The Speed Passion Thread
#8656
Couple questions. I have a superstock GT2.1 and my led box just shows update software on the screen and I can't do anything with it.. why wont it let me use the current software that it had? And also.. on my esc im trying to set it just using the setup button and I can't get it into setup mode per the instructions ...it just wants to keep resetting the throttle and neutral setting and wanting to run the motor. Maybe im.doing something out of order?
#8658
Hey guys
need some quick help
set up 1/12th , 1s , 3.0turns motor , quick flowing carpet track with lots of grip , SP GT2.0 speedo
we are racing saturday if possable ,
Thanks Phil
Thanks Phil
#8659
Im confused use my lcd card instead of my lcd programmer card? I have no idea what software the esc has. I plug in my lcd box and when it powers up it says "update software "... and so I attempt to just change the settings through the setup button on the switch and ut will only program my radio setting.. fwd ..neutral etc. I can't adjust the boost and get it into that setup mode...
#8660
The latest software and instructions that you need is available here: http://www.speedpassion.net/us/download.asp
It will only take you about 10 minutes to do it all. It's very simple.
#8661
It sounds like the LCD box and speedo don't have compatible software on each other. You have the USB cable right? Plug the LCD box into the computer and update the software, and then do the same with the speedo. You should have no problems using the LCD box then.
#8665
i hove done nothing more than attempt to plug the box in to the esc.. and then try to go through the setting by using the setup button on the on/off switch. i would definitly rather start fresh if possible. i only have PC access at work. i will ring it in tomorrow and plug it up and see what im working with. il have to load the disk into my PC right?
#8666
if you go to speed passion web site and select the speedy you have select down loads and you should be able to down load the the current usb link V1.37 this will be a good starting point start fresh. the program card you have does it allow you to connect to a PC ? if the speedy has already got 323 stock loaded on to it and your trying to adjust with the kit standard box it will not work do you have the LCD one ?
#8667
Speed Passion RS2
does anyone know where i can buy a speed passion rs2? i have been looking for one online and i can't find them.
if you can help me out that would be greatly appreciated
#8668
Matt.. i bought all this stuff. I really don't know what software it has. I can look at the box or the speed controller when I get home
http://www.rctech.net/forum/r-c-item...ogram-box.html
#8669
Speed Passion RS2
thanks, i will start there. hopefully this will lead me to a site where i can actually buy a speed passion rs2
