Old 09-05-2012, 09:01 AM   #9916
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by SRW141 View Post
I'm finding the yellow boards for carpet racing bring to much heat. Green boards work better and better all around power for carpet racing. Lower motor temps.
I agree , I also tried the stock timing board geared set in the middle ,fdr at a 4.2 and i was 3 tenths faster than with the green or yellow board with alot more rip and the motor never came off the track over 120 degrees.
Old 09-05-2012, 09:23 AM   #9917
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by JAM Racing View Post
Can use the led to edit but it locks up every time you edit an item in 0 stock and can only be set by cycling the on of button.
is this normal upgraded everthing software wise on lap top
If you are using the REVENTON ESC, please update the LED card to the latest V1.3 version from the software that you have already downloaded...that should take care of the problem.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 09-05-2012, 09:25 AM   #9918
Solara's Avatar
Originally Posted by ta04evah View Post
This is kind of "out there" but it may work as it seems the hobbywing & speed passion stuff have similar "issues".
Do you update the LED box like you do with the hobbywing lcd box? If so try running the update a couple of times and see if that helps the issue.
Couple of weeks ago helped a friend with a speed passion GT esc as he wasn't getting any braking with it, after he changed the capacitors with no difference we tried the "fix" that works with hobbywing esc's
We set the brake force to 100% (up from 70%), and set reverse force to 100%. Even though the esc was in fwd/brake mode this fixed his problems and gave him ample braking.
Cheers
Rob.
Well, that is not really a problem...the REVERSE function has everything to do with the BRAKES...it is listed on the manual. When you are using brakes from 75% and up and mating with the reverse to 100%...you will have all kinda brake that you want in the world and you should be satisfied with the performance. This is not a hobbywing programmer card fix....you can do the same setting on the SP card and it will performs the same.
My brake setting for indoor carpet is always 100%/100%...for outdoor, I will trim down to 75%/100%....
Old 09-05-2012, 09:29 AM   #9919
Solara's Avatar
Then start doing more racing and share with us of your motor/timing setting...
Old 09-05-2012, 09:48 AM   #9920
Super Moderator
Marcos.J's Avatar
will do , state race coming up in a week and a half
Old 09-05-2012, 10:00 AM   #9921
M-Technic's Avatar
Trader Rating: 15 (100%+)
Are you going to do more than one race this season Marcos?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-05-2012, 05:11 PM   #9922
ta04evah's Avatar
At the time this occurred we were at the track without the manual, I was unaware that this was listed and my friend may have overlooked that part in the manual.
The reason why I remembered about the settings was that I had read about it in the hobbywing thread.
Just putting it out there for other Speed Passion users that may have also overlooked this in the manual, and are wondering why their esc has little braking force.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 09-05-2012, 06:54 PM   #9923
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Default Awesome Electronics
Hey all,
I don't want to bore you all with my whole background but,at the tender age of 47 I have seen a lot of racing,and a lot of escs.
And I think what Speedpassion has done is simply awesome.
To our own Ryan Maker,Andy Cooke,Simon Nicholson,Ari Bakla,Oscar Piastri etc,Speedpassion has given them the tools to excell in this awesome sport/hobby as well as all you guys from all over the world and the racing that I see on a constant basis blows my mind.
You guys are awesome,Speedpassion products are awesome.
The engineering,electronics,software and customer service is not unlike Apple products and you should all be congratulated.
I just want to go consistent first,then fast..........maybe one day....
Regards and well done,
Tim Phillips
Melbourne
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 09-05-2012, 11:15 PM   #9924
NewWestF1's Avatar
i'm getting a TB-03 hopefully soon in the mail. it's my second car and i plan on running it stock for a bit just to get the hang of it. but pouring over the SP site i've seen a few things that i definitely want to invest in but have a few questions ..
#1 the Furai body, gorgeous definitely scooping one of those for the TB-03 chassis but i want some decent wheels too and i saw the Type-S tyres and wondering when they'll be back, how much for a set, are they good for the TB-03 and how will they be with the Furai body .....
#2 our racing up here for TC is limited to 17.5T - 21.5T depending on the race and location .. would a Reventon S 40A and the Ultra Sportman v3 21.5 or 17.5 be a good combo and what type of LiPo would i need for that ..?
thanks.
.. Sakura FGX; Novak power plant, Exotek, Lotus/Renault #9 ..
.. TB-03 Calsonic GT-R . reventon s/ultra v.3 power plant . yeah racing ..
.. M-05 Mini Cooper, Silver Can 104BK speedo, fakkin' cute!
...one of these days, life will get easier...
NewWestF1 is offline   Reply With Quote
Old 09-06-2012, 01:01 AM   #9925
JAM Racing's Avatar
Default ok
down loaded software as you suggested previously...Yes it is an Reventon S but it still has the same issue.i origanally downloaded of the SP website for that very reason. how do you ask it to select the led box as it doesnt have that option or am i not seeing it
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 09-06-2012, 05:16 AM   #9926
Timbo99's Avatar
Default Software
Well now I'm the proud owner of a Reventon pro,and Bluetooth module.
But,I can't seem to find any software downloads or support for either item!
Is it because what I've got is up to date?
ANY ideas would be greatly appreciated.
I have an android device for B.tooth btw.
Tim
Old 09-06-2012, 08:23 AM   #9927
Timbo99's Avatar
Can anyone help?????
Old 09-06-2012, 08:32 AM   #9928
Solara's Avatar
Originally Posted by Timbo99 View Post
Hey all,
Tim Phillips
Melbourne
Thank you for your support...we are doing our best to make it better.
Old 09-06-2012, 09:23 AM   #9929
Solara's Avatar
Please do send me a PM....as US is not releasing the REVENTON PRO yet so the support on the webpage is not available.
Old 09-06-2012, 09:30 AM   #9930
Solara's Avatar
To update the LED card, you need to connect the USB cable between your computer and your PC....then press and hold the RESET button on your LED card, then turn on your SP REVENTON interface program on your PC....on the left side of the screen you will see a "update firmware" icon...click on it and pick the latest one, which is the V1.3...then install.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
