Like Tree46Likes
Old 11-06-2012, 06:10 AM   #10621
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Originally Posted by dan200487 View Post
hey guys ive got a reventon pro using in a f1 with a mmm 21.5 motor is there any good setup in the esc as the one im using doesnt seem to have much braking
Try adding brake via your Tx .
Or sounds like your diff needs to be tighter.
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 11-06-2012, 08:06 AM   #10622
Looking for a good starting point for reventon PRO and sp MMM 5.5t. Running indoor on carpent small/medium.
417X Speed Passion reventon PRO / Sp MMM 5.5T
himura is offline   Reply With Quote
Old 11-06-2012, 08:11 AM   #10623
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by himura View Post
Looking for a good starting point for reventon PRO and sp MMM 5.5t. Running indoor on carpent.
How long is the straight?technical? What software ?stock1boost or mod0? If you are running boost a 5.5 will be too much for a indoor track(if Is small indoor track) you may be better off with a 10.5 and some boost
Old 11-06-2012, 11:54 AM   #10624
Running v.19 stock software. Before i run a 4.5T and mod software but i was to aggressive and running a bit high in temp Esc/Motor. The track is medium in size. about 30meter straight. i have right now a FDR of 8.46.
Does anyone have marc.F last setup from ETS race?
my settings so far, and it works ok.
1:Forward/brake
2:cutoff 3.4v
3:heat 95c disabled
4:brake force 70%
5:dragbrake 10%
6:neut range 6%
7:drrs level 4
8:Hb active 50%
9:Hb maximum 110k
10:Hb start rpm 5000rpm
11:Hb delay 0s
Old 11-06-2012, 11:55 AM   #10625
roger999's Avatar
So what would you suggest to set for small indoor track, 10.5, not long straight, stock1boost? On hobbywing was using 64 timing with no turbo, ~9 drive ratio.
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 11-06-2012, 12:04 PM   #10626
Trader Rating: 16 (100%+)
Or I would use Mod1 with full timing and run 5.5 without boost and turbo....top driver run for small track. Boost is not necessary when running mod motor.
Old 11-06-2012, 12:10 PM   #10627
i will try that, thanks solara!
Old 11-06-2012, 12:43 PM   #10628
Yes, I am sure MOD1 with 5.5 is more then enough for your track. The beauty about MOD class is..you pick the motor that fits the track. You use boost ONLY when a 4.5 motor is still not FAST enough, mainly on a very large track. And using boost software is usually ONLY if you are limited to run slower motor but want to achieve the faster speed, for example, open stock class like running a spec 13.5 motor but with the mod speed....
If the track is small enough, you can actually get better lap time to run a 7.5 motor...play with the timing board on the motor as well.
Old 11-06-2012, 05:03 PM   #10629
vr6cj's Avatar
Trader Rating: 124 (100%+)
Originally Posted by vr6cj View Post
Hey Solara,
Find a fix or update that'll fix the setup button issue? SPCS wants me to rma it.
ttt
vr6cj is offline   Reply With Quote
Old 11-06-2012, 05:31 PM   #10630
Trader Rating: 17 (100%+)
Anyone have a Reventor R in orange they would sell. I had one in my cart from Speedpassion.net and then someone snaked out from me while I was browsing around.
429racer is offline   Reply With Quote
Old 11-07-2012, 11:45 AM   #10631
Xenolance's Avatar
Well, I was supposed to hear back about my warranty status yesterday on my Rev R in orange that died from the programming box. Not sure what happened there but if they refuse to fix mine you could swap cases with it at least :-)
I got the orange because it matches my Savox servos, now I've got a stupid hobbywing black ESC messing up the look of my car.
David Rose, Houston, TX.
Spec-R R1 / S1, Corally RDX.
"He's a Picasso with an Allen wrench." -Guffinator
Xenolance is offline   Reply With Quote
Old 11-07-2012, 05:25 PM   #10632
I bought an Xray T32012 and I have a Revetech motor that matches and I would like to keep it looking nice! The blue Reventon R would not be too bad and would match the blue on the motor, but if I switch motors then it will look out of place. I would buy it from you fixed, but not broken
Old 11-08-2012, 07:11 PM   #10633
Penz316's Avatar
Hi
I just want to be sure ...
I'm running 17.5t blinky ... so stock0 (v18) software
Can I run without the fan on the Reventon pro ?
Alex
Alex Fournier
Team Associated | Reedy | Team Scream Racing | Hyper Hobbies
Penz316 is offline   Reply With Quote
Old 11-08-2012, 07:12 PM   #10634
Penz316's Avatar
double post
Alex Fournier
Old 11-09-2012, 05:20 AM   #10635
Super Moderator
Marcos.J's Avatar
Originally Posted by Penz316 View Post
Hi
Alex
You can it never hurts to run one either
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
