Like Tree12Likes
Old 10-16-2012, 06:28 PM   #10351
any updates if the new software for the 13.5t is available for download?
kikoy is offline   Reply With Quote
Old 10-16-2012, 07:38 PM   #10352
Fuzzi0n's Avatar
Originally Posted by YoDog View Post
You don't have to buy parts to change the timing. You have the option of expanding the range of timing with other sensor modules. there is a difference.
The other brands typically don't have as broad a timing range as the SP motors hence you are limited by what comes installed by design. Each module provides 10 degrees of adjustment and depending on which model you choose, it can be 0-10, 11-20, 21-30 and so on. With the 31-40 degree module, you are getting up in the range most motors can't accommodate. So in conclusion, if you know what timing range you intend to run, you may or may not need an additional module.
Thanks for clarifying that, I may have misunderstood them.
Fuzzi0n is offline   Reply With Quote
Old 10-17-2012, 01:56 AM   #10353
If you are actually running in "Blinky" mode, then how is it that you have 45 degrees of timing in the speedo, or do you mean temp?
45 degrees > temp
Originally Posted by SP Tech1 View Post
Are you sure no wires were touching each other?
No, wires are correctly, donīt touch each other
brnantunes is offline   Reply With Quote
Old 10-17-2012, 08:04 AM   #10354
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Default Reventon PRO Software
Hey guys,just feel I,(we), would just like an update on how the software development for 13.5 + is going?
No stress or worries,just wondering.
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 10-17-2012, 08:15 AM   #10355
Solara's Avatar
Trader Rating: 16 (100%+)
New software for boost is almost ready.....EC KIM took the Korea National win with the software for MOD and 13.5 boost class. It must be good....
I need to find a way to explain how to UPDATE the software without reinstalling the whole program...give me some time.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 10-17-2012, 08:24 AM   #10356
the new boost software only for reventon pro? how about reventon R?
wan161111 is offline   Reply With Quote
Old 10-17-2012, 08:29 AM   #10357
Originally Posted by sidecarphil1 View Post
anyone used a GT2.0 pro in a WGT 2S lipo and a 17.5 motor that care to share a set up ???
i have the feeling i can either have good torque or good top speed but not both
Thanks Phil
Can anyone help ????
PLEASE
sidecarphil1 is offline   Reply With Quote
Old 10-17-2012, 09:33 PM   #10358
Tunatsol's Avatar
The Reventon R 13.5+ boosted would help a lot. Useing a GT2.0 LPF in my Durango DEX210 buggy and its a tight fit. The Reventon R would be nice to have in there.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 10-17-2012, 10:05 PM   #10359
Radio Active's Avatar
I'm trying to find the sweet spot for a Speed Passion 1 cell 10.5 in blinky 12th.
Others are having decent success with the V3 at a rollout between 60 and 65 mm with 10 degrees advancement*, but my car seems sluggish with similar settings on the 1 cell.
I've got the timing boards to make anything I need just about, but could use some advice.
Circuit is 25m x 12m with 3m lanes.
*Except one car that has a rollout over 80mm and is still fast. This I just don't understand.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 10-18-2012, 01:47 AM   #10360
Timbo99's Avatar
Thanks Howard!
Old 10-19-2012, 06:50 AM   #10361
Timbo99's Avatar
Hi.am I the only one here?...and why am I whispering ?....nobody has been on this thread for days!...shhhhhh.
Old 10-19-2012, 07:12 AM   #10362
Trader Rating: 38 (100%+)
Try what the others are running and test gear combos before starting to adjust timing. I can't help with 10.5 but know that at my local track, two of us are using the 1 cell 17.5 motors with nearly identical qualifying times. I'm usually around 85mm of rollout with the stock timing insert at max and he is somewhere around 100mm with the +20 board. I determined my timing/ratio by watching lap times and found that my fastest laps didn't change (less than a tenth) with the lower rollout but there was no heat built up and absolutely no fade at the end of the run.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 10-19-2012, 08:32 AM   #10363
bare with me, i'm reading threw this thread but it's huge
i just received my reventon S and ultra sportsman v3 17.5. I'm going to be running in out local 1/10 tc sportsman (17.5) class which has NO restrictions on esc setup, timing etc.
so what are the recommended setting/starting point for software for this. i can run any timing, boost, whatever.
theagentorange is offline   Reply With Quote
Old 10-19-2012, 09:46 PM   #10364
NewWestF1's Avatar
Same setup, same question. Also do the software updates being talked about here apply to the Rev S too? Is it worth getting the Wifi module?
.. Sakura FGX; Novak power plant, Exotek, Lotus/Renault #9 ..
.. TB-03 Calsonic GT-R . reventon s/ultra v.3 power plant . yeah racing ..
.. M-05 Mini Cooper, Silver Can 104BK speedo, fakkin' cute!
...one of these days, life will get easier...
NewWestF1 is offline   Reply With Quote
Old 10-20-2012, 02:10 AM   #10365
Both of you should have read the specifications on the Speed Passion website or asked on here before buying the Reventon S esc's. They do not support Hybrid boost or any turbo functions. They are more suited to blinky classes. Only the Pro and R support Hybrid boost settings. The Wifi module is a good idea but I feel its more of a gimmicky thing really. I bought one but have never used it so far. The LCD box is just as easy to plug in and change settings with. Also, the Hybrid boost profiles are in the final stages of testing for 10.5-21.5 and are due to be released very soon according to SP.
Bumpy is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
