Like Tree12Likes
Old 06-12-2012, 01:56 AM   #9541
mnz
random question. thinking of getting the speed passion gt 2.1 ex or the gt 2.0 pro. which is better?
mnz is offline   Reply With Quote
Old 06-12-2012, 06:29 AM   #9542
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by wollow86 View Post
I just picked up a GT 2.1 Pro Stock, which I'm going to try in my boosted 17.5 TC. I'm looking for a good starting setup for a large outdoor asphalt track.
I'm coming from a Tekin RS, so I'm not new to boosted setups. I'm wondering how much info from the Tekin setup will be useful for me at my home tracks?
For a rough idea, I was running 5.35FDR, with 50deg boost, 5000-17000rpm, 14deg turbo, .3 delay, 2ramp, and 8deg motor timing on a Duo 3. That would come off at about 75*C with a yeah racing fan after a 6min run. I'm now using a Seis fan, with the Reflex fan mount.
Any help would be great.
The Tekin setup won't help very much. Start out with a setup like this, but you'll probably add more gear since you were running a 5.35 before.
http://www.speedpassion.net/uploadfi...%20Raceway.pdf
For what application? The GT 2.0 Pro is their best speed control though.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 06-12-2012, 07:22 AM   #9543
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Solara View Post
OK....keep an eye on the site, REVENTON "S" will be instock very soon (later this week or next week).
Reventon "Stock Club Race" will be 3rd week of June...and Reventon "R" will be right after.
REVENTON "S" can be software update to the new STOCK "0" software that will run blinky mode.....
And which Reventon will run 1s without a booster? The pro correct?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 06-12-2012, 07:24 AM   #9544
Default to change different software
at the moment using sp 323 stock software on my xray t3 2012 with good success i race on indoor carpet just seen sp had released 428 stock software anyone used this yet ? worth upgrading yet ? what do you gain with the 428 stock software thanks for any replys
rc12r5.1
moggy12 is offline   Reply With Quote
Old 06-12-2012, 07:46 AM   #9545
Trader Rating: 72 (100%+)
Default 428
Solara said, more topend, with same gearing, less motor heat reported.
btrukr is offline   Reply With Quote
Old 06-12-2012, 07:48 AM   #9546
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by johntrickle2 View Post
Solara,
What causes a Sensor Board to go bad? In a 17.5r MMMv3.0 at 153'F, just went bad. I checked the sensor board with an Extreme Dyno checker.
My other SP17.5 motor at 164'F was perfectly fine all day at these temps. Both had the Blue Sensors installed at the same timing.
You have PM...please check, thanks.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 06-12-2012, 07:54 AM   #9547
Solara's Avatar
GT2 PRO....GT2.1 EX is mainly for 12th scale run with 1S lipo
Old 06-12-2012, 07:55 AM   #9548
Solara's Avatar
Yes and yes and yes yes yes....
Old 06-12-2012, 07:56 AM   #9549
Solara's Avatar
Listen to the BOOST master here....his setup won't be wrong.
Old 06-12-2012, 04:50 PM   #9550
bluef250's Avatar
so why is the 428 stock not recommended for mod when Marc Rheinard ran a mmm 4.5?
bluef250 is offline   Reply With Quote
Old 06-12-2012, 10:25 PM   #9551
the problem is , stock software has more options for timing and if your not experianced then running timing and mod is a bad option , if your experianced then go ahead , the Marc set up from ETS is on the Speed Passion site
sidecarphil1 is offline   Reply With Quote
Old 06-12-2012, 10:52 PM   #9552
Robertcooper88's Avatar
428 is a definite improvement for already great software. It will allow you to go more aggressive on your setup in the summer months without the added heat. It can only help your speedo setup limits.
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 06-13-2012, 03:46 AM   #9553
Pattojnr's Avatar
Trader Rating: 19 (100%+)
looks like ill be trying some new software this weekend , lets see how it goes with the 3.5T .
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-13-2012, 04:46 AM   #9554
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
tried the 428 at the last ETS in holland. temperture was lower than with 323. however i had almost no breaks with a thunderpower 4.5T motor. i changed back to 323 and brakes were good again. could well be a fluke as viktor was running the same settings and motors but just saying.
Yokomo BD7 -- Hobbywing v3 -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 06-13-2012, 07:01 AM   #9555
M-Technic's Avatar
What were your settings for brake and reverse strength?
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
