Like Tree46Likes
Old 02-22-2012, 05:46 PM   #8956
LonnyJ1950's Avatar
Originally Posted by Taman View Post
No I haven't tried that - how do you know when your battery is low if the voltage cut off limiter isnt working? So it's still ok to run I take it as you have been doing it.
You may be able to set it to 3 volts, I'm not that familiar with the Cirtex. But I run mine with it off. For racing in 1/12th I never use more than 4000 MAH, for practice you have to be careful not to run the battery too low. Most new transmitters have a timer function you can set.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 02-22-2012, 05:56 PM   #8957
Taman's Avatar
Trader Rating: 64 (100%+)
Thanks Lonny, appreciate the reply. I'll give that a go.
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 02-22-2012, 06:51 PM   #8958
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Originally Posted by Danny-b23 View Post
I find the V3 motors to be very heavy on low end torque compared to most motors out there, but seem to be very very smooth after the initial grunt. This is especially true when you add the new Red or Green timing boards.
This is all for blinky, by the way. Boosted, 95% of your speed comes from the ESC, so you don't need to worry about motor characteristics too much.
I am looking for more torque , doing offroad and using ballistics, everyone else is running motors in the 8.5 range and can clear a jump from a dead stop. the track is carpet and very small small, so the 17.5 around the rest of the track is great, but I just need more torque.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 02-23-2012, 06:45 AM   #8959
M-Technic's Avatar
Trader Rating: 15 (100%+)
If it's open motor you'll save your self a headache by just going to something a little more powerful like a 13.5.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 02-23-2012, 09:55 AM   #8960
ruebiracer's Avatar
Im very sad to say, that my Cirtix zero boost esc blew up a minute ago!
Never had any problem with it, a true "no worries" part!
Unfortunately for our new racing class were forced to switch to the LRP X12 motor, which is a mess in my eyes.
Well, I bought a used one from 2011, which should not have the actual problems (another theme).
So I tried it today on the table, motor came with the 4 dot insert.
Adjusted the esc, test the gas, everything seemed normal, with or without sensor cable, only the r.p.m. seemed to be a bit low (from the sound).
Suddenly I smeeled something burning, and my capacitor smoked up and the motor began to rev slowly without getting a signal. End of my beloved esc, probably.
Please, if you had similar problems, what could it be?
Is the sensor cable from LRP any different to SP? Also running GM motor on it and never had an issue! Sh** LRP stuff...
Help very much appreciated, as I dont dare to connect it to my GT pro now...
Best regard,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 02-23-2012, 10:48 AM   #8961
Tech Legend
Cain's Avatar
Yeah, I think I just drop in the 10.5 stators and go from there.
Old 02-23-2012, 11:58 AM   #8962
Danny-b23's Avatar
Best regard,
Matthias
If I were to guess I'd have to say that there was probably a short somewhere in windings on the motor.
And as far as it being cooked, it could just be the cap, it could be the whole ESC.
First thing I'd try is running a different motor, doesn't matter the wind as long as it's within the limit, on that ESC. Replace the cap with a new one and wire up as per usual. If that's not the ticket then next I would test the motor with a voltmeter to check the wires.
If one reads funny, the motor cooked the ESC, and it will probably continue to do so on every unit you use it with. If it reads fine, might have just been a short elsewhere, make sure when you re wire it all that everything is by itself, nothing visibly touching.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 02-23-2012, 02:44 PM   #8963
ruebiracer's Avatar
Thanks Danny,
I will measure the windings with a voltmeter.
Meanwhile I was in contact with the guy I bought the motor from, and he said that it was a known problem with Cirtix and LRP??
For sure the cap is gone, maybe the rest survived.
I will probably give Toni Rheinhard a call tomorrow. If there is a known problem, he should know it...
Thanks so far,
Matthias
www.TTSC-Racing.de
Old 02-23-2012, 03:52 PM   #8964
Questions??
Originally Posted by Pattojnr View Post
Howard, we use for boosted Stock, 17.5.
i would feel settings be similar, but gearing may change.
End bell - full retard , black (std timing board)
S411 (2.0 internal) FDR - 4.0
drag brake - 0
low voltage cut off- none
DRRS - 9
brake force - 75%
nuetral range - 6 (narrow)
AMTS timing- MAX
over heat - on
supercharger boost level - 7
RPM Delay - 5000
Full throttle delay - off
supercharger punch - -1
Temps with 17.5 were very stable and never went over 70C after 6 mins.
we ran one pack down past cutt off, and temp was maybe 76C but grip was huge, and it was about a 8 min run. we took off the dual fans and heatsink, and run one 25mm high speed fan taped to the chassis behind the motor (rear of car) and everything worked flawless. 6 min run, we can still go higher on SC punch, and SC boost level. but was no need on sunday, we proved it works.
for 13.5 you may want to try somewhere around a 4.6 FDR and see what temps are like. if its still winding out on straight, then drop to maybe 5 .
i really hope this helps you out Howard, and all the guys running SP at the TITC. Best of luck.
Was this with the 323 software, or the 528 software?
Thank you
gdcopbdcop is offline   Reply With Quote
Old 02-23-2012, 04:51 PM   #8965
Danny-b23's Avatar
Thank you
This would be with the 528. Note the "Supercharger Boost" and "Supercharger Punch" settings. These adjustments change in 323.
Danny Buck
Old 02-24-2012, 07:10 AM   #8966
mattwoodcraft's Avatar
yes this is with the 528 software
mattwoodcraft is offline   Reply With Quote
Old 02-24-2012, 08:38 AM   #8967
thanks guys, i will give this a shot!
Old 02-24-2012, 02:00 PM   #8968
Trader Rating: 20 (100%+)
Default gear 13.5 sp v3
I know this is the onroad forum but there is a lot of action here. Maybe someonce can point me in the right direction. I running a TLR 22 buggy with 2.43:1 gear box ration. I a running a 13.5 SP v3 motor. My current set up is a 27 tooth pinion and 70 tooth spur. My fdr is 6:30.. I am running blinkly software with a viper esc. What should my ration range be. I downloaded the PDF from SP site. It says 4.8 to 6 on a six cell..
Can someone help me out to what a safe range would be.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 02-25-2012, 04:59 AM   #8969
scoyle's Avatar
Hi,
Can anyone tell me if it is possible to replace the 'massive' capacitor that comes with the Speed Passion GT v2.0 with something smaller in size? I have had to mount the capacitor on top of the top deck.
Stephen
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 02-25-2012, 05:21 AM   #8970
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Why run blinky? Offroad motor questions can be answered here
http://www.rctech.net/forum/electric...on-thread.html
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
