Old 01-09-2012, 07:52 AM   #8701
mattwoodcraft's Avatar
Originally Posted by Ooj View Post
I just picked up a new 4.5 MMM and noticed there was about 2mm of play in the rotor/shaft. Is this normal? I don't have that amount of play on my V3.0 6.5.
I have some motor shims if I need to shim it but I'm not entirely sure how to "center" the rotor because the magnets don't seem to be pushing it to any natural static position.
Thanks in advance for any tips.
You can shim it I generally leave about 1 mm how ever the rotor will find it centre while running. I have got motor with no movement at al and removed a shim to allow for heat expansion
mattwoodcraft is offline   Reply With Quote
Old 01-09-2012, 12:18 PM   #8702
burgboyz's Avatar
Trader Rating: 70 (100%+)
Originally Posted by bigdadracing View Post
hey guys does anyone know when the new speedo going to be out....
also does anyone know who has 2.0pro gt in stock in the states???
CEFX Speed Shop has the 2.0 in stock and at discounted prices right now.
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 01-09-2012, 02:32 PM   #8703
bigdadracing's Avatar
thanks !!!!!!
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Old 01-10-2012, 01:57 AM   #8704
Trader Rating: 17 (100%+)
Did some testing at our local track today, tried 2 different MMM 13.5 motors and was quite dissapointed with the results.
Both motors used the same FDR and boost settings but one was miles ahead in terms of top end speed compared to the other. should I expect such a big difference between motors?
Xray T4 Sanwa M12
Team Xray Australia
STMCC President:
I was alright, .......but I got over it
New Web Address www.stmcc.webs.com
lethallee69 is offline   Reply With Quote
Old 01-10-2012, 02:05 AM   #8705
I have experienced the same thing with the V3 motors. My first two SP V3 17.5T motors were really different. One had to be geared around 6.5 FDR and the other I could gear around 5.0 with no issues.
Actually I tried doing the FDR 5.0 on the first one, and it died. But the other one were going strong with low temps and more power.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 01-10-2012, 06:18 AM   #8706
AlanHall's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
What would you estimated a good range of fdr would ne for me to get pinions? I was thinking like a 5.0 through 6.0 to start? Im buying all fresh gear this season and using the v3 17.5 boosted touring. Oh...anyone know any pinion that are cheaper that $5 each?
Alan Hall
AE B5r
AE B5/SC10
AlanHall is offline   Reply With Quote
Old 01-10-2012, 06:49 AM   #8707
defcone's Avatar
Trader Rating: 15 (100%+)
Yeah racing have 6 pinions for 20usd.
defcone is offline   Reply With Quote
Old 01-10-2012, 06:56 AM   #8708
5.0-6.5
Niklas Hansen
Old 01-10-2012, 07:17 AM   #8709
when your working out your gearing just check your temps and turn on your thermal cut off once your happy with you can then turn it off again.
i have found that with my V3 i am 4.2 FDR and my MMM 6.5 FDR both 17.5 boosted
Old 01-10-2012, 10:34 AM   #8710
yeah we saw this with ETS , there was some cheating b#%^rds buying 100 motors and 100 speedos then picking the quickest combo !!!!!
He was found to be cheating at the last ETS and was removed from the rankings.
BUT i have dyno'd a lot of my own motors and position of the end bell makes a huge differance , the end bell can go on 3 places and i moved it round untill i got the best RPM's this made a differance of 5000 RPM on some V3 motors , Also shim the rotor towards the sensor , at higher revs the rotor will move away from the sensor and you can get missed senses on the motor , tis drops the revs down slightly.
This is the world of 0 timing / fixed gearing we are in now in Europe
sidecarphil1 is offline   Reply With Quote
Old 01-10-2012, 10:56 AM   #8711
AlanHall's Avatar
Thanks. I have to buy new pinions and didn't want to buy a bunch I don't need
Alan Hall
AE B5r
AE B5/SC10
Old 01-10-2012, 12:06 PM   #8712
sp v3 5.5 is too much for my happy trigger finger. Will i see a diffrence if i buy a 6.5 or should i buy a 7.5?
And does anyone know who has these in stock? Cant find it in stock at the biggest US/HK shops.
Tnx
Marcus
MarcusEngdahl is offline   Reply With Quote
Old 01-10-2012, 01:05 PM   #8713
AlanHall's Avatar
you gotta setup a dealer account to buy from them??
Alan Hall
AE B5r
AE B5/SC10
Old 01-10-2012, 01:08 PM   #8714
burgboyz's Avatar
Tnx
Marcus
http://cefxspeedshop.com/Speed-Passion_c26.htm
Got Droop???
Old 01-10-2012, 05:42 PM   #8715
Tnx
Marcus
Try have a look in eBay I have seen a few in there
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
