Like Tree46Likes
Old 01-14-2012, 12:59 PM   #8746
just run my sp gt 2.1 and 13.5mmm motor for the first time coming down the
streight the boost kicks in about half way and car accelerates well after
around 2mins this stops working and at the point were the boost kicked in
the car stops accelerating please help
track is small indoor low grip 15 sec laps.
set up is as sugested in instructions
with drrs level 5 over heat off temps after 5mins 60c and
gear ratio 6.25
any sugestions please?
rick oxley is offline   Reply With Quote
Old 01-14-2012, 10:59 PM   #8747
TeamWTF's Avatar
Had my first run with a V3 1cell today in 17.5 boosted sedan. Previously running the regular V3.
Pretty happy with the motor, tried different ratio's but ended up running the same FDR as before. Car felt pretty good, lots of punch and top end. I dont think it ran any cooler though as I thought it would.
Overall, thumbs up
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 01-15-2012, 04:05 AM   #8748
mattwoodcraft's Avatar
gear ratio 6.25
Hello
To start with will need to know what software you are running and what the settings are you are currently using
mattwoodcraft is offline   Reply With Quote
Old 01-15-2012, 12:23 PM   #8749
the software is what the gt 2.1 superstock comes with as this is the first time it has been used and not been changed setup as posted above sp
start recomendation for 13.5 in the instructions
these boost setings are
9=8
12=7
13=3
14=5
15=2
Old 01-16-2012, 11:31 PM   #8750
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
Ok guys.. you can laugh.. but im not sure how to set my gt2.1 in blinky? Im thinking there might be a drop down on the PC software?
Alan Hall
AlanHall is offline   Reply With Quote
Old 01-17-2012, 04:07 AM   #8751
morgoth's Avatar
Originally Posted by mattwoodcraft View Post
if you using the 323 software on the interface V1.37 go to the help and look at the the firm ware manual and in a addition to this M-Technic done a great write up on the software in more details which goes into it and clears things up a whole lot more.
really no need to be a brain surgeon now to understand it i save a copy here it is to assist you also with these 2 at your side while making adjustments it will make it easier for you
M-Technic if you ever feel the need to explain things more please feel free to do another write up you explain things very well and easy to understand
Where can I find V1.37? The speedpassion website only V1.36.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 01-17-2012, 05:02 AM   #8752
when i down loaded the it from speed passion mine is saying 1.37 when i updated it when it although it said v1.36
i double checked mine it defiantly says V1.37
Old 01-17-2012, 06:16 AM   #8753
morgoth's Avatar
You're right. I downloaded V1.36 from the website but the shortcut says V1.37.
Which software should I use for 17.5T and 10.5T boosted? I also download the Hobbywing software. Should I go with 323 from Speed Passion or 930 from Hobby wing?
I'm having exams this month and in february there's a race every weekend. I go working every saturday so I can't test with the setting. The first race is a club race so maybe I can test the software during the quali's if I have the time.
Old 01-17-2012, 06:46 AM   #8754
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Make sure you erased any previous version of software. Including the Hobbywing stuff which you don't need. Then d/l to get V1.37.
Upload SP 323.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 01-17-2012, 07:36 AM   #8755
M-Technic's Avatar
Trader Rating: 15 (100%+)
SP 323_Stock software for boosted 17.5 and 10.5.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-17-2012, 08:51 AM   #8756
morgoth's Avatar
323 is what I currently have. So no one tried the Hobbywing 930 firmware? My mates their Hobbywing ESC's seems to have more punch then mine. I tried the same settings as them with the same motor, but there's still a difference.
Old 01-17-2012, 02:19 PM   #8757
Trader Rating: 16 (100%+)
gear ratio 6.25
Try turn off lipo cut off and thermal protection both.
Old 01-17-2012, 03:54 PM   #8758
thanks will try this next meet and let you no how i get on.
any tips on smoothing out the acceleration until the grip
comes up?
Old 01-17-2012, 05:00 PM   #8759
hanulec's Avatar
Trader Rating: 27 (100%+)
Hi all - I just bought a bunch of mmms and green sensor boards. I integrated them this past weekend and found that one of the green boards is a dud. The motor runs but has less rpms than a black board (I have the Turbo dyno numbers to prove it). How can I get it replaced? Thanks!
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-17-2012, 05:42 PM   #8760
Trader Rating: 17 (100%+)
I have tried both, there doesnt appear to be any difference between the 2 in my opinion, more likely to be a motor variation.
I am now sticking to SP software and motors, and I am starting to get somewhere I think
these are my settings;
GT 2.0 Pro 323 stock software
FDR 7.65 Track= 210 mtrs with a 50 mtr long back straight
DRRS 6
Brake Force 87%
Reverse 100%
Boost Timing 48
Turbo Slope 18
TurboTiming 12
Start RPM 5000
Turbo Delay 0.2
ACC 450
Track temp was 55-60 Degs C Motor came off after 6 mins running at 76Degs C
Tried 2 different MMM motors and a V3 and all motors came off around the same temps but all had varing top end speed and rip out of corners
Car was slightly down on top end compared to another car with Hobbywing esc and 13.5 motor
any thoughts for improvement?
Team Awesomatix
R1 Wurks
RC Maker.com
Southern Tasmania Model Car Club
lethallee69 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
