The Speed Passion Thread
#8641
Is there anyway to change the rotor in the MMM? I have a 17.5 in an HPI blitz used for oval racing. I have a FDR as 7.7:1. My top speed is fine I just need some more punch coming outta the corners
#8643
#8644
rollout chart
Hi, is anywhere available rollout chart for SP motors?
#8647
Hey guys,
I just bought a 10.5T Speed Passion V3 for my Xray T3.
I'm looking for a good starting FDR for indoor (Boosted & Blinky). The track is about 14m*30m. The other tracks I drive on are about the same. (Currently, I drive with a FDR of 6.4 on our track with a 17.5T boosted motor and it's perfect)
#8648
I have the citrix short course master so its got no boost.
But I have max boost and max timing thru the esc then on the motor i have max timing on the stock sensor ring.
On race days I have very little time to practice at the track since it's only open twice a month on race days.
Any help would be great
#8649
Couple questions. I have a superstock GT2.1 and my led box just shows update software on the screen and I can't do anything with it.. why wont it let me use the current software that it had? And also.. on my esc im trying to set it just using the setup button and I can't get it into setup mode per the instructions ...it just wants to keep resetting the throttle and neutral setting and wanting to run the motor. Maybe im.doing something out of order?
#8650
#8651
Mr M-Technic I few pages back a couple of weeks ago you gave me some different settings to try after posting my speedy set up and discussing the problems I was having today I will be heading down to the track and giving it a shot I will let you know how it goes also the write you put down about the 323 software it helped very much with myself to understand it more
#8652
