Like Tree12Likes
Old 02-21-2012, 05:34 AM   #8941
SlideMasteR's Avatar
Default SP esc and x12 13.5
HI Guys
I have a SP GT2 Pro and x12 13.5 and was wondering if anyone got this combo to run cool or acceptably cool, here are my current settings
DDRS 8
boost 40 (any more and it just gets even hotter)
Turbo 15
Turbo delay 0.2
Turbo open 6deg/.1
Boost Acc 500 (running lower ups the temps even further)
Track is 40 x 20 outdoor smooth asphalt with medium to highspeed sections, currently running a 27 -28.5 mm rollout or 6.97FRD and the motor does not come off a 5 min run under 100c
Does anyone have setting that will work ???
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 02-21-2012, 06:18 AM   #8942
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by SlideMasteR View Post
HI Guys
DDRS 8
Turbo 15
Turbo delay 0.2
Turbo open 6deg/.1
Can you post the rest of your settings? Such as the boost start RPM?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 02-21-2012, 06:39 AM   #8943
Take a look at my X12 17.5T setup posted a couple of pages back, and then go a bit milder. They worked quite good.
But no matter what you do, the X12 will run hot! In high traction, my motor got 85 deg C after a 5 min heat, and some (at the DHI Cup) went even higher!
Probably the most important thing, is to use 4-dot insert in the endbell on the X12. Anymore timing (less dots) and you will never get decent temps - you will most likely fry it.
HI Guys
DDRS 8
Turbo 15
Turbo delay 0.2
Turbo open 6deg/.1
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-21-2012, 11:46 AM   #8944
HI Guys
DDRS 8
Turbo 15
Turbo delay 0.2
Turbo open 6deg/.1
Apologies start rpm is 5000, with 4 dot timing insert
Old 02-21-2012, 01:24 PM   #8945
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Originally Posted by nnick View Post
I used to run V3 5.5 for tc with GT2.1 pro stock and 323stock firmware
I'm about to use the 1s 5.5 motor. Should I make any changes to esc settings?
Any comments?
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is online now   Reply With Quote
Old 02-21-2012, 11:36 PM   #8946
Taman's Avatar
Trader Rating: 64 (100%+)
Hi, I just bought a SP Citrix Club Sport esc for my RM-01, wasn't untill the motor wouldn't turn that I noticed it isnt for 1 Cell Li-Po. I'm using an SP V3 17.5T motor. Will it work if I just replace the motor with a SP V3 10.5T 1S motor?
Does SP make a 1 Cell Esc?
thanks
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 02-22-2012, 03:32 AM   #8947
mattwoodcraft's Avatar
the citrix will run the V3 1 cell or 2 cell motor with no problems , in the F1 the 1 cell motor is better as it is lighter, i dont think the citrix will run a 1 cell battery
mattwoodcraft is offline   Reply With Quote
Old 02-22-2012, 03:41 AM   #8948
Taman's Avatar
Thanks mate, are there 2S batteries the same size as a 1S?
Got those setup sheets aswell - cheers
EDIT: Thanks Nexus!
Old 02-22-2012, 01:41 PM   #8949
Trader Rating: 37 (100%+)
thanks
Taman,
Look into the Speed Passion GT 2.1 EX. That ESC has a small footprint and supports 1 and 2 cell lipos.
Nexus is offline   Reply With Quote
Old 02-22-2012, 01:45 PM   #8950
burgboyz's Avatar
Trader Rating: 70 (100%+)
Originally Posted by Nexus View Post
Taman,
I have 3 of these and they are great! No need for a booster or rx pack either!
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 02-22-2012, 01:48 PM   #8951
Tech Legend
Cain's Avatar
Trader Rating: 232 (100%+)
how torquey are the SP 17.5s compared to a novak ballistic 17.5?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 02-22-2012, 02:20 PM   #8952
M-Technic's Avatar
The V3 motors are very good all-around. Torque I would say is comparable to Novak.
Old 02-22-2012, 03:01 PM   #8953
Danny-b23's Avatar
I find the V3 motors to be very heavy on low end torque compared to most motors out there, but seem to be very very smooth after the initial grunt. This is especially true when you add the new Red or Green timing boards.
This is all for blinky, by the way. Boosted, 95% of your speed comes from the ESC, so you don't need to worry about motor characteristics too much.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 02-22-2012, 04:28 PM   #8954
LonnyJ1950's Avatar
thanks
Did you reset the voltage cut off? On my EX2.1 I had to plug it into a 2S pack and turn off the voltage cut off limiter for it to work with 1S.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 02-22-2012, 04:31 PM   #8955
Taman's Avatar
No I haven't tried that - how do you know when your battery is low if the voltage cut off limiter isnt working? So it's still ok to run I take it as you have been doing it.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
