Like Tree12Likes
Old 10-08-2012, 10:54 AM   #10216
Originally Posted by NolanP View Post
It is. I have removed/installed four times now. Following your instructions. Once I re-install and connect everything it just keeps popping up do you want to connect to your esc. I click obviously....yes. It pops back up again. I click yes.....It pops up again. I click no.... Read. Read ok. Do you want to connect to your esc.....Yes. wait for it........Do you want to connect to your esc. Yes.
I've tried holding down value to have it "Connecting to the PC"
Hello Nolan,
Try This,
1. Uninstall V18 interface software
2. Uninstall anything that said SP, Reventon and SP lap under programs
3. Restart computer
4.Re-download V8 software
5.Install setup.exe
6. Install SpUsbInstaller.exe inside SpUsbDriver 6.6 folder
7. Make sure you say yes to everything windows ask you during install.
8. plug in the LCD card and got to Device manager, under ports it will shop Speed Passion Program Card(Com?)
9. unplug card and start interface software
10. At the main screen, hold the reset button on the lcd card and plugin the USB cable.
11. Update Firmware will show on middle left hand, update to V2.4.
12. Unplug after finish then replug.
13. Now connect ESC without BATTERY and any bare wire touching each other plus Cooling fan unpluged.
Thank you
SP CS is offline   Reply With Quote
Old 10-08-2012, 11:44 AM   #10217
NolanP's Avatar
Originally Posted by SP CS View Post
Hello Nolan,
Try This,
1. Uninstall V18 interface software-Done
2. Uninstall anything that said SP, Reventon and SP lap under programs--Done
3. Restart computer--Did full reboot from last know good settings per windows
4.Re-download V8 software--Done
5.Install setup.exe--Done
6. Install SpUsbInstaller.exe inside SpUsbDriver 6.6 folder--Done
7. Make sure you say yes to everything windows ask you during install.--Always
8. plug in the LCD card and got to Device manager, under ports it will shop Speed Passion Program Card(Com?)--Com3
9. unplug card and start interface software---Done
10. At the main screen, hold the reset button on the lcd card and plugin the USB cable.---Done
11. Update Firmware will show on middle left hand, update to V2.4.---Yup
12. Unplug after finish then replug.---In Process
13. Now connect ESC without BATTERY and any bare wire touching each other plus Cooling fan unpluged.---In Process
Thank you
Working on step 11 again. The I will repeat 12. Then 13
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-08-2012, 12:09 PM   #10218
vr6cj's Avatar
Trader Rating: 124 (100%+)
So I see Much More has SP Reventon Pro clones out..... is this the case?
vr6cj is offline   Reply With Quote
Old 10-08-2012, 12:29 PM   #10219
Yep I would say its a replica, shame
Jampot is offline   Reply With Quote
Old 10-08-2012, 12:32 PM   #10220
NolanP's Avatar
Hello Nolan,
Try This,
3. Restart computer
5.Install setup.exe
Thank you
No Luck.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-08-2012, 01:36 PM   #10221
jeff jenkins's Avatar
Trader Rating: 75 (100%+)
Speedpassion manufacters them for much more just like the old fleta 3.0 which was a gt 2.0 pro.
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 10-08-2012, 01:58 PM   #10222
Originally Posted by or8ital View Post
Does the reventon pro have a blinky mode and is it gonna be submitted for approval? Thanks.
"Stock0 ZERO TIMING "Stock - Blinky" software mainly used in USA. Also used in races such as ETS 2010-2012, TITC 2010-2012, and IIC (USA). (Roar approval pending)."
No specific time on when ROAR approval will be given or how long the process will take.
Originally Posted by JoeyE View Post
Where can I find a 4.5R MMM motor? Looks like it is out of stock everywhere.
If you can't find a 4.5 MMM there is also the 4.5 V3 and V3 1cell versions. Both are excellent motors for onroad. They are also heavily discounted at this time.
No Luck.
Nolan,
Are you still experiencing issues? If so can you post the specs of you computer? Window XP, 7.0, other?
Thank you.
SP Tech is offline   Reply With Quote
Old 10-08-2012, 02:07 PM   #10223
NolanP's Avatar
The weird part is that I can't even get the box to communicate with the esc at this point to change anything.
Windows 7
Asus 2.2 ghz 4gb ram, 64 bit, Service Pack 1
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-08-2012, 02:31 PM   #10224
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
Windows 7
i had the same issue with another laptop and i went under device manager with the card plugged in, clicked on it on the device manager then it gave me the choice to reinstall drivers i did and it works just fine now, i had to do it twice
Old 10-08-2012, 02:58 PM   #10225
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
That's kinda what I did...
kwiksi is offline   Reply With Quote
Old 10-08-2012, 03:27 PM   #10226
NolanP's Avatar
Too bad all I have here are two other Mac computers.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-08-2012, 03:29 PM   #10227
Super Moderator
Marcos.J's Avatar
oh i could not get it to work at all with my mac's i dont think the mac was reading the file correctly i tried 2 of them.not even running windows in paralell
Old 10-08-2012, 04:24 PM   #10228
NolanP's Avatar
Yup. I know I am waiting for someone...hint hint. To make a Mac program. I know for a fact I would have never been in this issue. My Mac doesn't crash or have program's freeze...but thats a whole new forum altogether. I guess I gotta track down Davitto or someone local to load up Stock0.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-08-2012, 06:43 PM   #10229
Hope you have time to answer my PM
Originally Posted by Solara View Post
SP Tech and Sptech1 are the official Speed Passion USA support here in Rctech. Any question about our products, orders or anything....They will be here to answer. And myself will help to answer as well (I do need help, I can't answer 20-30 PM plus email everyday anymore)....
outlandr91 is offline   Reply With Quote
Old 10-08-2012, 06:59 PM   #10230
In you Device Manager have you tried disabling and enable the USB port that you are using? This may reset everything in Windows 7 and allow you to start from the beginning.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
