Like Tree32Likes
Old 05-07-2012, 11:43 AM   #9421
i bought some Ceramic bearings and i didn't notice any differance at all ,
I personally think they are a waste of money , clean your original bearings of the blue grease then oil with light bearing oil and then your set
my motors have the best top speed of most of the blinky field over here in Holland
sidecarphil1 is offline   Reply With Quote
Old 05-08-2012, 05:46 AM   #9422
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
Default setting gt 2.0
Just got a GT 2.0 (happy!) and the instructions say to set the brake/throttle EPAs to "100%" while calibrating. My radio (like many others) will let me adjust the T/B maxes to 140% and 160%. So, my questions are:
  • Do I set it at 100% and then leave it even after calibrating?
  • Do I set it at 100% and then, after calibrating, adjust the EPAs back to their maximums?
  • Do I calibrate it at their maximums even though those are higher than 100%?
Thanks for any input!
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 05-08-2012, 06:07 AM   #9423
M-Technic's Avatar
Trader Rating: 15 (100%+)
You could do #1 or #3, but I don't suggest #2. I do #3 personally. But I don't leave it at the maximum... I never need "full" brakes, so after calibrating I turn them down to 80-110% (after calibrating at 140%).
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-08-2012, 07:18 AM   #9424
stankulas's Avatar
RC America
Xray
Hudy
stankulas is offline   Reply With Quote
Old 05-08-2012, 08:28 AM   #9425
Solara's Avatar
Trader Rating: 16 (100%+)
Please do your #1 option...set throttle and brake @ 100% (default for any brand of radio) and calibrate with the ESC.
If you are interested to find out yourself, you can try turning up (or down) the EPA % after the initial calibration (@ 100%)....you will find out there are no physical advantage by turning the EPA UP at all. Some OFF ROAD driver will turn down the EPA % after then calibration because they run MOD motor and do not need the extra power that doesn't need (due to the track size)....turning DOWN the EPA is all driver preference. But turning up the EPA after the calibration does not make it faster or more brake.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-08-2012, 08:57 AM   #9426
Dog Runner's Avatar
Great, thanks
I'm close to Kochanski now and we'll see if this new ESC gets me any closer....
JR
Old 05-08-2012, 11:14 AM   #9427
Solara's Avatar
Great, thanks
Ah....Nochanski. You need more then the ESC then...I usually get 6 packs plus Tacos and tried to make him sick on the driver stands. It worked on Frazier..LOL.
Old 05-08-2012, 07:43 PM   #9428
Trader Rating: 72 (100%+)
Default GT pro/4 pole 550
Solara: If I turn off the boost and timing, will a GT pro run a 4.5/550/4 pole on 2s ok? Want to put it in my 1/8 buggy. Am lightening everything in the car to try and gain advantage, and 2s is lighter then 4s.
btrukr is offline   Reply With Quote
Old 05-09-2012, 12:06 PM   #9429
JamesHealey's Avatar
I have just bought a Speed Passion GT V2.1 EX and trying to start it up with 1S Lipo.
And it just goes "beep beep ---- beep beep" with a green light flashing also.
Which as far as I know means insufficient voltage, do I need to start it with a 2S battery?
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 05-09-2012, 12:11 PM   #9430
Solara's Avatar
ONLY if you are running 2 cells. Anything more, you will see the magic smoke. BTW, you can run boost with 2 cells on your 550 too....just make sure your 550 can handle the boost/power.
Old 05-09-2012, 12:12 PM   #9431
Solara's Avatar
Use the 2S lipo to setup, turn off the voltage cut off, then you can use the 1S lipo for racing.
Old 05-09-2012, 12:42 PM   #9432
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Being bored the other day, I decided to take apart a few motors, clean them with brake parts cleaner and re-oil bearings etc.
I noticed there were no markings on the can and end cap... Does it matter how its put back on? The poles on the v3 are evenly spaced and the sensor is "free"... How should it be re-assembled? I shoulda marked them....
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 05-09-2012, 01:15 PM   #9433
Solara's Avatar
The end cap of all the V3 motor...."B" location, is align with the main LOGO of the V3 motor...if not, you will get 3 ABC pole messed up.
Old 05-09-2012, 01:32 PM   #9434
I see! I just need to get home and double check....
Yellow= Pole B....
V3 MMM:
V3 1 cell:
V3 NOT-MMM:
Old 05-09-2012, 02:23 PM   #9435
Just used some old NiMH.. thanks for the tip it's worked a treat!
Just a shame I've just knackered my radio handset, was looking forward to giving the car a shake down.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
