Like Tree12Likes
Old 09-28-2009, 02:37 AM   #856
irgo's Avatar
Originally Posted by memix View Post
Today in the track ( outdoors tarmac ) with near 30C outside temp , the speed control was at 45C , motor 60C , lipo 45C .
FDR 8.2 ( 116 spur , 29 pinion )
that's 45C esc without fan ?
and where is your clear case picture ?
Quark Force
irgo is offline   Reply With Quote
Old 09-28-2009, 02:43 PM   #857
No its with a fan ( stock speed passion fan ).
About the pics , trying to find the usb cable for the phone so i can download the pics to the computer
Team Magic G4JS - Orion wasp .12 - Traxxas 4tec - O.S 18 tz
Team Magic E4FS - speed passion GT 2 pro - 4T ver 2 - 4.5T Ver 3
Kyosho spada 09 - Kyosho mini-z monster - Kyosho mini-z mr-02
memix is offline   Reply With Quote
Old 09-28-2009, 03:22 PM   #858
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by got2bqik View Post
Is it the general finding , now, with adjustable timining on the can, that for 17.5 it is better to crank can and esc timing up and gear down a bit to keep temps in check? Or is it still gear to the moon and play with timing on the esc to gain top end and keep temps in check?
Tim
I ran 3.7 with timing in the middle on can, (how it came out of box) esc timing 18.75 (speedpassion gt 2.0) no problems, could have went up a gear or two
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 09-30-2009, 03:40 PM   #859
AE 14year-old's Avatar
Trader Rating: 15 (100%+)
I have sent Shumacher 2 emails regarding speed passion speed controls but still nothing back can someone tell me if there is another place I should email instead??
Zack Rogers...
Kyosho / Team Orion / Airtronics / Jconcetps / Amainhobbies.com / Protek Rc / BlackBeard Rc / Rcinsider.com
AE 14year-old is offline   Reply With Quote
Old 09-30-2009, 05:16 PM   #860
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
may want to just call. could be getting caught up in the spam filter.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 09-30-2009, 05:22 PM   #861
Trader Rating: 22 (100%+)
Does anyone have any tips for the version 3 17.5 that they wish to share since the iic ?
Do you gear the same as the version 2.
Timming settings, is 0deg the same as the version 2 (non adjustable) timming or is the 0-10deg under or over and above the timming range of the version 2 motor.
Thanks in advance.
bjspinner is offline   Reply With Quote
Old 09-30-2009, 05:41 PM   #862
irgo's Avatar
where is adam ?
Quark Force
Old 09-30-2009, 07:40 PM   #863
skypilot's Avatar
Thanks in advance.
I gear mine at 3.7 with a tekin rs pro with the turbo turned off, and dropped 4 teeth with the turbo turned on, didn't notice a difference, (fastest car on the track either way) temp was only 140. could have added a tooth or two, but why bother
where is adam ?
maryland, at nationals
Old 09-30-2009, 08:02 PM   #864
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 34 (100%+)
Will the GT1.1 LPF run on 1s lipo? If so is a booster recommended?
-rocky b
flatspunout is offline   Reply With Quote
Old 09-30-2009, 08:26 PM   #865
cjmonkey's Avatar
Im running a 10.5 v3 geared at 5.920 with timming set to 0, and an LRP stock spec spx at profile 7. My car is a TRF416WE
After a 5 minute heat on a medium/technical track, the motor comes off at 35/40c ?!? can't believe how cool this engine runs. I'm using an LRP fan, which i am sure helps alot, but i am still amazed at how cool this motor runs.
Oh, not to mention... it's PLENTY quick.. for the whole 5 mins.
Makes me wonder if i could gear lower??
TAMIYA - LRP - Speedpassion - Sorex - Futaba - Protoform - Intellect - Muchmore
DEM Racing Team
W.E.R.C
cjmonkey is offline   Reply With Quote
Old 09-30-2009, 09:52 PM   #866
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
-rocky b
It sure will. Either a booster or a receiver pack will be necessary for the esc to power the motor optimally. It may run without one, but I wouldn't expect to win any races without a booster or receiver pack.
Old 09-30-2009, 09:53 PM   #867
Originally Posted by Mike Haynes View Post
312 software,full timing and 9 drrs, i have been using an rx pack and speedo switch off
You make me laugh out loud Mr. Haynes. Can I run a SP LPF 2.0 in my Mini-Z?
Old 10-01-2009, 03:01 AM   #868
Sorry to report it was a no-go...double-blinking green LED and no power to the motor at all. Plugged in a receiver pack and everything worked fine. Not a problem but maybe I don't have the newest software? I've had the ESC in my touring car since it was purchased in December of 08 with no updates.
-rocky b
Old 10-01-2009, 07:28 AM   #869
cyanyde's Avatar
There's no way 1s lipo can be used without a booster or receiver pack. The voltage is too low for the electronics to work.
cyanyde is offline   Reply With Quote
Old 10-01-2009, 09:09 AM   #870
skypilot's Avatar
not true
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
