Like Tree12Likes
Old 10-16-2012, 08:20 AM   #10336
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Originally Posted by JoeyE View Post
What USB cable do you need/use for the computer fir the esc?
If your meaning the computer to the LCD programmer,it's a standard USB to mini USB.
Cheers
Tim
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 10-16-2012, 08:26 AM   #10337
Super Moderator
Marcos.J's Avatar
Trader Rating: 174 (100%+)
Originally Posted by RSCosworth View Post
And is there any news on how the testing went with the software that'll support 13.5-21.5?
So far so good
Old 10-16-2012, 08:33 AM   #10338
YoDog's Avatar
Trader Rating: 26 (100%+)
You will need the LCD programming box and a mini USB to USB cable connected from the PC to the programmer. Then you connect the speedo to the programming box with the receiver cable.
I strongly suggest reading the manual. They are all available online.
The speedo comes with the receiver cable and the programmer comes with the USB cable when purchased.
YoDog is offline   Reply With Quote
Old 10-16-2012, 08:49 AM   #10339
Trader Rating: 27 (100%+)
I bought the Reventon Pro and it came with the programmer box but no usb cable. Ill have to go buy one today. Thanks for the info.
JoeyE is offline   Reply With Quote
Old 10-16-2012, 08:49 AM   #10340
Trader Rating: 14 (100%+)
Just wanted to add one more thing. The Reventon PRO comes with the programming box. If you get the Reventon PRO, all you will need is the USB cable. You might already have some laying around from PC accessories or cell phone chargers.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 10-16-2012, 08:59 AM   #10341
Mxer59's Avatar
Trader Rating: 114 (100%+)
Im getting ready to buy one of the new reventon esc's and was looking at the MMM SP motors. Are they very competive looking at 17.5
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 10-16-2012, 09:02 AM   #10342
Fuzzi0n's Avatar
I asked about that elsewhere - they seem quite good although you have to buy different parts to change the timing.
Trinity seem to be the go to option for 17.5 - very quick. Reedy are a good choice too.
Fuzzi0n is offline   Reply With Quote
Old 10-16-2012, 09:03 AM   #10343
Default Reventon Pro Issues
Anyone have problems with new Reveton Pro?
In this weekend I run the first time with my new reventon pro, with an 10.5T thunder power in blinky mode, after 2 minutes run without explanation began smoke, the motor has 37 degrees and speedo 45 degrees, when I plug batery he smoke. It's everithing correctly switched. I don't understand what happens.
Now I hope that the shop or Speed Passion, resolve my situation.
brnantunes is offline   Reply With Quote
Old 10-16-2012, 10:37 AM   #10344
YoDog's Avatar
Ah, valuable information...
You didn't mention it was a "Revention Pro".
I recall someone else mention that it didn't have the USB cable in the box.
Most are the same so if you already have one from another device, it should work as mentioned by the previous poster.
Old 10-16-2012, 10:41 AM   #10345
YoDog's Avatar
If you are actually running in "Blinky" mode, then how is it that you have 45 degrees of timing in the speedo, or do you mean temp?
Old 10-16-2012, 01:34 PM   #10346
Are you sure no wires were touching each other?
SP Tech1 is offline   Reply With Quote
Old 10-16-2012, 06:18 PM   #10347
rimracker's Avatar
My track has buggy and SC 17.5 racing, I've tried several brands and the SP MMM is awesome. You can get more out of it depending what your track will allow, the red rotor is stock class legal at 12.5mm http://www.speedpassion.net/us/produ...=RS13803&c=MTR
If your track is not that strict (ROAR rules) I would suggest the green rotor http://www.speedpassion.net/us/produ...=RS13805&c=MTR.
But these are just upgrades the way the motor comes is pretty darn good.
I race against the new Trinity's, yes they are good but certainly not better IMO. You can dial in more timing the way the motor comes. If you want to go crazy then buy the other boards,
blue http://www.speedpassion.net/us/produ...SP000059&c=OPT
green http://www.speedpassion.net/us/produ...SP000029&c=OPT
yellow http://www.speedpassion.net/us/produ...SP000058&c=OPT
rimracker is offline   Reply With Quote
Old 10-16-2012, 06:24 PM   #10348
YoDog's Avatar
You don't have to buy parts to change the timing. You have the option of expanding the range of timing with other sensor modules. there is a difference.
The other brands typically don't have as broad a timing range as the SP motors hence you are limited by what comes installed by design. Each module provides 10 degrees of adjustment and depending on which model you choose, it can be 0-10, 11-20, 21-30 and so on. With the 31-40 degree module, you are getting up in the range most motors can't accommodate. So in conclusion, if you know what timing range you intend to run, you may or may not need an additional module.
Old 10-16-2012, 06:24 PM   #10349
rimracker's Avatar
I want to swap out bearings in my MMM motor. What is the best way to go about this? I assume I will need a bearing tool? Any suggestions or do they all work the same?
Old 10-16-2012, 06:28 PM   #10350
YoDog's Avatar
If you pull the end plates off, you can heat them up with a heat gun and they will fall out if simply pressing them out by hand doesn't work.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
