Like Tree3Likes
Old 05-16-2012, 09:16 AM   #9451
Solara's Avatar
Trader Rating: 16 (100%+)
As far as I know...there are no fix for the 1S cutoff. I have several versions that I have tested....no matter how GOOD and how MUCH I charged a good lipo, it will cut off at 6 minutes or so, on boost stock and mod, on 12th scale...it does not really cutted off, it stop, and back on, then couple laps down, do it again and again....
I leave the cut off completely turned off and never have a problem again, and still haven't have a 1S lipo buffed or went bad so far...
I personally never use lipo cut off........never need it.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-16-2012, 08:32 PM   #9452
Jonnydb's Avatar
Send a message via MSN to Jonnydb Send a message via Skype™ to Jonnydb
Originally Posted by sidecarphil1 View Post
just a Team Powers Dyno , it measures A draw and motor Revs
are you using a lipo? the only that i dont like using this dyno, because after few tests the battery will lose the power
i didnt find yet a good volt regulator to use with power supply, to work with 7.2v
T.O.P Racing Brazil
Jonnydb is offline   Reply With Quote
Old 05-17-2012, 07:54 AM   #9453
Moderator
Clegg's Avatar
Yeh you would probably need to source a pretty expensive lab power supply (adjustable, very high current, clean and filtered power) to do that. I know I looked at one and it cost around $1000 that could properly emulate a 3.7 or 7.4v Pack at high sudden amp draws. In the end it wasnt worth it.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 05-17-2012, 09:19 AM   #9454
M-Technic's Avatar
Trader Rating: 15 (100%+)
I would think topping off the charge on your battery between dyno pulls would be sufficient.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-17-2012, 12:11 PM   #9455
onekiwi's Avatar
Where can I find the manual to this esc? The top one
http://www.redrc.net/2007/11/speed-p...o-feigao-escs/
Is it any good? I got it in a job lot of RC stuff
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 05-17-2012, 12:33 PM   #9456
Solara's Avatar
None....but what would you like to know about this ESC? Just hook it up like the current SP ESC and calibrate the same way and see that works or not.
If it make the motor move, it is GOOD...but if you are talking about is that any good for RACING....then I would say buy a new ESC. That ESC is like 4 years old products.
Old 05-17-2012, 05:32 PM   #9457
Jonnydb's Avatar
dont need that only a good regulator... maybe the motor only draw 10A unload.
T.O.P Racing Brazil
Old 05-17-2012, 05:34 PM   #9458
So I got a V3 17.5 and it has started to give me some issues. It shutters bad, and will just not move until I give it a push sometimes. So is this going to be a sensor board or is it a bad phase?
ikpthegame is offline   Reply With Quote
Old 05-18-2012, 02:37 AM   #9459
malcnz's Avatar
Any one know why the MMM 13.5 motors are taking so long to get back into stock?
cheers.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 05-18-2012, 03:23 AM   #9460
onekiwi's Avatar
Sorry its this one at the top
Mine hasn't got the HW name on it.
Can this be upgraded?
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 05-18-2012, 06:11 AM   #9461
M-Technic's Avatar
Try replacing the sensor wire (several times) first. Then move onto the sensor board on the motor. Finally, if you are still having issues, it could be the sensor port on the ESC, but that is very rare.
Old 05-18-2012, 07:58 AM   #9462
YoDog's Avatar
Trader Rating: 26 (100%+)
It appears to me that the sensor modules are kind of fragile compared to other motors I've used. I just got a MMM 13.5 and 2 of the pins soldered to the PCB from the Hall effect board were not soldered adequately and came loose right off the bat. it seems the pins are just a tad too short and are difficult to get a good solder bond. I would say that if your motor is cogging, it's probably because of the sensor module or the cable. That's been my experience with the V3 motors.
YoDog is offline   Reply With Quote
Old 05-18-2012, 08:27 AM   #9463
M-Technic's Avatar
cheers.
MMM's should be back in stock by the end of May or early June.
Old 05-18-2012, 08:38 AM   #9464
Solara's Avatar
Cogging is cause by several things...(1) ESC software mal-fucntioned (2) Motor sensor board went bad (3) sensor cable went bad (4) Sensor socket on ESC went bad...
Best way to check is use the same ESC with different motor....if it works on the other motor, then the sensor board within the motor went bad, replace with a new one.
Old 05-18-2012, 08:39 AM   #9465
Solara's Avatar
No, they are not upgradable.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Scrad
