Old 08-28-2012, 11:23 AM   #9856
bvoltz's Avatar
Trader Rating: 44 (100%+)
Did anyone run the Reventon?
What is the difference between this and the GT2.0?
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 08-28-2012, 11:59 AM   #9857
Solara's Avatar
Trader Rating: 16 (100%+)
I am only testing it at LHR...we submitted the ESC to ROAR but they have yet to approve that.
It is new for sure, smaller then GT2 PRO, 140A unit instead of 120A. New hardware, new software....full aluminum case design, It will run cooler. It will have full range of software to support from blinky to boost mod. It has 1S support (Pro-EX model)...and it will be a PRO-S model (80A unit).
Newer and better....simply saying.
Will be out in like 2-3 weeks.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-30-2012, 01:00 AM   #9858
JAM Racing's Avatar
Default Just bought my first speed passion but
Iv got an reventon s bu after swapping it to stock you cant get it to accept other setting from the Smart Led Program card with out it locking up and not moving on to the next setting
any clues
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 08-30-2012, 01:13 AM   #9859
Is there a step by step intructional somehwre that shows you how to programme the ESC . I have just got the GT2.0 and want to "de-tune"it slightly using the programming card
robprid is offline   Reply With Quote
Old 08-30-2012, 03:42 AM   #9860
mes
I was shocked to notice that the Reventon Pro is too wide to fit onto the chassis of my B-Max2. The LRP SXX and GM Genius Race R series (also available from Vampire Racing, Yokomo and maybe others) are a tight fit already. Fortunately there's way more room in a 4WD...
Oh, and I've got a Competition 3.0 related question: I fried my 7.5R in my 4WD buggy some weeks ago due to unknown reasons, and a club member's motor went up in smoke during the German nationals last weekend. Might this be caused by a bad connection due to the plugs becoming looser in the course of time? I've been a big fan of the Competition 3.0 motors, but chose a motor with solder tabs as a replacement due to my suspicion.
mes is offline   Reply With Quote
Old 08-30-2012, 04:07 AM   #9861
I got a reventon s running a 21.5 mmm in a friends novice car. Does anyone have any ideas why when he runs the car at the start of the race it does 2 laps then stops and only has steering then if u turn the esc off and back on it will run the whole race and the next time u take it out when it is at room temperature it does it again ???
Craft86 is offline   Reply With Quote
Old 08-30-2012, 05:20 AM   #9862
any clues
I had the same issue when using a notebook to setup my esc. I louded it from my PC and work great.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 08-30-2012, 07:59 AM   #9863
Mine was loaded from a pc and works fine except this glich. If anyone else out there had an idea what it could be it would be much appreciated.
Old 08-30-2012, 08:11 AM   #9864
M-Technic's Avatar
Trader Rating: 15 (100%+)
There shouldn't be any problems with using a notebook to program the ESC. Several of local racers, including myself, all do it with no problems.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-30-2012, 08:28 AM   #9865
I tried it on two notebooks. Didn't work properly. As soon as decided to try the PC. It worked. Now there is another issue. Need to get hold of Solara to discuss. I will seen an email out to the team about it soon.
Steve Walter
Old 08-30-2012, 10:57 AM   #9866
mes
Maybe the issue is related to the operating systems you use?
Old 08-30-2012, 12:25 PM   #9867
Solara's Avatar
any clues
Does that allow you to do any adjustment with your computer and the interface? Do that first...
Old 08-30-2012, 12:26 PM   #9868
Solara's Avatar
+ YouTube Video
Old 08-30-2012, 12:30 PM   #9869
Solara's Avatar
I cannot say too much about the new motor, but the new one will resolve your concern about the wire connection...in BOTH ways...
About the motor smoking issue...I have yet to see one that went to smoke because of the bad connection. Usually the motor will stop running after the plug went off....but it usually SMOKE the motor first due to over timing, over or under gear, then it pop the plugs off from the motor...that I have seen alot. OR...there are external item that jammed inside the motor can and cause the malfunctioning...so many reason.
Old 08-30-2012, 12:33 PM   #9870
Solara's Avatar
It is the sensor issue....replace your sensor wire with a new one, and check the sensor inside the motor...that sensor board might be damaged.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
