Like Tree46Likes
Old 10-25-2012, 07:44 AM   #10441
Tunatsol's Avatar
Default v19
New v19 stock 1 is out on the SP site.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 10-25-2012, 09:21 AM   #10442
sosidge's Avatar
Would be nice to see some proper information about suggested settings (for 13.5), and what the settings REALLY do.
Old 10-25-2012, 09:25 AM   #10443
tazfam2's Avatar
Trader Rating: 40 (100%+)
Instead of waiting for settings, gear accordingly and experiment with settings and make sure you temp your motor regularly.
I have had mine with a 9.5 and I have played with different gearing and settings and have found what suits me the best according to my driving and have yet to get the motor over 130. Experiment but be careful and temp all the time until you are comfortable
Xray x1 17 Xray t4 2017
T4 2017 tekno 48.3. Associated B6 B64
Leisure Hours Hobbies and Raceway
Fiercesolutions.com
Windy City RC raceway and hobby's
tazfam2 is offline   Reply With Quote
Old 10-25-2012, 09:42 AM   #10444
Solara, please check pm
X men is offline   Reply With Quote
Old 10-25-2012, 10:01 AM   #10445
mes
Reventon Pro finally available in Germany!
mes is offline   Reply With Quote
Old 10-25-2012, 10:22 AM   #10446
Tunatsol's Avatar
OK so I have not had the chance to update my esc. The v18 settings in LED box don't mach up to the setup sheet. Like items 3 and 4 seem the be backwards. Has someone else had this problem and what is going on and how do I know what I'm changing in the LED box?
Josh Youngs
Old 10-25-2012, 10:47 AM   #10447
trickedout's Avatar
Trader Rating: 31 (100%+)
Is this happening in Stock?? heres a post I wrote in the off-road thread, might be whats happening...
Also just a note when using the led card in stock0 profile. Since setting 3 being the dynamic multi timing system is disabled it is also skipped but the numbers can get confusing. When running stock your settings will be
1-1 running mode
2-2 lipo cut off
3-4 this is where it gets confusing where this would normally be DMTS it is now setting 4 which is DRRS and everything setting after that is a number ahead.
3-5 Abs
4-6 drag brake
5-7 neutral range
6-8over heat
In the middle of some changes
*702 RC Raceway* *WindWater Raceway*
trickedout is offline   Reply With Quote
Old 10-25-2012, 11:15 AM   #10448
slakr's Avatar
Trader Rating: 28 (100%+)
Is there somewhere that compares or lists all the specifications for the different REVENTON versions (PRO, R, S, STOCK CLUB RACE)?
Thanks.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is online now   Reply With Quote
Old 10-25-2012, 11:47 AM   #10449
Tunatsol's Avatar
Thanks.
The speedpassion site has a compare button if you click on the left side esc / reventon. Speedpassion.net
Josh Youngs
Old 10-25-2012, 11:54 AM   #10450
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
My set up posted for the 10.5 a page back or so works well with the 13.5 use those settings if you are racing a large nitro track that's open try gearing around 5.5 or so with the stock sensor board to the right(max) and check your temps . I don't much 13.5 but that should get you in the ball park. I geared my 10.5 around a 5.1 but that's a 1cell motor so it has less timing on the sensor board than the mmm10.5
Old 10-25-2012, 12:00 PM   #10451
slakr's Avatar
Don't see it. Must be blind or something. Don't understand why the website does not have a "specification" tab under each Reventon model. You know, motor limit, voltage/cell count (type) limits, BEC voltage Etc.
Old 10-25-2012, 12:04 PM   #10452
Super Moderator
Marcos.J's Avatar
Reventon pro has a 3.5 limit
Reventon r had a 5.5 limit (7.5 boosted)
Reventon s I think is. 10.5 limit
They are listed In the king-golden website
http://www.kinggolden-rc.com/catlist.asp?mid=1
Old 10-25-2012, 12:07 PM   #10453
Super Moderator
Marcos.J's Avatar
The boosted software for the reventon pro is from 4.5-21.5
Old 10-25-2012, 12:29 PM   #10454
slakr's Avatar
Thanks Marcos. The most useful information I found was by downloading the two user manuals (one for the Pro and another for the other 3). It gave me most of what I was looking for.
Old 10-25-2012, 06:50 PM   #10455
Trader Rating: 3 (80%+)
Does this mean blinky for 21.5 is ready ?
76Trans Am is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
