Like Tree32Likes
Old 10-08-2012, 06:53 AM   #10201
NolanP's Avatar
Originally Posted by tazfam2 View Post
by the way there is new interface just released.
I'm on speed passion.net/downloads using the Reventon Pro software.
http://www.speedpassion.net/us/download.asp?page=1
Is this not the correct thing?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-08-2012, 06:55 AM   #10202
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Originally Posted by NolanP View Post
Can you explain what you had to do just in case.
I went to device manager to see if the LCD was hooked up...it was, but I right clicked on the Silicon labs 210xxxxx > click properties...there was a setting that needed adjusted that prevented the laptop to work with the driver or something to that matter.
kwiksi is offline   Reply With Quote
Old 10-08-2012, 06:55 AM   #10203
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
I just looked at what I wrote and thought ...Duh"!
Before anyone says "just lower the boost and DRRS",I like to only change one thing at a time ie.motor turns.
Still experimenting,playing,but luckily not breaking!
I hope you worked it all out Nolan.P
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 10-08-2012, 06:57 AM   #10204
Timbo99's Avatar
If its the one at the top.....correct.
Old 10-08-2012, 06:59 AM   #10205
NolanP's Avatar
It is. I have removed/installed four times now. Following your instructions. Once I re-install and connect everything it just keeps popping up do you want to connect to your esc. I click obviously....yes. It pops back up again. I click yes.....It pops up again. I click no.... Read. Read ok. Do you want to connect to your esc.....Yes. wait for it........Do you want to connect to your esc. Yes.
I've tried holding down value to have it "Connecting to the PC"
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-08-2012, 07:05 AM   #10206
Timbo99's Avatar
Ok.
That's your driver not reading the software.
Re-install the driver.
Double check the video,and instructions.
I know this is very arduous,but it's well worth the effort.
Hang in there!!!
Old 10-08-2012, 07:06 AM   #10207
Timbo99's Avatar
When it says do you want to connect your esc turn the car on
Old 10-08-2012, 07:09 AM   #10208
NolanP's Avatar
Ok.
Hang in there!!!
The link wasn't working for me for the video.
I will re-install the drive again.
None of the above. I have tried to re-install. I have read the instructions quite a few times. I can get the box to update the firmware I just can't get the esc to communicate.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-08-2012, 07:16 AM   #10209
Miller2's Avatar
Nolan i was having problems too Rick Davitto is the man to update your esc he put newest software on my pro and lcd card. NO issues since. I was struggling for 3 days tring to get it to work. Almost threw it away i was so pissed lol.
Miller2 is offline   Reply With Quote
Old 10-08-2012, 07:22 AM   #10210
Timbo99's Avatar
If you go to Speedpassions YouTube channel its there as well.
Old 10-08-2012, 07:30 AM   #10211
Make sure the leads are hooked up correctly. I ditched the all black for the traditional black/red/white. If reversed it won't work..
Old 10-08-2012, 07:38 AM   #10212
NolanP's Avatar
def not reversed.
I'm going step by step via the video instructions right now.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-08-2012, 09:07 AM   #10213
Does this new program support 13.5?
RSCosworth is offline   Reply With Quote
Old 10-08-2012, 09:08 AM   #10214
mes
Still neither Reventon ESCs in Germany nor information on the new motors. I guess I'll stick to Thunder Power and GM in this case...
mes is offline   Reply With Quote
Old 10-08-2012, 10:27 AM   #10215
def not reversed.
Also make sure if you are using a futaba radio that you reverse the throttle
SP Tech1 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
