Like Tree46Likes
Old 01-05-2012, 04:54 PM   #8671
that didn't really help much
ruselmaxx238 is offline   Reply With Quote
Old 01-05-2012, 05:30 PM   #8672
mattwoodcraft's Avatar
Originally Posted by AlanHall View Post
Matt.. i bought all this stuff. I really don't know what software it has. I can look at the box or the speed controller when I get home
Speed Passion GT V2.1 Pro Stock ESC + SP Motor + SP Program Box
does this program card allow you to connect to the p.c. if its the one that came with the speedy it will not allow it, i have the 2.0 and the pro stock now if the speedy has the 323 software in it it will not work, this program card will work with the kit software that usually comes with the speedy 528 stock which is what my pro stock 2.1 came with. you have the USB cord i see can this plug into that control box or does it only have the small 3 pin harness for programing the ecs
mattwoodcraft is offline   Reply With Quote
Old 01-05-2012, 05:53 PM   #8673
Originally Posted by ruselmaxx238 View Post
does anyone know where i can buy a speed passion rs2? i have been looking for one online and i can't find them.
if you can help me out that would be greatly appreciated
ebay
Old 01-05-2012, 10:30 PM   #8674
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
My box has the usb plug for the PC. But I have no idea what software is on the esc now.
Alan Hall
AlanHall is offline   Reply With Quote
Old 01-05-2012, 10:49 PM   #8675
LonnyJ1950's Avatar
The software is not on the esc, it's in the computer. The esc just responds to what the computer tells it to do. To program the esc, you have to download the link program to the computer, then load the software package into it. Most people who run boosted are using 323 stock. You set your specs for boost, DRRS, brake, etc, on the PC, then send it to the esc. Read the instructions or watch the video.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 01-05-2012, 11:02 PM   #8676
AlanHall's Avatar
Or I can ask here like everyone else does. Reading my directions tells me to plug my box into the esc or program the esc with the setup button. And neither work.
Alan Hall
Old 01-05-2012, 11:12 PM   #8677
@Art_Mighty's Avatar
Default Confused...
So what exactly is the difference between the "Short Course Master ESC" and the "Cirtix Inspire V2.0 ESC"? Looking at the manual and the setup information for the two i can't find anything that sets them apart.
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 01-05-2012, 11:47 PM   #8678
LonnyJ1950's Avatar
That only works for the LED box that comes with the esc and the programming it will do is very limited. The LCD box with the USB connector is the one that does the advanced programming. You MUST have a PC to use it. Download the USB link program V1.37 to the computer. Plug the USB connector from the LCD programming box into the computer. Remove the esc receiver wire from the receiver and connect it to the LCD box. Plug the battery in and turn on the speed control. Link V1.37 defaults to 323 stock software. At least mine did. Using the Basic and Advanced tabs you can set all your specs for brakes, voltage cutoff, boost, turbo etc. When you have it the way you like it press the apply button (I usually do it twice) and the settings will be sent to the speed control. The video on the website explains this much better and its free. Don't be too upset, I'm a grumpy old man.
Lonny
Old 01-06-2012, 01:00 AM   #8679
AlanHall's Avatar
Thanks alot. So once I do this the 1st time should I be able to adjust it with my lcd box? Like at the track? Cause now its just says "update software" when I plug in the esc
Alan Hall
Old 01-06-2012, 02:48 AM   #8680
the lcd box i use is the hobby wing it looks similar with the 323 software i do not take a lap laptop to the track so the answer is yes you can.
Old 01-06-2012, 07:44 AM   #8681
M-Technic's Avatar
Trader Rating: 15 (100%+)
That's correct. You only need to plug them into your computer once to update the software on the box and the speedo. After that, you will be able to make all the changes without a computer, simply with the LCD programming box.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-06-2012, 07:51 AM   #8682
AlanHall's Avatar
Okay I guess I was confused because it says to update the software. It works Fine right now The power curve is just a little too smooth like for off road. And I'm running touringe ith it now. That's what made me think it was the box that had the software loaded into it. so ithe box is telling me I need update the software in my speed control?
Alan Hall
Old 01-06-2012, 09:28 AM   #8683
Originally Posted by sidecarphil1 View Post
Hey guys
need some quick help
set up 1/12th , 1s , 3.0turns motor , quick flowing carpet track with lots of grip , SP GT2.0 speedo
we are racing saturday if possable ,
Thanks Phil
anyone ????
sidecarphil1 is offline   Reply With Quote
Old 01-06-2012, 09:40 AM   #8684
Trader Rating: 16 (100%+)
Try EBAY.....plenty of those with different color and with free shipping.
http://www.ebay.com/sch/i.html?_from...All-Categories
Old 01-06-2012, 09:46 AM   #8685
SCM = sensor system
Inspire = sensorless system
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
