Like Tree32Likes
Old 08-17-2012, 12:17 PM   #9811
Trader Rating: 14 (100%+)
Originally Posted by SRW141 View Post
The green board is next 21* to 30*. Then yellow 31* to 40*. Then blue 41* to 50*.
I personally like the green board so far for 17.5 blinky. I keep switching back and forth between the green and the yellow. Make sure you drop a couple teeth when switching boards and watch temps.
Alright, just so I am clear on this. The +10, +20, +30, etc All refer to the base timing? Meaning the stock red sensor board bumps the base timing up by 10 to start with and goes to 20?
puhrot is offline   Reply With Quote
Old 08-17-2012, 12:37 PM   #9812
M-Technic's Avatar
Trader Rating: 15 (100%+)
There is base timing "built into" the motor that is always there no matter which timing ring you are using.
The stock board goes from +11-20*. The green board goes from +21-30*. The yellow board goes from +31-40*. And the blue goes from +41-50*. These are on top of the "built in" timing.
If you want to add 10* on top of the stock board, you should go with the green board.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-18-2012, 11:50 AM   #9813
guys, i am at the track now, running a 2.0 pro. we are racing 17.5 boosted. i am using the set up posted in the S/P web site. I need the boost to come in just a bit sooner. What can i do or change to start the boost just a bit sooner?
Thanks,
rich
gdcopbdcop is offline   Reply With Quote
Old 08-18-2012, 08:58 PM   #9814
shmit 1's Avatar
Originally Posted by Solara View Post
Please try to turn off the THERMAL protection via the programmer card.
That fixed my problems, thanks for the help.
It also helped 2 other racers at the track today.
shmit 1 is offline   Reply With Quote
Old 08-18-2012, 11:38 PM   #9815
miz4's Avatar
I'm having the same issue with the Reventon S that i just got. Should I do the same thing and turn off the thermal protection?
miz4 is offline   Reply With Quote
Old 08-19-2012, 09:10 PM   #9816
Mxer59's Avatar
Trader Rating: 114 (100%+)
I'm getting back into rc and would like some info, will any of the new Revention series Esc be able to handle a 4-pole 4x4 sct setup
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 08-20-2012, 06:11 AM   #9817
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
Ran the reventon r yesterday , very nice! Very smooth, little soft on the brakes but I will figure it out
Old 08-20-2012, 06:23 AM   #9818
M-Technic's Avatar
You shouldn't run with the thermal protection on for any racing applications.
Old 08-20-2012, 09:34 AM   #9819
Solara's Avatar
Trader Rating: 16 (100%+)
Thanks,
rich
Item 13 and 15...the lower the number, the faster and harder it will hit, also, temps go higher and sooner too.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-20-2012, 09:38 AM   #9820
Solara's Avatar
Glad that work............for your information, I don't use LIPO cuttoff as well. I pull off after 6 minutes no matter I am practicing or racing, I never overrun my lipo/car....turning that off will avoid the DNF while racing.
Old 08-20-2012, 09:39 AM   #9821
Solara's Avatar
NOT YET....only the REVENTON PRO can run the 4 pole 4x4 motor with boost. Should be out like October time.
Old 08-20-2012, 09:41 AM   #9822
Solara's Avatar
A little preview....debut this week at the ON ROAR PAVED NATIONAL 2012
Old 08-20-2012, 09:41 AM   #9823
Solara's Avatar
Remember this....BRAKE JUST SLOW YOU DOWN....ignore the brake...
Old 08-20-2012, 09:43 AM   #9824
burgboyz's Avatar
Trader Rating: 70 (100%+)
Beautiful!!
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 08-20-2012, 09:56 AM   #9825
M-Technic's Avatar
Wow, the Reventon Pro looks amazing!
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
