Like Tree12Likes
Old 10-13-2009, 04:23 PM   #946
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
what voltage should my lipo cutoff be at?
a 7.4V Trakpower 5400 Gold Lipo
kriiiss is offline   Reply With Quote
Old 10-13-2009, 06:40 PM   #947
ark
kriiiss
Ive only just got mine and I run 40c 7.4 intellect and I set it at 3.0v per cell. I hope its right.
I have a question tho, the gt2.0 comes with max timing advance as standard setting, Im running mod 4.5 so I turned timing off. Did I do the right thing?
cheers
ark is offline   Reply With Quote
Old 10-13-2009, 06:59 PM   #948
abailey21's Avatar
Trader Rating: 36 (100%+)
3.0v per cell
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-13-2009, 07:10 PM   #949
Hi Adam,
i'm new to SP product, just got 11.5R comp3.0.
i want to know, what is the 11.5R v2.0? is that the "Ultra Sportsman" series?
because i never saw 11.5R comp2.0, or do i miss something?
krat is offline   Reply With Quote
Old 10-13-2009, 07:26 PM   #950
abailey21's Avatar
Originally Posted by krat View Post
Hi Adam,
It was the previous version of the motor; pics to follow in a second i just need to find some
K.C.C.O.
Old 10-13-2009, 07:28 PM   #951
abailey21's Avatar
Example of a version 2 motor
Example of a version 3 motor
K.C.C.O.
Old 10-13-2009, 07:49 PM   #952
Ok, thanks Adam.
my friends told me that the old 11.5R motor is lack of torque and topspeed.
I'll test my comp3.0 this weekend, hopefully it performs better.
Old 10-13-2009, 08:17 PM   #953
Guys,
I have 2 brand new GT2 escs. They both run great, but in the couple of seconds that the spektrum is binding each time I turn the car on, the motor spins slowly.
Is this normal?
Once the receiver is bound up everything is completely normal and the car runs great.
Michael Jones
ixlr8nz is offline   Reply With Quote
Old 10-13-2009, 08:34 PM   #954
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Spektrum receivers have a failsafe function that defaults to whatever value the throttle is in when you bind the receiver. Recalibrate your esc, then rebind your Spektrum and hold full reverse when you rebind it. Or just leave it alone. It won't hurt anything.
Old 10-13-2009, 08:38 PM   #955
r0adrunn3r's Avatar
Send a message via MSN to r0adrunn3r
Originally Posted by ixlr8nz View Post
Guys,
Is this normal?
Michael Jones
Always turn your transmitter on before turning the ESC on...
Tony Doherty
r0adrunn3r is offline   Reply With Quote
Old 10-13-2009, 09:13 PM   #956
ark
cheers
Anyone?
Old 10-13-2009, 10:33 PM   #957
Thanks mate, I will give it a go.
Mike
Old 10-13-2009, 11:42 PM   #958
jdev's Avatar
Originally Posted by abailey21 View Post
Highly advised to NOT run both switches, it's a quick way to make your ESC go poof
Ok, so no cutoff then... so we just have to track runtime. Thanks.
jdev is offline   Reply With Quote
Old 10-14-2009, 12:45 AM   #959
hey mike how did you get on???my sp ver 3 motor is only 40degree celcius after a race my lrp x12was 100 is this normal ???does it mean i can gear more both are 4 turn motors
tamiya_008 is offline   Reply With Quote
Old 10-14-2009, 01:52 AM   #960
Ryan Maker's Avatar
Send a message via MSN to Ryan Maker
kriiiss
cheers
Hey Daz,
Nar, put the timing back up to Max. I run all my Motors, 4.5, 4.0 on Max Timing, heaps faster this way
Ryan.
Awesomatix - Muchmore - Silverback - Roche - Radtec - LeeSpeed - Protoform - Futaba - Hiro Seiko - SG PitDesign
RC MAKER - www.rcmaker.com.au
AWESOMATIX - R1 WURKS - VOLANTE
Ryan Maker is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
