Old 12-30-2011, 01:17 PM   #8626
M-Technic's Avatar
Trader Rating: 15 (100%+)
Here is my mod touring setup for 323_Stock. Using a Trinity Duo3 5.0t motor, 8.82 FDR, Xray T3 2012, and the SP GT 2.0 Pro ESC. Hope this helps!
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-30-2011, 06:02 PM   #8627
kwiksi's Avatar
Trader Rating: 101 (100%+)
Send a message via AIM to kwiksi
Originally Posted by kwiksi View Post
Whats a good fdr for tc on a med indoor carpet track for 17.5 blinky using v3 with kit 10 deg timing.
Originally Posted by Drillit View Post
3.2 to 4.0 'ish', you know the story, small, med, large, grip etc......
this is why we need the Tuning Sensors, to get us up to blinky 30* gearing like some of the others.
Just ckecked last weeks club race notes, was runnin 3.48, came off at 175*f after 6mins with fans on speedo and motor. tc4 team tub, sp 2.0, sp 17.5v3 w/ 10*sensor. carpet, med grip ozite. oh yeh, battery, ready for this? original gold brick Track Power 4900 29c, almost keeps up with the latest revtech stuff....almost
I forgot to mention this is for rubber tire.
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - Vision Racing Products - Reilley Motorsports - 92Zero Designs
kwiksi is offline   Reply With Quote
Old 12-31-2011, 07:18 AM   #8628
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Correct........it's been a while since we've had foam tc here in Oregon also.
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 12-31-2011, 03:32 PM   #8629
Slash'em1's Avatar
Can a Speed Passion GT 2.0 pro be set to run in "Blinky" mode?
never mind I figured it out!
Slash'em1 is offline   Reply With Quote
Old 12-31-2011, 03:58 PM   #8630
For sp17.5v3 no timimg racing with the motor set at 10 degrees. I always ran 2.8 to 3.2 fdr. Make sure to watch your temps.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 12-31-2011, 07:13 PM   #8631
Originally Posted by jake95 View Post
yes it does
does 1 cell motor run for long time or is recommended for short run time? i not sure on 1 cell or sportman motor.
thanks
freakyfreakyflo is offline   Reply With Quote
Old 01-01-2012, 03:31 AM   #8632
Originally Posted by anzmania View Post
Hi, does anyone have an approx FDR for the following combo?
Running a GT 2.0 lpf ESC and 21.5T Competition 3.0 motor. Its on a med/large technical track with medium traction (asphalt). Rubber tires. Supercharger function is permitted.
Cheers
Anyone able to help with this query?
anzmania is offline   Reply With Quote
Old 01-01-2012, 04:04 AM   #8633
mattwoodcraft's Avatar
thanks
i run with my cell in the F1 for 25 mins when practicing no problem at all smooth motor barley even gets hot warm only
mattwoodcraft is offline   Reply With Quote
Old 01-01-2012, 07:42 PM   #8634
bluef250's Avatar
question about the DRRS setting, is this just starting from a stop? what effect does this have?
bluef250 is offline   Reply With Quote
Old 01-02-2012, 04:53 AM   #8635
the higher the number the stronger it accelerates out of corners the lower the smoother it is, in my TC i either use option 8 or 9 in stock mod may be a whole lot lower for smoother acceleration
Old 01-02-2012, 10:21 AM   #8636
Kulgs's Avatar
I use option 7 at our track
Rob
TEAM PMS, Paint by Patto
Xray T4 2016!!!
Kulgs is offline   Reply With Quote
Old 01-02-2012, 03:17 PM   #8637
bluef250's Avatar
i race high bite dirt oval, so acceleration out of the corners is crucial. Does this setting effect top end?
Old 01-02-2012, 03:26 PM   #8638
It affects punch out of a corner and start top end is more so gearing and whether or not you are using boost the higher the Drrs does affect heat in the motor
Old 01-02-2012, 03:37 PM   #8639
bluef250's Avatar
thank you.
Old 01-02-2012, 04:00 PM   #8640
ghiro's Avatar
Send a message via Skype™ to ghiro
Anyone here using Sanwa/Airtronics M11X + 451-R rx is having any problem in using this combo in SSR mode with a GT2.0 Pro?
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
