The Speed Passion Thread
Hi, I just buy a Reventon Pro and should receive it this week.
Sorry but I am concerned about the need to disconnect the fan when programming the ESC. Is it true that damage of this sort will occur if I leave the fan connected ?
What is the reason to have a separate regulator for the fan and not just feed it from the BEC ? Is it for future 1S application ?
Thanks !
Thanks !
Hi,
I received the Reventon pro and have it in the car. I raced the last 2 weekends and love the punch and braking power. However after a 5 min heat race when I stop the car. The ESC is turning itself off. I also had it shut itself off when I had crashed near the end of a heat and was waiting to be marshaled. I am running 21.5 Blinky. The lipo cut off is turned off as well as the temp cut off. I also added the fan to see if it would help but it does not.
Any ideas ? LMK Thank you.
R/C Tech Elite Member
So Speed Passion has impressed me with their hardware and now their customer service. I ordered another Stock Club Race ESC and after placing the order realized that I would like to have reverse. They were able to change my order before shipping. Top notch in my book. Most would have made the original order go through and then hassled me through the RMA process.
Word is...ROAR is about to approve the entire line of REVENTON series ESC for running the soon be release STOCK0 V20 software. It is still the same as the current Stock0 software except we have to have a VERSION # listed as this is the ROAR new rule....new update software should be out along with the new EOS winning off road software MOD2.
Thanks !
Thanks !
Also, do not connect your LIPO on your ESC when plugging in the LCD and computer, THAT...for sure, will damage your computer. And we are also working on that and try to eliminate that issue.
No...it won't damage anything, it just won't connect to the computer. Simply unplug it and it will connect to LCD or computer. We are actually working on re-working this issue and hopefully will never need to do that again.
Work when I plug it on my computer but doesn't work with the ESC/Battery
I cannot update the LCD with plugging on CPU too
Rich
quick question, i have an lpf 2.0 and pro stock 2.1 esc. the lpf 2.0 has the boost software installed. w/c one should i used on my main sedan and the other one for gt? w/c one has more power? thanks for the info:
Ok, Roar approval is great. But what good is an ESC that shuts itself off ? Any answer on this issue ?
I wish those who contact me and report the problem can explain to me what happened to them like what you just wrote here...very detail, and I am well aware of this case now. I will do that myself and see is that a software problem or not.
I believe I know a backend fix on this issue but I am not 100%, I need to try it tonight. I will get back to you tomorrow. Thanks for reporting this to me.
Anyone have a 17.5/13.5 blinky set up for the Reventon Pro?
Joey- I was going to test my ESC on my TC & F1 for Stock0 mode, but looks like Rain is in the forecast.
I have had 2 r's been in tc, buggy and sc with mortors from 17.5t down to 7.5t and never missed a beat only had to turn off lipo as I have old ones with low c rating
As for the software I had to fiddle with the USB files at first with the first ones but new ones work no problem and the wifi unit works great
