMK Thank you.
If it happened after a crash as some other people have also mentioned I wonder if it is worth checking the internals of the ESC. Someone mentioned some dry solder joints on some of the latest speed controllers, it may be worth checking and touching up any suspect joints. I'm not sure of the construction of the Reventon Pro but some ESCs have dual layer boards, it may be worth also checking that everything is connected firmly inside.
Failing that I would contact your local distributor or Speed Passion directly and organise a replacement.
Hope this helps.
I've kept my GT Prostock just in case anything happens with the new Pro so I'll have something to use if it needs to go back. I had tons of trouble with a brand new ESC by another manufacturer last year. I really hope the pro doesn't suffer the same fate.
Mine is installed in my new TCXX but i'm yet to test it in anger. So far, baring some teething problems updating the LCD firmware on Windows 7 64 bit, everything seems great.
Old 11-17-2012, 02:32 AM   #10695
Smile
That is one HUGE track
When you connect the ESC to the PC and open the Reventon software, under settings, Hybrid Boost you have to select your motor type. Here it has recommended starting points for HB Active and HB Maximum.
I'd start with DRRS set to 7, RPM start at the highest, 9000 I think and boost delay 0.3. I would have said this was a good starting point but others may have better suggestions. Just remember to check motor temps whilst testing any new setup.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
