Like Tree12Likes
Old 09-29-2012, 09:26 AM   #10141
Trader Rating: 38 (100%+)
Mine works fine under Windows 7. Updating the card on with version 17 gives me one choice, v1.3. After installing this, the programmer shows the same issue as before in the fact that the display no longer works. It connects to the ESC through the computer fine though and setting the ESC/updating the program is seemless.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 09-29-2012, 09:30 AM   #10142
Super Moderator
Marcos.J's Avatar
Trader Rating: 175 (100%+)
At the track so far so good 7.5v3 with 90% boost = ballistic
Fdr 7.6 temps in the Florida heat 136degrees
Old 09-29-2012, 10:03 AM   #10143
Super Moderator
Marcos.J's Avatar
Darn I wanted to try out the 4.5 but I left it at home
So far the 7.5 and 10.5 are very fast temps are staying under 140 . Software is very easy to use and tune very smooth also.
Old 09-29-2012, 07:30 PM   #10144
Trader Rating: 108 (100%+)
Send a message via AIM to kwiksi
Originally Posted by Timbo99 View Post
Ok.
Go to your user control panel,select add remove program's.
Get rid of what you have downloaded,restart pc.
Go to speedpassion,download the interface/ program.
Get hold of another pc/ laptop/phone or whatever and follow that video to the letter.
Then at the end you update the LCD programmer by holding in the reset button AND plugging into USB port.
It will then say on the programmer " UPDATE FIRMWARE"...click "yes".
It will take approx 4-5 minutes.
And yes I'm running windows for this process.
If it doesn't work,we will have to organise a Skype conversation so I can show you how to do it.
Or I'll fly over...LOL
Good luck,let me know how you go.
Wipe that pc first!!!!!
Regards
Tim Phillips
Mobile: 0416973325
Tried all that. Wondering if there's an issue with LCD box. Works fine with speedo. Checked all 4 USB ports on laptop.
kwiksi is offline   Reply With Quote
Old 09-29-2012, 07:32 PM   #10145
Super Moderator
Marcos.J's Avatar
After running the reventon pro in the Florida heat I added a sp fan on the side of the esc it dropped the heat temps by almost 20 degrees
Old 09-29-2012, 07:35 PM   #10146
Trader Rating: 14 (100%+)
Woo! Proven intercooler design!
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 09-29-2012, 08:47 PM   #10147
Super Moderator
Marcos.J's Avatar
yeap thats were i put the fan
Old 09-30-2012, 04:44 AM   #10148
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Well done Marcos,please let us all know what you think of the boost in relation to the length of the track.
This esc is going to be the best!
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 09-30-2012, 05:03 AM   #10149
Super Moderator
Marcos.J's Avatar
The track was about 135 feet maybe a little longer , never ran out of power, I started with solara's settings that are on the instructions. The only thing different I changed the startup rpm's for the 10.5 do it could kick in a little early. Boost I left at 90% for both motors , didn't feel the need to try 100% boost lol.
The 10.5 felt like a strong 5.5 motor
Old 09-30-2012, 07:00 AM   #10150
Super Moderator
Marcos.J's Avatar
This is the track that I ran yesterday !
http://www.charlottercracers.com/
Old 09-30-2012, 06:49 PM   #10151
I tried the 17.5 MMM at a 95 rollout with stock timing and the car felt flat. Dropped it closer to what I run my 1 cell at and it woke up on the infield without losing any speed on the straight. I didn't get a chance to play with timing but likely will during the IIC practice. My question is, what difference will I notice with more timing. Will I get more punch or more speed if I leave the gearing the same. Motor temp was only 120 with the 95 rollout and 106 at the lower. The 1 Cell generally comes off at around 98ish. In case anyone is wondering, the lower roll out was 2 tenths faster each lap overall.
John Barr
Old 09-30-2012, 08:01 PM   #10152
vr6cj's Avatar
Trader Rating: 124 (100%+)
How lomg did it take to get your esc's from SP to the US from outside the states? I want to order a couple but not sure they will be here for this weekend if I did. Anyone know?
vr6cj is offline   Reply With Quote
Old 09-30-2012, 08:07 PM   #10153
trickedout's Avatar
Trader Rating: 31 (100%+)
I'd say from outside us, not going to happen. And to be honest not a good chance at all even from the us warehouse.. I usually get my orders from us site in about 6-8 days or more... They take a day or two to process your order and then off to shipping...
In the middle of some changes
*702 RC Raceway* *WindWater Raceway*
trickedout is offline   Reply With Quote
Old 09-30-2012, 09:32 PM   #10154
blade072's Avatar
Trader Rating: 98 (100%+)
agreed
i ordered mine from rcmodel.hk.........i got mine in 4 days via ems.....but i do live in australia though......im guessing you would have to wait a minimum of a week maybe more
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 09-30-2012, 09:37 PM   #10155
NewWestF1's Avatar
i've gotten shipments from EMS (rcmart.com order) to Canada in 4 days too, fast shipping .. if you can find what you need in HK and need it quick and are willing to pay the $$, you should get it in time ..
Originally Posted by blade072 View Post
agreed
.. Sakura FGX; Novak power plant, Exotek, Lotus/Renault #9 ..
.. TB-03 Calsonic GT-R . reventon s/ultra v.3 power plant . yeah racing ..
.. M-05 Mini Cooper, Silver Can 104BK speedo, fakkin' cute!
...one of these days, life will get easier...
NewWestF1 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
