Like Tree12Likes
Old 04-05-2012, 08:27 PM   #9226
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by wwddww34 View Post
I like the looks of the new Speed Passion Reventon ESC.
Now where can I get one? Speed Passion's web page has none in stock.
I hope end of this month....I have delay shipping date every time I asked that I don't want to promise anyone anymore.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 04-06-2012, 06:20 AM   #9227
Default need advice on timing
Hey guys, I have been having a look through but its not easy to find one particular setup, wondering if anyone can offer some advice,i finaly recieved my program card (lcd) i am running the following
Hpi pro 4
Speed passion GT 2.0 Pro
Speed passion MMM 10.5
6500 Lipo 90c 7.4 2s lipo
It will be used on a medium track quite a nice straight
Item 9 Boost timing
The defualt for the boost timing is showing *37 and to the right 36 hmm
The manual suggests value 5 which is 15 big differance
Item 10 Turbo slope
I dont evan have this one in my book
Its set at default *4 and to the right the number 18
Item 12 Turbo timing
set default *25 to the right the number 24 (i am sure i read somewhere were all meant to be using this 24 timing at our track)
Item 13 start RPM
Set as default *4 number to the right is 4000 (rpm)
Item 15 timing acc
Set as default *7 number to the right is 350
any adice on the above items appriciated thanks
DoNiE is offline   Reply With Quote
Old 04-06-2012, 07:13 AM   #9228
Solara's Avatar
Hpi pro 4
Item 9 Boost timing
Item 10 Turbo slope
Item 13 start RPM
Item 15 timing acc
Try that....
http://www.speedpassion.net/uploadfi...Howard%20L.jpg
Old 04-08-2012, 01:47 AM   #9229
Taman's Avatar
Trader Rating: 64 (100%+)
Hi, is there a "factory reset" option on the esc? I am running a 21.5R V3 1 Cell motor and it seems so slow. I normally run 17.5R. I have calibrated the esc to my transmitter.
The reason I asked is that the LCD Multi Esc Program Card just has "-" in both the Item and Value boxes. I'm sure I have seen numbers in them before that tell you the programmed value.
thanks!
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 04-08-2012, 02:16 AM   #9230
dfiantii's Avatar
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
thanks!
You have not said which esc you are running, only what motor is hooked up to it. Is your battery fully charged? What software is on the esc?
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 04-08-2012, 02:21 AM   #9231
Taman's Avatar
Opps thought I was in the SP Cirtix thread Fully charged battery, the software would be standard as I havent updated anything
I may have the wrong programming card as the one I just looked at had the ability to display 2 numbers in the value field whereas mine can only display 1.
All the programming boxes look so similar.
Old 04-08-2012, 02:26 AM   #9232
dfiantii's Avatar
What is your motor temps when you come off the track?
TLR 22 2.0
Old 04-08-2012, 02:35 AM   #9233
Taman's Avatar
Couldnt tell the exact temp as I didnt have my temp gun with me as I was just playing with my Tamiya Nissan R91Cp but the motor was just warm to touch, not hot at all. Are 21.5 slow normally compared to 17.5?
Old 04-08-2012, 02:42 AM   #9234
dfiantii's Avatar
It is a slower motor but it may come down to the gearing that your doing if its just warm to the touch you might be able to gear it up more. You do need a temp gun though so you don't burn up your motor.
TLR 22 2.0
Old 04-08-2012, 02:43 AM   #9235
dfiantii's Avatar
Do you have the same gearing as though you were using your 17.5?
TLR 22 2.0
Old 04-08-2012, 02:49 AM   #9236
Taman's Avatar
no I don't as my 17.5 is in my F104. I guess I didnt expect a 21.5 to be so slow. It's a 70T spur and 14T Pinion. Longest straight is approx 25 > 30 meters
I had a Tamiya Sport Tuned Motor in prior to the 21.5 with the same gearing and it was quicker.
Thanks for your help, appreciate it
Old 04-08-2012, 02:55 AM   #9237
dfiantii's Avatar
Thats the problem right there. You can't gear a brushed motor the same and you gear a brushless motor. With a 70/14 your gear ratio is 13. For brushless 21.5 you need to be down to a 4.2 ratios. Your gearing is way off thats why the 21.5 seems slower that the sport tuned motor.
TLR 22 2.0
Old 04-08-2012, 02:58 AM   #9238
Taman's Avatar
Ahh thank you so much. Really appreciate you taking the time to sort through this with me. Mental note - put more details into my initial question
Old 04-08-2012, 03:35 AM   #9239
Taman's Avatar
One more question - what temp range should I be looking for (the motor)?
thanks
EDIT: ha ha thanks thunderbt3 Can't have any of that magic smoke getting away!
Old 04-08-2012, 08:01 AM   #9240
Trader Rating: 14 (100%+)
thanks
Try to keep temps under 180F to prevent letting out the magic smoke
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
