Like Tree12Likes
Old 10-12-2012, 06:24 AM   #10276
NolanP's Avatar
Originally Posted by linkless View Post
So I finally got a chance to put my Reventon Pro in my touring car and am running into major issues. I've updated the firmware on the programmer card and in the ESC and so far have tried Stock0 and Mod1 with the same results. Pulling the trigger nets no activity from the motor most of the time. If I roll the spur gear about a half turn and try again it works fine until I stop again. I thought it might be a sensor wire issue but 4 wires and 2 motors later there hasn't been a change in how it's acting. Just to be sure, I put the reventon S back with with the same battery/rx/radio/sensor wire/motor and everything works perfectly and is very smooth. With the Rev Pro it has the issue above and even when it works it doesn't sound very smooth. Has anyone else had this issue and does anyone have any ideas of anything else to try with it?
In case anyone is wondering, KO 408s rx, Futaba BLS351 servo, Novak Ballistic 17.5 motor. The entire setup has worked flawlessly with the Reventon S, the Novak Edge and Novak Kinetic ESC's so I'm quite certain it is something specific to the Reventon Pro.
From what your describing it almost sounds like the hall sensor on the motor. Try a different motor.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-12-2012, 06:27 AM   #10277
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Thumbs up Job?
I think I'd be a great Speedpassion tech,I'm on here more,am disabled with one knee shot and live and breath RC.(only hobby sport I can do AND love).
How about it Howard?
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 10-12-2012, 06:29 AM   #10278
Timbo99's Avatar
Hey Nolan,he is using 17.5 with 10.5 software.
That's the issue.
Cheers
Old 10-12-2012, 06:29 AM   #10279
Trader Rating: 38 (100%+)
Originally Posted by Timbo99 View Post
Hi,
Quite a simple fix.
You can't run a 17.5 yet with the current software.It only is suited for motors UP too 10.5.....or lower turns (down to 4.5/4.0).
The software you need will be released soon for 13.5/17.5/21.5.
Just have to wait,shouldn't be far away.
Cheers
Tim
If it was doing it on the Stock1 setting I would agree with you. Unfortunately it is doing it with the Stock0 software which is what I need for an upcoming race. I tried a couple of more motors last night including a 13.5 and 4.5 from Speed Passion and they all do the same thing. It happens when I'm running sensored and gets much worse if I run sensorless.
It 'seemed' fine on initial powerup and the issue showed up after updating software.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 10-12-2012, 06:31 AM   #10280
Super Moderator
Marcos.J's Avatar
Trader Rating: 174 (100%+)
i had a similar issue with it sounds like the motor sensor,
Old 10-12-2012, 06:34 AM   #10281
I guess I need to be more clear, 4 motors that run fine on numerous other ESC's and it gets worse if I try to run sensorless. I'm quite sure it isn't a motor problem.
John Barr
Old 10-12-2012, 06:40 AM   #10282
Timbo99's Avatar
Originally Posted by gdcopbdcop View Post
i can't wait to get the new s/w for 17.5 motors....
As you can see there is NO software for anything above 10.5 yet.
Don't just agree or disagree with me,read the instructions....PLEASE!
Old 10-12-2012, 06:43 AM   #10283
Timbo99's Avatar
That's right it isn't a motor problem,it's a software problem as there is none for the Reventon pro yet.
Ask one of the S/Passion techs for this to be clarified.
Regards
Tim
Old 10-12-2012, 06:48 AM   #10284
M-Technic's Avatar
Trader Rating: 15 (100%+)
Timbo, the software may not be "approved" by SP yet for liability reasons, but there really is no reason why it shouldn't function properly with any turn motor.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-12-2012, 07:02 AM   #10285
Solara's Avatar
Trader Rating: 16 (100%+)
You should contact the Australia distributor, I know there is a hub there, and I am sure they will need help...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 10-12-2012, 07:05 AM   #10286
Solara's Avatar
Timbo99 is correct....
We are going to release a software that will work with motor 10.5 and slower, we have the low and mid range problem take care, but we are now going back to finalize the top end in Thailand. Once this software is approved by the factory driver (we are very confident), this software will be release on SP site and this software will work on ALL MOTORS TURN.
I will say sometime next week....I just receive it 4 hours ago and I will test it tonight.
Old 10-12-2012, 07:12 AM   #10287
Xenolance's Avatar
This issue only effects the pro correct? I just received a Rev R and it seemed fine on the first run, a bit slow but that was my gearing, I was running 17.5 with stock 0 and a 6.5 FRD just to test it out.. the motor never got above ambient temps :-P Love the ESC so far though, it's really well made and seems high quality.
Xenolance is offline   Reply With Quote
Old 10-12-2012, 07:45 AM   #10288
Correct me if I'm wrong, but the software everyone is talking about is the Hybrid Boost (stock1). Is it wrong to assume that the Reventon Pro will work with a 17.5 using the Stock0 software?
John Barr
Old 10-12-2012, 07:54 AM   #10289
Solara's Avatar
Yes....the stock 1 version for the R is the mild version from the PRO. Not the same as the stock1 from the PRO.
Old 10-12-2012, 07:54 AM   #10290
Solara's Avatar
I will take care of your case....check your PM.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
