Old 02-15-2012, 02:50 PM   #8896
Lenman73's Avatar
Can someone please help me get a GT2.1 to blink in blinky mode ? I cannot seem to do it.
TeamC TC02T
Team-C TC02 evo
TLR 22 2.0 & 3.0
TLR 22-4 TLR 22t 2.0
B44.1 B44.2
Lenman73 is offline   Reply With Quote
Old 02-15-2012, 02:58 PM   #8897
Lenman73's Avatar
I have version 1.37 and only have 528stock listed. No 508stock. How can I find this?
TeamC TC02T
Team-C TC02 evo
TLR 22 2.0 & 3.0
B44.1 B44.2
Old 02-15-2012, 03:13 PM   #8898
Lenman73's Avatar
Nevermind. I do believe I actually figured it out.
TeamC TC02T
Team-C TC02 evo
TLR 22 2.0 & 3.0
B44.1 B44.2
Old 02-15-2012, 03:54 PM   #8899
@Art_Mighty's Avatar
Questions??
Originally Posted by Solara View Post
The CORE position from the rotor for 3.5T - 8.5T (Mod motor) is different then the one for 9.5 - 21.5 (stock motor).
You use a 3.5T - 8.5T rotor on a stock motor you have to repositioning the rotor (shims) and the result is horrible........and there is no reason to use a stock rotor on a MOD motor at the beginning.
Now that I'm paying attention I see that some manufactures have separate lines of tuning rotors for Spec vs. Mod, some don't. Why the alignment change? What's the benefit?
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 02-16-2012, 10:18 AM   #8900
onekiwi's Avatar
Can replacement boards be purchased?? Kinda need a new one
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 02-16-2012, 10:50 AM   #8901
Trader Rating: 36 (100%+)
Post up what you did and or how you did it.
I'm sure it will help many people looking to do the same thing.
Thanks.
Nexus is offline   Reply With Quote
Old 02-16-2012, 02:26 PM   #8902
Hi,
I hope anyone can help me here. I am using a GT2.0 Pro together with an LRP X12 17.5T running blinky. The motor is timed with 4-dot insert and geared at 4.0. Good speed and low temps.
The problem I have is with the brakes. I have calibrated everything and brakes are turned up to 100% in both speedo and transmitter. I almost have no brakes at all. I know that such a tall gearing will have less braking, but the Tekin speedo has a lot more brakes with the same setup!
Anyone that can help?
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-16-2012, 02:34 PM   #8903
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Originally Posted by Nilks View Post
Hi,
Have you reset your Tx to the ESC? Tx needs to be at 100% brakes, 0 EPA, 0 trim.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 02-16-2012, 02:51 PM   #8904
mattwoodcraft's Avatar
Hi,
You could also try sighing your throttle on your handset from normal to reverse or the the other way around and then reprogramme the speedy to your hand set
mattwoodcraft is offline   Reply With Quote
Old 02-16-2012, 03:19 PM   #8905
Solara's Avatar
Trader Rating: 16 (100%+)
Hi,
The most important step is...make sure the REVERSE (#6 option) setting is at 100% (if you want MAX BRAKE)....don't ask me why REVERSE (even there are no reversing on the GT2 PRO) has to do with Brake...it just does.
Try that...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 02-16-2012, 03:20 PM   #8906
Solara's Avatar
Is that a CIRTIX stock club spec..? If it is...buy a new one, cheaper that way.
Old 02-16-2012, 03:56 PM   #8907
onekiwi's Avatar
Unfortunately not its the GT 2 pro
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 02-16-2012, 05:18 PM   #8908
Solara's Avatar
Please contact your local SP agent and see they do offer repair service, or refurbish unit with a discount price.
Old 02-17-2012, 12:07 AM   #8909
onekiwi's Avatar
Nice to think it would but mine is a second hand unit
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 02-17-2012, 02:03 AM   #8910
Yes, I did that.
I will try that, if Solara's suggestion doesn't help.
Try that...
I will try that next time at the track. My reverse is all the way down, as I didn't think that would mean anything. But maybe it does
Niklas Hansen
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
