Like Tree46Likes
Old 04-11-2012, 08:51 AM   #9256
Originally Posted by narcotiks View Post
Hey
I need help with gearing and speedy setup on this track
In 21.5 boosted class with a MMM motor and gt 2.0 lpf speedy with the latest firmware.
I have tried a wide range of gearing from 4.6 (which I had no acceleration out of corners and from 6.1-7 which I was getting close to a good spot but it just wasn't working.
I'm stuck with what to try and need some advice.
Thanks.
Im facing exactly the same problem on the same track in 21.5T. I started on 4.5 gearing, loved the straight and my V3 motor stayed nice and cool, but got owned in the infield.
Went to gearing of 6.0, was like a blinky down the straight and my motor went to 88 degrees, too hot for the V3's.
I settled on gearing of 5.1, competative down the straight, nice and punchy in the infield and my motor is happy on 68 degrees with max timing on the speedy.
Try it you will love it. My name is Chris see you Sunday week :-)
Ignition75 is offline   Reply With Quote
Old 04-11-2012, 11:53 AM   #9257
Hi
What is the ideal gear ratio for a SP V3 21.5 no ESC timing on a medium sized Asphalt technical track?
Thx!
zzztech is offline   Reply With Quote
Old 04-11-2012, 01:14 PM   #9258
burgboyz's Avatar
Trader Rating: 70 (100%+)
Solara,
yhpm
Thanks,
Jon
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 04-11-2012, 02:22 PM   #9259
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by zzztech View Post
Hi
Thx!
3.8 to 3.5 should get you close....
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-11-2012, 11:58 PM   #9260
thx! Would retarding motor timing actually help to gear it up a bit more? Or not much benefits. I saw on SP setup sheet a guy with stock retarding the motor timing fully?
Old 04-12-2012, 12:17 AM   #9261
it depends...if your running a boosted class, you use less motor timing, and get all your timing from the speed controller,,if your running no stock non-boosted, you use all the timing in the motor you can get
gdcopbdcop is offline   Reply With Quote
Old 04-12-2012, 12:50 AM   #9262
I see, this kind of makes sense. The speed passion seems a lot less torquey than my LRP on the 21.5 that's why I was thinking of retarding the timing to get similar gear ratios
Old 04-12-2012, 03:44 AM   #9263
I LOVE IT! Finally got to test my new GT2.1 Prostock last night and it's amazing.
I'm coming from the Novak Kinetic and the Speed Passion has so much more speed!
I've based the settings on the 323Stock setup for 13.5 on the Team Driver ESC Setups page and just calmed it down a little.
The temps seemed to stay low and I could barely reach full throttle in my street it was so fast!
Really looking forward to racing this Sunday - it should be interesting.
Does anyone else have any more setups for 13.5 touring car as there is only one on the Speed Passion website for 323Stock.
dvaid852456 is offline   Reply With Quote
Old 04-12-2012, 04:04 AM   #9264
Also I note the instructions say to reverse the throttle channel on Futaba Transmitters. Why is this as it seems to work both ways. Normal and reversed.
I am using the 3GR 2.4GHz Transmitter is it necessary to reverse the throttle?
Old 04-13-2012, 10:35 AM   #9265
Trader Rating: 16 (100%+)
As long as it work...you are fine. But the older Futaba model like the 3PK still need to use the REVERSE on the throttle setting to get the car moving forward when I pull the trigger, not push forward.
Old 04-13-2012, 11:12 AM   #9266
what start gearing do you recommend on a v3 5.5t, 1s motor in touring on a large asphalt track? would 8:1 be a good start?
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 04-13-2012, 12:17 PM   #9267
Pattojnr's Avatar
Trader Rating: 19 (100%+)
thats a bit high. i run on a large track, and normally use 8.2-8.4 for a 3.5T. last couple of rounds i used a 5.5t and still managed a similar lap time . i used 6.8FDR for the 5.5t GT2 Pro with the 323 stock software 32 boost 20 turbo , 6 turbo slope and 550 ACC . no heatsink, just a fan on the chassis behind the motor. temps were around 80C all day. if temps get up, try 600 ACC.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-14-2012, 09:48 AM   #9268
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
Whats the recommended ESC for short course mod truck? I'm new to Speed Passion, but I'm looking to upgrade my LRP stock race club speedo. What software version would you recommend?
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
Old 04-14-2012, 07:29 PM   #9269
Trader Rating: 37 (100%+)
GT 2.0 Pro is still their top model until the Revention Pro comes out in the future.
Nexus is offline   Reply With Quote
Old 04-15-2012, 12:03 PM   #9270
Chief's Avatar
Trader Rating: 14 (100%+)
Post GT 2.1 Pro Stock
Guy's
I'm goint to be running 17.5 blinky in my TC6. I just wanted to double check that I will need to buy the LCD program box to install the 508 blinky software
right? Does the HobbyWing 2in1 LCD program box work also?
Thanks.
____________
TC6
B4.1
FT SC10
Chief is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
