Old 01-21-2012, 08:46 AM   #8791
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by mattwoodcraft View Post
Solara and M-Technic
i have a question i have been adjusting and playing with the 323 stock software after the advice given a while ago this is where im up to. the car pulls hard plenty of speed how ever it seems to still be wanting to pull hard at the end of the straight it now keeps up with the tekin and lrp
would lowering the turbo slope to 6 be worth while to try ? or would this soften the car to much
thanks
were you not happy with the 528 settings Matt ?
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-21-2012, 12:04 PM   #8792
koopesv's Avatar
Trader Rating: 18 (95%+)
[QUOTE=M-Technic;10200607]What version of the 2.0?
Yes its 2.0 can I use 323 in mod
Your batteries are fine then, I just thought I'd ask.[/QUOTEtt
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 01-21-2012, 08:38 PM   #8793
Chief's Avatar
Trader Rating: 14 (100%+)
Default Esc
I have a tc6 and plan on running 17.5 blinky. I know there is a stock esc but I may need a boost in the future. So what do I get? Gt pro, v2.0 or v2.1? I don't know the difference between them. If it matters, I have a reedy motor.
Thanks!
____________
TC6
B4.1
FT SC10
Chief is offline   Reply With Quote
Old 01-21-2012, 08:41 PM   #8794
Tech Legend
Cain's Avatar
Trader Rating: 211 (100%+)
I have to say that latest stock software really puts out the power.
Using a Novak Ballistic 17.5 I went just took off the additional novak timing amounts from what was recommended but already can see a lot more power and the temps are next to nothing.
< Team Associated RC10B6D x 2>
< Tekno SCT410.3 x 2>
< Durango DEX410V5>
Old 01-22-2012, 04:36 AM   #8795
mattwoodcraft's Avatar
patto very happy with the setting mate. i was just giving this a shot also since i have been asking lots of questions about the 323 also.
I have been trying to feel the difference between the 2 settings and have better understanding on all the adjustments for the future. Im always interested in trying stuff
mattwoodcraft is offline   Reply With Quote
Old 01-22-2012, 06:38 AM   #8796
kwiksi's Avatar
Trader Rating: 101 (100%+)
Send a message via AIM to kwiksi
Thanks!
Either one will be fine. If I remember the Gt 2.0 will go down to 3.5t and the 2.1 Prostock down to 5.5t.
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - Vision Racing Products - Reilley Motorsports - 92Zero Designs
kwiksi is offline   Reply With Quote
Old 01-22-2012, 07:28 AM   #8797
Chief's Avatar
Thanks. I think im going to go with the the GT 2.0 LPF.
____________
TC6
B4.1
FT SC10
Old 01-22-2012, 08:19 AM   #8798
Yesterday i put the 0 timing soft in a gt2.0 LPF. It s a new ESC so after the update i set the neutral point/gaz/brake, all is OK.
I ve got a little red light when i am in the dark, but it s not easy to see it.
Maybe the A-B-C-+/- sticker under the soldering post hide the flash ?
Manson is offline   Reply With Quote
Old 01-23-2012, 06:51 AM   #8799
M-Technic's Avatar
Trader Rating: 15 (100%+)
thanks
If the car is still pulling at the end of the straight, I'd try using setting #4 or #5 for the turbo slope (18 or 24*/0.1s). This should be fine for 17.5 and it will apply the turbo faster on the straight away. Other things you could try are lowering the turbo delay to 0.1s, and also try moving some of your turbo timing over to boost. For example, you could run 48 boost and 16 timing and have the same amount of overall timing.
I meant what version of the 2.0, i.e. is it the 2.0 Pro, 2.0 LPF...?
323 can be used in mod, but you have to be careful as it can be very easy to overtime and blow up the motor.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-24-2012, 05:00 AM   #8800
Great thanks I will give this a shot next time at the track
Old 01-24-2012, 10:20 AM   #8801
Solara's Avatar
Trader Rating: 16 (100%+)
Ok....I need some update on the boost software setup for some oversea racer. Track is around 70' x 170' outdoor asphalt running boost 13.5....please share, thanks.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-24-2012, 07:11 PM   #8802
nexxus's Avatar
Trader Rating: 295 (100%+)
I just bought a used Speed Passion motor with the red tuning rotor in it (whatever that does) but upon inspection the rotor seems to have some obvious damage. Is this still ok to use or should I be sending the seller a strongly worded email?
nexxus is offline   Reply With Quote
Old 01-24-2012, 07:22 PM   #8803
defcone's Avatar
It's probably been dropped, nonetheless it's damaged.
defcone is offline   Reply With Quote
Old 01-24-2012, 08:15 PM   #8804
nexxus's Avatar
So unusable?
Old 01-24-2012, 08:28 PM   #8805
defcone's Avatar
So unusable?
Never tried, at high speeds the surrounding bits might come off but that's only a guess.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
