The Speed Passion Thread
#8988
Please help~
I just downloaded the 1.06 software with driver for the Reventon ESC, but I am not able to install the driver as my window 7 (64bit) keep saying the driver is not certify by Microsoft (something like that)...
Please help~
Please help~
#8992
I think in the install manual it goes over this as well.
If you go to Speed Passion's website and catch the support guy online you can chat with him as well. Their number is also toll free I believe.
#8995
Tech Legend
Thanks, I'll see what I can find. Am I correct in assuming that with motors that start with high timing by default (ala Novak Ballistic 30 degrees) you just subtract the difference between what motor is on the setup and its stock timing versus the ballistics stock 30 degree timing?
#8996
#8997
Tech Legend
Thank you for your advice, I appreciate it.
To clarify, this would be for a 2wd SCT and 2wd Stadium truck. (onroad thread I know, but the offroad one is a bit dead)
Are there any setups out there you recommend to use as a baseline over others?
And if you have any advise for SCT 4x4 setup and firmware, would love that info. Motor there would be a 550 Tekin 5.5 in an SC10 4x4.
#8998
Sorry I couldn't help more. Hopefully someone else can chime in for you.
#9000
For offroad mod, you might not need as much boost anyways, so running the mod software can be a safety net, but it doesn't really matter either way.
